  • Replies 52
Posted Images
lol Joel, you redeemed yourself with that last line :)
seriously Damo, unless you've done what Joel and others have done in relation to baffles and restrictors, do not try this method.....2 laps around Malalla and they'll be full.
I still believe that the 2 can setup that I described earlier is still the best for no other mods to restrict the oil
+2 for the two can system if you havent done your internal oil mods..
It worked well for my GTR and I took it to the track all the time and was doing quick times.
I still overfilled the oil a litre and half as well.
Your always going to get a bit of oil in the 2nd can if your pushing the car and out in it alot..as long as you top up the oil you will be right ;)
I decided to fit an oil catch can before i went to Mallala on Sunday, just one of those cheap ones from ISC. This is how much oil was in it after just one day at the track.
Edited by DSTROY
No baffles, and yes i did overfill. Filled it to the top of the H on the dipstick and i tried not to rev past 7000rpm but i hit the limiter at 8000rpm a few time when the wheels decided to spin coming out of corners in second gear.
If the catch can fills up with oil after a few laps, what would it indicate? Severe blow-by? Or just incorrect setup?
They all pump oil out when at high revs from the head as the oil cant drain to the sump quick enough. Mine used to fill up after a full day at the track
Depends on how big the catch can is to get concerned??Thst why I like the two can system one mounted ontop of the head and breathers going to a seond can situated near my headlight
If the catch can was filling up with general driving thats blow by :wub:
It can be due to a number of factors, the most common being.
1 Incorrect set up. Mostly this involves people removing the pcv function which allows the sump to be pressurised which in turn causes problems. Make sure the pcv is fitted & working - this can be done even when a catch can is fitted.
2. Oil in the head splashing/generally finding its way into the recirc system. This is common on RB26's particularly. The popular conception is too much oil pumped is into the head - but it is just as much a function of poor shielding for the venting system. It can be fixed by oil restrictors (head off), oil return lines (engine out - mostly), Mines cam baffles (see below!) or oil/air seperators like the Nismo offerings (Stupid money for what you get). The principal advantages of these systems over catch cans is the are either hidden from view or look stock. Which means one less potential point of grief from the police. There are other offerings as shown in this thread but they tend to stick out like dogs b@llocks.
3. Blow by.
  • 5 months later...
Pete,
Another mod is to relieve/vent the pressure in the sump to a catch can. Also works as a catch can drain if needed which it won't. :D
Where can this connection to the sump be made on an RB25? Could you just T-into the turbo oil return line? Also would it need a PCV valve?
3. Blow by.
PCV valve has almost nothing to do with it. The PCV valve only operates when there is negative intake manifold pressure, so unless you have a N/A it is closed apart from off boost... The factory system utilities a passage from the breathers to the intake before the turbo which allows the vacuum from the turbo to continuously pull from the crankcase.
The main thread has better details, no point going over it again in here.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
    • Could be correct. Meter might be that far out. Compare against a known 5 ohm 1% resistor.
    • @Murray_Calavera  If I were an expert I wouldn't be in here looking for assistance.  I am extremely computer literate, have above average understanding on how things should be working and how they should tie together.  If I need to go to a professional tuner so be it, but I'd much rather learn and do things myself even if it means looking for some guidance along the way and blowing up a few engines. @GTSBoy  I was hoping it would be as simple as a large vacuum leak somewhere but I'm unable to find anything, all lines seem to be well capped or going where they need to be, and when removed there is vacuum felt on the tube.  It would be odd for the Haltech built in MAP to be faulty, the GTT tune I imported had it enabled from the start, I incorrectly assumed it was reading a signal from the stock MAP, but that doesn't exist.  After running a vacuum hose to the ECU the signal doesn't change more than 0.2 in either direction.   I'll probably upload a video of my settings tomorrow, as it stands I'm able to daily drive, but getting stuttering when giving it gas from idle, so pulling away from lights is a slow process of revving it up and feathering the clutch until its moving, then it will accelerate fine.  It sounds like I need to get to the bottom of the manifold pressure issue, but the ignition timing section is most intimidating to me and will probably let a pro do that part.  Tomorrow I'll try a different vacuum line to T off of, with any luck I selected one that was already bypassed during the DBW swap.  (edit: I went out and did it right now, the line I had chosen did appear to have no vacuum on it, it used to go to the front of the intake, I've now completely blocked that one off at the bracket that holds several vacuum lines by the firewall.  I T'd into the vacuum line that goes from that bracket to the vacuum pump at the front of the car, but no change in the MAP readings).  Using the new vacuum line that has obvious vacuum on the hose, im still only getting readings between -6.0 and -5.2.  I'm wondering why the ECU was detecting -5.3 when nothing was connected to the MAP nipple and ECU MAP selected as the source. @feartherb26  I do have +T in the works but wanted to wait until Spring to start with that swap since this is my good winter AWD vehicle.  When removing the butterfly, did it leave a bunch of holes in the manifold that you needed to plug?  I thought about removing it but assumed it would be a mess.   I notice no difference when capping the vacuum line to it or letting it do its thing.  This whole thing has convinced me to just get a forward facing manifold when the time comes though.
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
