Yeah, sucks but have to do it at this stage.
Hoping that I will build something again in a year or two, but am probably being a bit optimistic
I find pizza capers too expensive. Can't justify spending that much when I can pick up dominos or eagle boys for $6-7
I think I am just incredibly cheap
And good looking
Cheap and good looking, in case you guys missed it
they are expensive. but it covers lunch today aswell.
Domino's can go eat a big phat one (id rather eat my own excrement than buy that garbage again), and eagle boys wasnt easily on hand :)
good night it was, getting pulled over by the Girls in blue was entertaining. dam that was a cold drive home.
I has a set of keys!!!
1/1 Silvyn St
Redcliffe
(cnr Anzac ave and silvyn st)
new place. signage being sorted now. look for a LOT of changes over the next few months. major relaunch happening.
1/1 Silvyn St
Redcliffe
Soooo.... Does the wife know yet?
Beers at opening?
maybe.
definitely a tech night there though. this place is mine (leased but mine) so I can do what I need to do now.
Ralf and Bodo, we love your adventures to our Fancy town.
lol, love it.
there are a few good caboolture specific ones around too.
I'll have to find my flano and denim overalls for happy laps....I'm sure they're around here somewhere.
not yet. need your services as well.
So when does she find out?
I'm booked out for the next few weeks and then I'm overseas for work.
maybe.
Keen to throw my hot sausage at people again.
sounds good to me :)
/\ This
lol, love it.
Thought you might get a kick out of it.
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
