hey guys here is my car and wondering what you think i should do next. ?
carbon fibre bonnett?
lower car?
front bumper of front lip??
heres a pic of the car now. just wondering what your oppinions are, massive storm coming here foxtel out so now im left to entertain myself on here lol
https://www.sau.com.au/forums/topic/261363-what-to-do-next/
Looks nice like that, i would spend my money on brakes or handling or performance.
carbon fibre bonnett? Defect
lower car? scrapes on speedhumps and steep driveways and effects handling
front bumper of front lip?? I smashed my 400R on a driveway(gone back to stock)
Just my 2 cents.
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4480759
i would say do what u want to do.........no one else is driving the car but you so who cares what anyone else thinks?
i started off with exhaust/rims/body kit/ and went from there.........its ur car u do what u feel is best.....
just my 2 cents
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4480782
some nismo clear side indicators? only like 80 bucks but i would spray the outer section white instead of leavin it black like a majority of ppl.
if ya going for styling looks (obviously cause u put it in this section lol) how bout some interior stuff?
how are ur wipers looking? mine looked a lil worse for wear so i sprayed em a matte black. made the front look a lil newer. but i guess only to me as i was the only one that knew i did it. lil things like that i like doing to brighten the car up a bit. anyway im rambling.
just have a close look around ur car and things u might wanna change, write them down and think of a way to do it. even the smallest things changed can make u feel better about the looks of ur car
Edited by SLY-25T
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4481277
yeh i was thinking the exact same thing the other day mate, was looking at my wipers and was thnking that they need a touch up hey. looking a bit worse for wear,. but yeh i guess i would be the only one that would notice it but would look better to me as im everyday noticing it.
clear indicators one step a head of ya hey haha waiting for them to arrive in the mail. yeh thats a good idea about spraying white,will keep that in mind for sure thanks mate.
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4481296
another thing i did (but failed lol) was spray the rubbers around the windows. saned a few bits, taped it all up and sprayed fine. next day car was in sun for a while and all parts i didnt sand properly had gone wet again cause it didnt grab properly :) the B pillar garnish looks alot better though. will have to do a proper job. just used the same stuff as i did the wipers with.
so check over your car for bits that could use a touch up with some paint and give it a go.
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4481382
got nsmo side indicators on now
and also painted the wipers black agaiin, looks way better like brand new again haha.
yeh paint the indicators white around the outside ya reckon. anyone got a pic of this done>? hows it look?
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4498235
cliff, like above, just get an orange LED. looks nice. and with the painting of the outside, id say mask off light area and could find some close matching spray paint. havent seen any done yet so might look a bit diff :D
https://www.sau.com.au/forums/topic/261363-what-to-do-next/#findComment-4499328
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
