What does the loom do? I though most of the time the ones in the guards were to do with headlights and indicators.
I've lost my indicators and a couple of other little bits. Headlights are still ok and rest of the car is running as per normal. Chris is sorting it out tomorrow and I got some prices on some new rubber for the fronts. Will have a look and see if I can't jack it up a little further but they look like they are at 100% as is...
All I want is a front end I trust and right now I don't trust mine as far as I can throw it :( There must be some aspect of the front suspension setup I'm overlooking, surely the change from 225/45 to 235/45 can't be the only culprit here. Its only 4.5mm difference in the sidewall or 9mm overall.
Morning Mangs,
Too quiet in here :(
That sux dude :(.
Remember 225/45 to 235/45 is going to make the tyre WIDER and TALLER. So it could make a difference.
Yeah, it is different but who'd have thought that 10mm wider and 4.5mm higher would make so much difference. Once I get the loom sorted I'm thinking I'll go buy some 225/45 595 RS-R's for the fronts and keep the 235's as spares to replace the rears I'll no doubt ruin at the drag day ;)
Question for all. If under boost my car sounds like i am strangling a cat BUT only happens when cold what would that mean? Thinking turbo on the way out but hoping that isnt the problem.
Oh and good morning all
Looks like Joe made a call to UK customs for me! :) Thanks Brooo
18-07-2011 19:45 National Hub Received and processed
18-07-2011 17:47 International Hub Forwarded for UK processing
15-07-2011 08:38 International Hub Awaiting Customs clearance
10-07-2011 17:03 International Hub Awaiting Customs clearance
10-07-2011 17:00 International Hub Received in destination country
05-07-2011 23:58 Delivery Agent - BRISBANE - PTT Forwarded for export
05-07-2011 16:21 Delivery Agent - AUSTRALIA Collected from customer
I was told 2-4 days by Aus post, and its now been 13 and it still hasn't gotten there yet :(. 8 days to clear customs :devil::domokun:
Could be a dying turbo. Could just be a gasket or something too. worth checking out.
Customs clearance number speeds that up. average ex japan for me is 3-5 and 6-8 for the UK.
If it was gasket tho wouldnt it happen all the time and not just when cold? i am really hoping it is gasket <BR>Typical tho. First time i go to a track i get issues lol Edited by Kiwibob
I had no problem getting it here from the UK. Left the UK thursday night and I got it on Monday. I don't think Aus customs had a chance to blink it went through that fast.
Hold up has been sending it BACK to the UK for warranty (f*ck ever buying a phone overseas again). But it seems I can blame Joe for the holdup :P :
Urgh, my busted phone has been sitting in UK customs for 3 days. What's up with that?
I called them and told them to do so. Had to pull some strings but it was well worth it :nyaanyaa:
If it's a gasket it might just be on its way out at the moment so as the car heats up the gasket expands and fills the holes. When its cold it's contracted and leaves a bigger hole.
average ex japan through customs for us is about 20-25 minutes...:P
haha!!
your company is a 1000 times bigger than mine..
    • Power steering is probably because someone has nuked the HICAS CU and you no longer have the variable power asist doing what it is supposed to. How much boost are you running? You are aware that any more than 10 psi on the stock ECU is just asking for it to go to full R&R (that's Rich & Retard, which is effectively Retarded and Retarded!) which kills all the power. Depending on the exact conditions, it can just be runnign on the fat and stupid end of the maps, then the conditions change, you make a little more boost and the ECU goes into panic.
    • @BuiltNotBought Just as GTSboy said.   If you want driveabilty and more low down torque..keep the stock runners. They are VERY good from a factory. I have them too on my RB25DET NEO and as a GTSboy i have fmic but with stock piping route(i have Blitz intercooler) Iam making around 320 BHP and the car pulls "hard" from like 2,5k all the way to 7k. I have it dyno tuned to mimic N/A power curve and making little less max torque due to the smallbox tranny. But driveability is very great. I had 350Nm below 3k so car feels very quick.
    • Looking to sort out a couple of issues on my skyline  It recently was rebuilt, however rebuilder long story short did not give two flying effs about the work he did. So moving forward it's running but I have two persistent issues 1) it has a misfire / lag type of issue (was at higher RPMs but I had a dead piggy back ecu removed which improved it) now it's not as bad but still does it at random, I thought it may have been a boost issue I'm running an older turbosmart dual stage controller, turbosmart told me to try running off gate pressure however it still has a lag at random times. It has New MAF, maf plug, coil packs, sparks, CP harness.. injectors tested and cleaned. Factory ECU. 2) Power steering issue. It is tight as anything. Flushed power steering, rebuilt my pump because the bearing was shot. Flushed again still tight (mainly when parking and going slow into my driveway etc)  No kinks in hard lines, replaced the lines I could see had cracks. Still tough to steer.  I was told to shim a coin and place into the solenoid plug? Is there anything else. My steering angle sensor also has a issue. It's a used one I replaced, does it need to be calibrated? I feel like I've tried everything and this car is my voodoo doll.
    • Holy shit... wow!!! I totally missed this
    • One main filter. Each tank has a prefilter to keep rocks and small children out, then the big main filter that also does water separation. Clogged the first one so bad it was like a rev limiter at 3200rpm. Literally just like dropping the throttle off and maintaining rpm!
