I would if i was an insurance company.
turns out i still need to cover the excess until they track old mate down, or i just wait till they sort that out (in other words Shannons dont want to sort out the police report asap, and are trying to scam 500 out of me)
Got the ball rolling yesterday, now i need quotes. can someone suggest a good panel shoppe on the northside? ive never had to deal with one...so i wouldnt know.
Anybody free and willing to help me dismantle the car this weekend? Struggling with shitty tools and have no idea how to go about pulling the engine out.
Willing to provide food and drinks cause I am a cheap fark
Mangs,
Doesn't feel like Thursday, but it is. So Maccas tonight :)
I was happy with the work done by this mob:
http://www.localbusinessguide.com.au/listing/g-a-wolfe-and-co-northgate/
notthere because GTR..
(I have the silver one in my possesion again. full interior strip with NEW bits going in.)
http://www.truelocal.com.au/business/strathpine-crash-repairs/lawnton
These guys did work on my sisters mazda, they replaced a rear quarter skin and painted it. I know they replaced it i just can't work out where they joined the new panel in. Quality work great blending on the paint (can't tell where it starts) and fast repair.
Not as fresh. Had to take the leopard for a couple of long drives to see if miss was fixed (it wasn't), and then I had to drive the skyline for a few days while I changed the coil packs, etc. So they're both a touch dirty. Will be fine with a wash though.
....then they will no doubt get dirty again on the 400km trip out to gundi. :(
    • Update: tested my spark plugs that are supposed to be 5ohms with a 10% deviation and one gave me a 0 ohms reading and the rest were 3.9ohm<, so one bad and the others on their way out.
    • 9" wheels are a little too wide for a RWD 32. They can fit. People have put R33 GTR wheels on 32s for years and years. But they are a very tight squeeze. This has been known for about 30 years. As I said - there is no difference between a 17 and an 18 in terms of what will fit. The rolling diameter needs to stay about the same as stock - not very much larger. If you increase that, you will start to have problems. If you increae rolling diamater at the same time as yo increase width, you will have problems earlier. as 9" wheels are pushing the boundaries already, you would need to be careful with tyre choice. I would put 8.5s on the front of mine, but would expect problems with 9s.
    • post up screen shots of your injector tables
    • Diagnostic flow for a code 21 says check signal at the ECU pins, on a voltmeter of some kind it should read 0.1V at idle, 0.12V cranking, 0.15-0.25V at 2000 rpm. Check each coil such that +1, -3 is infinite or very high resistance, -3, +2 should do the same. (-1, +3), (+3, -2), (+1, -2), and (-1, +2) should all be somewhere between 0 ohms and high resistance. If you trace the path from the coil pin all the way back to the ECU in the diagram the resistance you measure at the coil vs connected to the harness should be pretty much the same.
    • I have an elite 2500 running an adapter harness on an rb25de neo r34. I took the butterfly out and removed all that junk. But I also went Plus+t at the same time. The butterfly thing works in reverse to the boost solenoid on the Gtt if that makes sense
