Hi All,
I have a set of jap rims which are:
F: 17x8" +38
R: 17x9" +38
The rims are surprisingly light; the fronts are slightly lighter than the std gtst rims where as the rears feel about the same.
The fronts sit nice with a 235 no scrubbing. The rears however with a 255 are an issue.
I've spoken to wheelworks who said a manufacturer 'typically' makes a larger cast and then machines down the hub slightly to achieve a given offset.
So.. heaps of meat on mine (looks like a built in spacer) I am looking at machining down the hubs slightly to say a +45 on the rear so I can run a wider rear tyre without scrub and excessive camber.
With the 17x9" +38 there's 14-15mm clearance between the wheel and the hicas tie rod end so plenty of room for a +45.
With a +45 on the rear the front and rear outer edge of the wheel will closer to being equal.
Compared to stock wheels.
17x8 +38 sit out +21mm
17x9 +38 sit out +34mm
Where as 17x9 +45 sit out +27mm.
Should I go more than +45 given there's still another few mm available?
As I am moving the rear wheels in closer to each other will it be less likely to under steer but possibly be a little more over steery?
Edited by TheRogue
I have 38 offsets on back with a 17x9 rim and 255 tyres were too wide even with flaring rear guards a little. Ended up going back to a 235 stetched to fit on rear which no tyre scrub now felt, arse-end little more slippery but meh-got it set up for skids anyhow.
Will be watching to see how you go here mate
I'm hoping a 255, as much + offset I can squeeze, a rolled guard and a little little camber it will just fit. :S
In comparison to the std wheels the nuts screw on to the threads bugger all so fingers crossed there's plenty of meat.
Edited by TheRogue
there are much more effective ways to balance ur cars over/understeer than track changes.
The issue is I am trying to get as much semi-slick tyre under the rear as I can.
I doubt I'll be able to pull safely off any more than 2-3mm.
Either way these rims will do for now; I just don't like the idea of spending 1.5-2k on a set of rims when the car is only used for a little fun at the track and not driven on the street.
just get better tyres.
Not when your already at semi-slick level.
Edited by TheRogue
ok, then id be thinking less about track change, and more about clearance, what clearance issues are there on the inside?
also what gaurd modifications have u done if any?
I was simply curious how changing the rear track to improve clearance would neg affect handling if any. i.e rear track being less or more than front track etc..
Either way I spoke to the Troymeister; I will be fine with a 245 semi slick on the rear and rolled guards.
Semi's are apparently wider that the same sized road tyre so I shouldn't fit a 255 on the 9" rim as it will bulge a little too much.
Troy runs a 9.5" rear with rolled guards and no issues due to ride height.
I'm running 350mm with plenty of clearance so dare so I will be fine also.
Edited by TheRogue
let me put it this way, the added tyre width will more than cancel out any tiny amount of oversteer bias u might have got from the track change. saying that, personally i would have just pulled ur guards out more.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
    • I NEVER think about using a scissor jack unless there is absolutely no other alternative. f**king things are dangerous, annoying and stupid.
