What does the loom do? I though most of the time the ones in the guards were to do with headlights and indicators.
I've lost my indicators and a couple of other little bits. Headlights are still ok and rest of the car is running as per normal. Chris is sorting it out tomorrow and I got some prices on some new rubber for the fronts. Will have a look and see if I can't jack it up a little further but they look like they are at 100% as is...
All I want is a front end I trust and right now I don't trust mine as far as I can throw it :( There must be some aspect of the front suspension setup I'm overlooking, surely the change from 225/45 to 235/45 can't be the only culprit here. Its only 4.5mm difference in the sidewall or 9mm overall.
Morning Mangs,
Too quiet in here :(
That sux dude :(.
Remember 225/45 to 235/45 is going to make the tyre WIDER and TALLER. So it could make a difference.
Yeah, it is different but who'd have thought that 10mm wider and 4.5mm higher would make so much difference. Once I get the loom sorted I'm thinking I'll go buy some 225/45 595 RS-R's for the fronts and keep the 235's as spares to replace the rears I'll no doubt ruin at the drag day ;)
Question for all. If under boost my car sounds like i am strangling a cat BUT only happens when cold what would that mean? Thinking turbo on the way out but hoping that isnt the problem.
Oh and good morning all
Looks like Joe made a call to UK customs for me! :) Thanks Brooo
18-07-2011 19:45 National Hub Received and processed
18-07-2011 17:47 International Hub Forwarded for UK processing
15-07-2011 08:38 International Hub Awaiting Customs clearance
10-07-2011 17:03 International Hub Awaiting Customs clearance
10-07-2011 17:00 International Hub Received in destination country
05-07-2011 23:58 Delivery Agent - BRISBANE - PTT Forwarded for export
05-07-2011 16:21 Delivery Agent - AUSTRALIA Collected from customer
I was told 2-4 days by Aus post, and its now been 13 and it still hasn't gotten there yet :(. 8 days to clear customs :devil::domokun:
Could be a dying turbo. Could just be a gasket or something too. worth checking out.
Customs clearance number speeds that up. average ex japan for me is 3-5 and 6-8 for the UK.
If it was gasket tho wouldnt it happen all the time and not just when cold? i am really hoping it is gasket <BR>Typical tho. First time i go to a track i get issues lol Edited by Kiwibob
I had no problem getting it here from the UK. Left the UK thursday night and I got it on Monday. I don't think Aus customs had a chance to blink it went through that fast.
Hold up has been sending it BACK to the UK for warranty (f*ck ever buying a phone overseas again). But it seems I can blame Joe for the holdup :P :
Urgh, my busted phone has been sitting in UK customs for 3 days. What's up with that?
I called them and told them to do so. Had to pull some strings but it was well worth it :nyaanyaa:
If it's a gasket it might just be on its way out at the moment so as the car heats up the gasket expands and fills the holes. When its cold it's contracted and leaves a bigger hole.
average ex japan through customs for us is about 20-25 minutes...:P
haha!!
your company is a 1000 times bigger than mine..
    • A few small updates since the previous post and lessons. I decided to do a little interior light upgrade on the 110. I quite like the iilumo items, even if they're a bit of a premium over other brands. You'll also note the Stedi Fogs, that will go into the S15 fog lights as I needed to match the bulbs since I got the new ones earlier. I hope they fit as the body is quite a bit longer than your normal bulb.  Annoyingly, I managed to trip the fuse, which normally wouldn't be an issue until I located the fuse. I can't say I've ever come across this. I had lucked out that someone nearby had a spare, but oddly enough Toyota dealerships seem to keep this in stock. I ordered some to keep in my stash and as luck would have it, someone else nearby tripped the same fuse so I passed on the favour.  I also did a little service on the 110 ahead of some additional work coming up. It's been annoying that Goleby's stopped carrying this particular HKS filter for the 110, so now I need to keep them on order from Japan. I also took the opportunity to install a bash plate and number plate riser. The plate riser is such a cheap but nice fix to help really tidy up the car. I'm tempted to now also replace my headlights, on this car. Both items were from Project Aero.    I also needed to replace the rear tyres on the 110, and after trying to get it aligned learnt that I need to replace some bushes in the front end, so that's next.  Closing out this update with a nicer picture as always!
    • Yeah mate, never miss it.
    • Any going to watch World Time Attack at SMSP this year?
    • Appreciate the correction on the "ground", that will make a huge difference to looking at this. That makes complete sense about AF70/AF71 which is what I had come down to being the issue, one of these. I'll have another look in the ignition wiring when I get a chance next week. I'll also make up a jumper wire for running that AF73 test.  ECU is fine, relay itself is fine, pump harness is fine and the pump itself is fine. I am going to upgrade the Walbro 255 anyway with a DW300 I have since I need to replace the fuel sender and I'm going to upgrade the FPR with my chasebays kit ready for new plenum/injectors/dbw, but I'll get this working first. That's why this is so frustrating.
