im planning to service my brake fluids soon and i was looking at motul rbf600 (dot4) brake fluid , is this any good?
i asked a mechanic and he recommended i go for dot 5.1 from the motul range
http://www.motul.com.au/product_line_up/fo...s/others05.html
not sure on what brake pads and such the car currently has as it was recently purchased only
car is a 1993 R32GTR
car would mainly be driving on the street and the odd spirited run
https://www.sau.com.au/forums/topic/261659-brake-fluids/
The fluid we use and recommend is the TRW GP600 brake fluid:
TRW GP600 Dot 4 Racing Brake Fluid
Dry - Min 310
Wet - Min 204
That's about the best out there short of Castrol SRF, or GS610. But significantly cheaper than either of them at $65 for a 1L bottle.
For comparison, some other popular brands:
Motul Dot 5.1
270 dry
185 wet
Castrol Response Super Dot 4
286 dry
184 wet
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4484921
  • 1 month later...
Do a proper flush (out of the lines and abs unit) before putting RBF600 or 5.1 in or it defeats the purpose of putting them in, most likely just have standard DOT4 in there currently.
Flush it well when switching to RBF600 or 5.1 to 4.0 or vice-versa, there are known issues that some brake fluids aren't supposed to be mixed together...
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4585900
The beauty of the TRW GP600 I talked about above (apart from having better performance than the Motul and generally being cheaper anyway) is that it's Dot 4 compatible. So rather than use the expensive stuff to flush it the system out, you can just grab any $7 bottle of Dot4 from the servo, use that to flush the system out, gravity drain, then top up with the good stuff.
The problem with the Motul gear is that generally it's not Dot 4 compatible, and you cannot afford to have any of the old fluid left over...
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4589062
Look, with all due respect Motul RBF 600 and/or 660 IS A DOT 4 FLUID.
It is therefore compatible with other dot 4 fluids.
There is no good reason to use dot 5.1 fluids, Motul or otherwise. The dot 4-600 range perform better, ie have a higher boiling point. The hint is that the 600 (or 660) term in the title is a reference to its boiling point in degrees fahrenheit.
The reference is here:
http://www.motul.com.au/product_line_up/fo...s/others04.html
http://www.motul.com.au/product_line_up/fo...s/others03.html
Fresh fluid (of almost any description) is as good as tired RBF600 fluid. You lose approx 100 degrees celcius out of the boiling point when the fluid is old & wet.
Edited by djr81
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4589078
I have found the Castrol Response Super Dot 4 great for street duties, at around $10 a bottle its cheap and will not boil easily.
Used the same stuff on the track and as a new (ie. slower) track driver its sufficient, but its not very hard to overheat it.
Bought some Penrite Sin which is rated to 310deg Celsius dry boiling temp, its $20 from Repco so I thought I would try it at the next track day instead of the Motul stuff at $25-30 per bottle.
Anyone had experience with the Penrite fluid?
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4589094
I've used the Penrite Sin fluid in my GT-R, found it to be good.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4590305
yeh i saw that down a ABS when i grabbed my pads.
my only concern is that (not knowing) the current fluid in there could be silicone based. This will be the first flush since bought that car earlier in the year.
edit: that current stuff in there atm wont be that great. as the brakes only last 3 laps.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4591148
Thanks, what are you comparing with, i.e have you found it the same as rbf600 etc?
I've used both. I didn't notice any difference.
The sin is cheaper and my local repco has it. win win. Not knocking the motul product as i have used it for a couple of years with no issue, just don't feel like a half hour trip just to get some any more.
As mentioned above, both are dot 4 compatible so none of the issues of switching to a dot 5, just bleed it through.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4592582
Thanks for the reply. As of last night I have the fluid in my car and am using it this weekend :( Will post up how it performed afterwards.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4595340
Update:
Used Penrite Sin with DS2500 pads at Wakefield, fluid did not overheat at all during my 4 sessions.
Previously have only used Castrol Super Dot 4 (silver bottle) at the track, that would hold up ok but would overheat a bit (never overheated it on the street) keeping in mind I flush or bleed it before and after any hard use so its always fresh.
https://www.sau.com.au/forums/topic/261659-brake-fluids/#findComment-4600796
    • The rain is the best time to push to the edge of the grip limit. Water lubrication reduces the consumption of rubber without reducing the fun. I take pleasure in driving around the outside of numpties in Audis, WRXs, BRZs, etc, because they get all worried in the wet. They warm up faster than the engine oil does.
    • When they're dead cold, and in the wet, they're not very fun. RE003 are alright, they do harden very quickly and turn into literally $50 Pace tyres.
    • Yeah, I thought that Reedy's video was quite good because he compared old and new (as in, well used and quite new) AD09s, with what is generally considered to be the fast Yokohama in this category (ie, sporty road/track tyres) and a tyre that people might be able to use to extend the comparo out into the space of more expensive European tyres, being the Cup 2. No-one would ever agree that the Cup 2 is a poor tyre - many would suggest that it is close to the very top of the category. And, for them all to come out so close to each other, and for the cheaper tyre in the test to do so well against the others, in some cases being even faster, shows that (good, non-linglong) tyres are reaching a plateau in terms of how good they can get, and they're all sitting on that same plateau. Anyway, on the AD08R, AD09, RS4 that I've had on the car in recent years, I've never had a problem in the cold and wet. SA gets down to 0-10°C in winter. Not so often, but it was only 4°C when I got in the car this morning. Once the tyres are warm (ie, after about 2km), you can start to lay into them. I've never aquaplaned or suffered serious off-corner understeer or anything like that in the wet, that I would not have expected to happen with a more normal tyre. I had some RE003s, and they were shit in the dry, shit in the wet, shit everywhere. I would rate the RS4 and AD0x as being more trustworthy in the wet, once the rubber is warm. Bridgestone should be ashamed of the RE003.
    • This is why I gave the disclaimer about how I drive in the wet which I feel is pretty important. I have heard people think RS4's are horrible in the rain, but I have this feeling they must be driving (or attempting to drive) anywhere close to the grip limit. I legitimately drive at the speed limit/below speed the limit 100% of the time in the rain. More than happy to just commute along at 50kmh behind a train of cars in 5th gear etc. I do agree with you with regards to the temp and the 'quality' of the tyre Dose. Most UHP tyres aren't even up to temperature on the road anyway, even when going mad initial D canyon carving. It would be interesting to see a not-up-to-temp UHP tyre compared against a mere... normal...HP tyre at these temperatures. I don't think you're (or me in this case) is actually picking up grip with an RS4/AD09 on the road relative to something like a RE003 because the RS4/AD09 is not up to temp and the RE003 is closer to it's optimal operating window.
    • Either the bearing has been installed backwards OR the gearbox input shaft bearing is loosey goosey.   When in doubt, just put in a Samsonas in.
