mmm... I'm not very convienced till you get a 3inch hard intake pipe made with a high prssure actautor installed.
If that still doesn't work you can trade it back for a SS high flow.
But either way its won't have stock alike response
I understand this Will one of those hard rubber like just jap intake ones do ?? will be doing both above and my retune with injectors and afm with in next month or so.
Is the ss looking like it will make more power on less boost or ?
The Just jap ones don't fit. Have a read at page 55 to 61 there are plenty of info on how to setup a hard intake pipe and where AFM and BOV should go.
Also stock actuator starts to open around 2psi and high pressure actuator starts to open at 15psi. That makes a difference in response as well.
How much is a high pressure actuator for an rb20 turbo? It has been highflowed by gcg but I'd like to give one a shot, see if it can hold 18psi to redline.
the stock rb20 actuators tend to open later than the rb25 ones, around what psi do they start opening in your experience? it holds about 13psi with no controller if that helps.
Edited by Rolls
yea mine holds 14 no controller thats y i didnt thing a highr pressure one would help seeming it peaks at 15.4 and only drops to 14 but guess ill give it a try
Need to run wastegate controller to hold that sort of boost to red line on a RB20det turbo. I haven't had much experience with RB20 actuators as most of what we've got are Rb25 turbos. To test it simply hook on a gauge to a compressor nozzle and see at what psi it starts to move. RB25det once pretty much started to let loose just under 2psi, this is assume there is no back pressure. With back pressure I think it starts to let go as soon as it hits boost.
For people whom orders bolton Rb20det turbos we normally modify ATR28G1 / G2 in .64 rear with T3x flange and 6 bolt patterns (current ATR43SS profile). Those are close to stock alike response and rated to around the 200~230rwkws mark.
I'm working on a drawing of a adjustable actuator at moment, which is basically an reversed drawing of an external gate that you can change spings or load the spring with a pressure plate.
Also ATR43 is now available in 3x different bolt patterns:
Naked suitable for externally gated application, Vband internally gated, and Nissan RB2x OEM. They are priced referring to the amount of time, material and work required.
I've updated prices for them in page 1. The ATR43G3 .82 rear with .70 comp externally gated in T3x flange and 5 bolt T4x dump pattern is $1100 inc GST, oil line is $80.
Stao, how far away from being complete is the SS model for RB20 style.
Im looking for the most ideal turbo for street, which will make the most of my 440cc injectors. So, with a limit of 440 odd hp. Forged engine, gtr crank and rods bring capacity to 2.2. tomei valve springs.
SS is already complete there are 2x profiles one's. Both in .64 rear with .60 comp. Those won't make huge amount of power on RB20dets but good for a responsive street / drift car.
That billet SS with ball bearing I've built is aimed at RB25det.
At moment not. only been told its responsive on road by other customers. But I do have some results of them on CA18det, not sure if that helps.
Those are $1450 inc GST, oil line and high pressure actuator. I have result of it on Rb25det and CA18det only.
The difference between the RB20det profile and Rb25det turbo profile (the billet BB) is the turbine wheel and rear housing.
Reason I don't use the billet wheel as a more responsive alternative please refer to the drawing of the billet wheel in page 69.
Thinner hub = larger blades = greater flow per rotation = greater HP = greater resistance per rotation = greater lag
How ever on a RB25det this tinny amount of lag is not very noticeable, but definitely made more mid range, I don't think it would peek as much power as the ATR43G3s but definitely fast on road with excellent driving ability.
How does your wastegate controller work? Also do I need to send my turbo in or is it something you can just mail out?
I will need to modify your turbine housing for that to work. So you need to send in your turbine housing.
yeah too much hassle, if I was going to do that I would just get a neo 25 turbo and go for an upgrade, cheers anyway.
Can be ft into stock housings, but I would perfer to have our .64 custom nozzled T3x Nissan patterned housing for best out come.
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
    • Nice car! I’m glad folks in the US have gotten past the FnF and are buying real cool cars like the 260RS I was with a bunch of mates in Portland about a year ago and spotted a green Stagea (just a regular 2.5T AWD) parked about 2 blocks away and they were like “a what?” So I made a bet with them for a round of beers and said “ok one of you run down there and tell me if the steering wheel is on the correct side” 5 mins later the American comes trudging back up the hill and goes “he’s right guys. Ok what beer do you want?”
    • Should replace OR drop the tank, give it's good clean. Might be worth replacing that entire fuel level/pump/cradle thing with this: https://frenchysperformancegarage.com/products/fpg-s13-180sx-r32gtst-single-pump-hanger-kit-billet-hat-6-v3-fpg-089?gQT=2
