Guaranteed S.W.A.T response
Agreed.
Sarp mangs. Went and had a look at the car. Only thing left to do was the boot lip. It looks amazing. wub.gif
Wanna see. wanna see. wanna see.
watcha getting done bruski ?
boob job and some facial work.
Morning Mangs,
Not at work! Yay!
Too much COD. or WOW. Plus 1 mace.
I put on my robe and wizard hat...
much awesome. Cant wait for my MMS
That's what she said
Just walk away then......se if I care.....
Had beer, feel better.
Much awesome!
until the ceramic rubs off??
i <3 boost.
+1
In other news:
:D :D :D. f**k Three.
In other news:
Good work, welcome to good coverage, cable and connection, but shit everything else.
QQ does anyone know if you pay more tax as a subcontractor? I'm subbing with no abn.
No idea dude
why is the current network still called the Next G network? whats' the new one going to be called? next next G?
20G network.
Why does the sum total of the garbage we throw out every week add up to more than we bring in.
Fudge factor multiplier.
Depends on what you earn as usual, and what you can right off as business expenses.
Noel as we speak im finishing off another bottle of wine. Seriously thinking of drinking more
but i won't
took photo's of bike and put them on facebook
but i won't
LOL. I wont say much Dan, I too have a weakness for grape juice.
Weekend was the usual. Work, followed by more work :P
No really cute birds in at work tonight. Some ok talent but nothing really stunning. Made me all :(
Spotted you on Coro drive 10 minutes ago... i purposely drove slow so you would give it some to pass, and you did :thumbsup: Was in a black crv >_<
    • @Haggerty you still haven't answered my question.  Many things you are saying do not make sense for someone who can tune, yet I would not expect someone who cannot tune to be playing with the things in the ECU that you are.  This process would be a lot quicker to figure out if we can remove user error from the equation.
    • If as it's stalling, the fuel pressure rises, it's saying there's less vacuum in the intake manifold. This is pretty typical of an engine that is slowing down.   While typically is agree it sounds fuel related, it really sounds fuel/air mixture related. Since the whole system has been refurbished, including injectors, pump, etc, it's likely we've altered how well the system is delivering fuel. If someone before you has messed with the IACV because it needed fiddling with as the fuel system was dieing out, we need to readjust it back. Getting things back to factory spec everywhere, is what's going to help the entire system. So if it idles at 400rpm with no IACV, that needs raising. Getting factory air flow back to normal will help us get everything back in spec, and likely help chase down any other issues. Back on IACV, if the base idle (no IACV plugged in) is too far out, it's a lot harder for the ECU to control idle. The IACV duty cycle causes non linear variations in reality. When I've tuned the idle valves in the past, you need to keep it in a relatively narrow window on aftermarket ecus to stop them doing wild dances. It also means if your base idle is too low, the valve needs to open too much, and then the smallest % change ends up being a huge variation.
