Hey all, i was just thinking and wondered when we will have a V35 meet up cruise?.. for instance NSW and VIC organise a cruise and meet in the middle somewhere to share lunch and have a barbie then split back home again.. or NSW and QLD or WA or whoever!.. I think it would be a good social day.. But yeh WA is so far! =). Anyway just a thought it was a good idea (if ever it happens). So its just like here on the forums but in person! hehehe :blink:
Peace,
https://www.sau.com.au/forums/topic/261002-cruise-idea/
Peace,
oooh yeah!
just give me a couple of weeks to repair my V35's door locks and flux capacitor....
I'll be there, there, there and there!!!
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4476512
5 hrs driving for lunch.. i dont think there would be a lot of people interested.. and meeting in the middle, what will b the possible interest places?
Very looking forward for vic GOR cruise thou..
but if everything is planned, yea, why not, i am happy to join in~
p/s: more interested if someone can update my navigation's speed cam POIs.. lolz :blink:
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4476531
I got really excited when I read earlier about a SkyHigh cruise......I live around there!!!!!!
Man...we could take some killer pics, talk shit, pose a little, have a few snags....
And...that drive!....woah..I still can't get bored with it!
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4476536
I would organise it if there would be alot of people who would want to come.! But yeh 5 hours is a bit of a drive.
but if alot of people are down with it then im down. first ever V35 Group shot in AUS. woOt! (if it happens with at least 10 cars not just 2 or 3)
How bout individual state cruise?
Should be fun.
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4476552
Im in 100% to either choice.
In saying that, RTA are suspending my license for 3 months from 16 APR - so im out till 16 JUL :down:
waaa?? what happened man?
Hate to be you right now.. hope time flies for you man.
anythign happened to the beast?
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4476662
Points accumulation =(
Boxing Day, Double Demerits (NSW)
105, in a 50 zone - 12 points BAM!
Beast is getting a CarPuter while it waits idle =(
http://www.skylinesaustralia.com/forums/Ca...10-t261099.html
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4477766
dayemmmm... really hate to be you right now..lol all well.. thats a good lesson for yah. hehe
Just tell the carputer mechanic to take their time doing your stuff! :)
To Sethaiyaar, hmm track day? i think i pass that one. ill come watch and support tho. hehehe
yeh, hope any V35 interstate cruise happens sometime soon for a good cause (charity or something) and a group shot would be good for SAU V35 section!
Peace,
p.s haha good joke Paul... keep hunting!
https://www.sau.com.au/forums/topic/261002-cruise-idea/#findComment-4477853
    • What does it look like with highway driving? And yes, I had a similar thought as Duncan. It looks quite similar in my Stagea and I have made myself accept it as normal. Might have to look into it some day
    • While I was waiting for the new parts to come in for the charge pipe and radiator I decided to do some turbo modification. The drive pressure (exhaust backpressure) was a lot higher that I thought it should be. For 32lbs of boost drive was 55lbs. The turbine housing is a 1.10AR and my turbo builder has suggested to go to a 1.25AR. To test if a larger AR would do anything to reduce drive pressure AND not spend any money I decided to hog out the divider in my current housing. I removed it from the inlet and the whole way through the housing.  After reassembly and testing it doesn't look like this modification did anything for reducing drive pressure or requiring more fuel (making more power). Oh well, it was worth a shot. We'll get some data at the track if it makes it past the 60ft. I also machined a $7 shift knob off Amazon to fit my Stillway shifter since I didn't like the Stillway shift knob. Next on the list was the radiator replacement and fabrication of a new intercooler tube that had no silicon coupler. No pictures of this - I was short on time each night after work to get this done and didn't stop to take pictures.  Next was to get the clutch disks out and replaced. Previously when installing the dogbox I had ordered a set of the same sintered iron disks I had been running because I switched to the 26-spline input shaft. I thought it was odd that they didn't have any markings or brand name on them like all my old disks had but installed them anyway. At the track I could not get the clutch to lock up using my normal strategies. After two track nights I reached out to the clutch manufacturer and ask their thoughts. They said they had to switch the material out because they were having trouble getting the original material and that this new material would not take to being slipped very well.  So out with the first set of 26-spline disks and in with the correct material 26-spline disks. While I had the trans out I added an inspection/service hole. I've wanted one of these for a while. Now I can have a look at things and change the front cover shimming when needed (clutch wear). I hustled and got the clutch change done in a few hours on a Saturday. Hopped in the car and drove home. On the way home I did a 1-3 pull. When shifting from 2nd to 3rd the core plug in the back of the cylinder head popped out and dumped all the coolant. Thankfully I was only 30 seconds from home and coasted it there. Datalog showed nothing unusual and 2.5psi of coolant pressure. That plug has been in there since 1992 but I guess it worked its way out. Pulled the trans AGAIN and replaced the plug, JB welded it in, and made a brace. Also deleted the head drain I had added in during the bearing issue fiasco.  I am currently changing my boost control plumbing to make it cleaner. After that is done I'll make another attempt at getting past the 60.
    • Are you 100% sure this isn't tune related?
    • 140-150 across the board. At this point hoping the grounding harness fixes it. My grounds are all tied to the chassis and none to the battery. For SR and KA that’s never been a problem for me but had a few other guys here and Reddit who told me RB really like a very solid ground setup tied to the battery so going to try that next, I’m stumped if that doesn’t do it. Never had a car have spark and fuel and not fire off before. Only thing I can think is the spark is intermittent/weak because of grounds nothing else really makes sense at this point
    • I am having close to the same issue. Can you help me with what wire you grounded to get your pump to trigger?
