Edit: was just thinking. Maccas is actually pretty dead tonight and there be no pretty ladies. Maybe we should visit an establishment with pretty ladies for our meets. That will bring you all put. :P
Thanks Guys.
Yeah breaky creek tonight. Come along Miso!
Have been too busy to organise a German club, but we should definitely do one soon! Miso, how about for your birthday tomorrow? :)
Thanks Guys.
I am no good for this week. Marisa is working evenings, so am stuck with the kids at home, and over the weekend, I am doing some evening work to get some spending money for holiday in feb.
Next week is looking good if people are keen for sausage?
Keen.
They're not open Monday, I can't do Tuesday.
I think Scott is trying to organise another dinner for Wednesday... maybe we try to make that at the german club?
Or we go thurs/fri?
Keen.
Or we go thurs/fri?
I approve of this idea :)
Last nights dinner was great. We had a pretty good turn out and a good discussion. Would have been better if Miso was there.. :wub:
Never been to the German Club. What's it like for parking?
No party is complete without a token Eastern European
    • It would be different if the sealant hadn't started to peel up with gaps in the glue about ~6cm and bigger in some areas. I would much prefer not having to do the work take them off the car . However, the filler the owner put in the roof rack mount cavities has shrunk and begun to crack on the rail delete panels. I cant trust that to hold off moisture ingress especially where I live. Not only that but I have faded paint on as well as on either side of these panels, so they would need to come off to give the roofline a proper respray. My goal is to get in there and put a healthy amount of epoxy instead of panel filler/bog and potentially skin with carbon fiber. I have 2 spare rolls from an old motorcycle fairing project from a few years back and I think it'd be a nice touch on a black stag.  I've seen some threads where people replace their roof rack delete with a welded in sheet metal part. But has anyone re-worked the roof rails themselves? It seems like there is a lot of volume there to add in some threads and maybe a keyway for a quick(er) release roof rack system. Not afraid to mill something out if I have to. It would be cool to have a cross bar only setup. That way I can keep the sleek roofline that would accept a couple bolts to gain back that extra utility  3D print some snazzy covers to hide the threaded section to be thorough and keep things covered when not using the rack.
    • Probably not. A workshop grade scantool is my go to for proper Consult interrogation. Any workshop grade tool should do it. Just go to a workshop.
