Sitting around one day talking with my girls dad about motors that are easy to work on and cheap we came up with holden V6. I also always wanted to do up a ozzy R31 skyline as i had some out there ideas for one. so we decided we would get one and put a V6 in it. This is what we have done so far.
Note: Not looking to make it the fastest or best r31 out there just a fun n/a street car
1. Got a R31 from the wreckers and gutted it out
2. Had a old fu*ked V6 in the shed so we gave it a test fit. It sat in realy good lower and back more then a rb30 would.
3. Picked up a vp commodore realy cheap with a good working V6
4. Next it was time to start painting went with the red off a vt commodore. Engine and doors frist.
5. Made up engine mounts crossmenber and Tailshaft
Sorry the pics arn't to clear using my phone to take them.
This is were I'm getting some of my ideas from:
Let me know what you think will update soon.
https://www.sau.com.au/forums/topic/261001-v6-in-a-r31-skyline/
im just trying to figure out why you'd go through all that trouble for a VP V6 engine? I dont even really see that engine as an upgrade at all over the RB30e.
I say either work the **** out of that rb30 or drop a 5ltr in it :blink:
I could see the point in an LS1 conversion - 5 litre = lots of work for comparitively small gains, they're not really worth bothering with anymore, unless you already happen to own one.
Holden V6 though - vomit, rough, shite sounding motor, though turbo conversions are apparently widespread these days, why oh why not stick with the RB30 and turbo it?!!?? or buy a VN!?
I went in the other day and got a quote to recondition the V6 ( new rings, bearingd, decked, crank ground and linished so on ) ARP head stud kit, port and polish the heads, stage 4 crow cam kit, timing kit, gasket kit, was some other little things to but i forgot what. For me to take just the engine into him the quote was just under $3000
Also I went with the VP V6 as it has less crap on it then a ecotec V6 and vp commodores look like crap thats why i would not just get one of them.
  • 7 years later...
No question the RB 30 sounds sweeter - we have one of each and I've only heard one VT V6 that sounds good.
Bloke up in Strathpine QLD.  HE put a lot of work into it. I keep mine quiet.
Don't laugh though, that V6 has WAY more torque than mildly modded RB30s no real increase in weight, more than a VL turbo up to about 5k.  Torque is what turns the axles :)
Set the V6 donk back for better handling than an RB30 can give you - as the OP said.
A cheap, stock drop in.  Keep it quiet and you have a low cost sleeper.
Saw a complete (running) car at action go for a tad over $200.
Part it and the engine pays for ALL the other mods.
Turbo it and it HAMMERS in that light body.
I wonder if it can be stuffed into a 1200 ute?
Pics .. https://photohounds.smugmug.com/Cars
  • 1 year later...
i know this is a really old post... but im interested in finding out more about this conversion, mainly because my RB30 isnt the healthiest and im looking at cheap options until i can put what i want in the car, what was involved in it, obviously mounts crossmember and tailshaft, would the rb30s gearboxes (auto or manual, i have both)  hold up or even fit to this engine? any info would be appreciated and i thank you kindly in advance, peace out and stay gold mate :)
- Coopz
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
