Thinking about adding variable cam timing to my next GT-R. I know HKS had the V-cam setup, but does anyone know if VCT from an RB25 Neo can be adapted to the RB26 head?
Anyone done it? What's involved?
yes it has been done...ive seen it and been in a car with it...amazing results.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486043
Okay so what about using an RB25 Neo head, on an RB26 block and adapting the individual throttles on the Neo head and a big single or even adapting the twin manifolds to the Neo head? I actually have everything to try this, really has me thinking now. I have a damaged RB26 engine and an extra RB25 Neo head. Just a couple of questions but I will still check it out, will I have to bore the bolt holes in the head to allow for the 26 headstuds? Anything else will I have to mod or it should be fine?
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486498
The only difference is the manifold bolt up pattern but guys like ShaneF can make the adaptor plate for you and has done so with the 26 plenum on 25 head.
You will also have to externally feed oil into the vct like the RB30 guys do. But yeah, that would be the most practical way to do it. Both 25NEO and 26 heads have the same flow potential but the camshafts specs are different.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486522
I am almost done with the indivdual throttle setup on the Neo head, did like GTS4WD and changed the bolt holes and retapped, just need to alter the water neck on the throttle setup to accommodate the VCT solenoid. We'll see how it goes. Yeah may be a little wild but what the heck.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4486548
before you go too far, the combustion chamber in the neo head is smaller than the rb26 head, so that would bump up your CR. I would get the neo head cc'ed first to see how much it will jump up, otherwise sell the neo head and get the normal r33 rb25 head and use that since it has the same cc's as the 26
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4487476
I believe it could be done quite cheaply, using external solenoids and 2 rb25 intake camgears using either head, however it isnt VCT by any stretch of the imaginiation, and tuning two switch on/off points could be time consuming. You may then have to go away and modify the vct mechanism for different angle throw. IMO if you are going to go to all this effort it would be worth investigating a different mechanism say off an evo or mx5, and get true vct, as dirt said the results would be very worthwhile
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4487511
Maybe I can run a thicker headgasket to compensate for the higher CR? Ideally would be to get it CC'ed.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4487918
You would need to run a external oil feed to the head for vct, as the RB26 / RB30 block do not have the oil feed in the block to supply the vct.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4490043
I found this a workshop in Japan that does NVCS Conversion in RB26 while trawling around on gtr.co.uk forums.
http://www.rising-web.jp/03works/03works_frame.html
Look like it was taken off RB25 to me. And from what I've read above comments, it's more than what it is.
What does it need to have one implanted to a 26, looks to be interesting way to gain power and torque.
Would your average Power FC be able to 'control' the NVCS seeing RB26 doesn't have one?
Is it possible to copy the data on NVCS from RB25 and program it into 26 PFC?
Or better get other ecu that already has the software to support variable timing?
Is it worth going all the trouble for?
Cheers
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4491992
I came across this conversion too a while back and it showed some of the machining, head modifications to the oil galleries to hook up an external oil feed etc. They used an inline solenoid to supply oil from the oil pressure sender line to valve, and then used a RB25DET intake cam and gear.
I cant find the pics, but they used a -4 oil fitting screwed into the front of the head and then had drilled galleries to supply the cam gear.
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4492545
Delphi make a cam phasor for belt driven camshafts - as used on the EVO9. You could probably adapt the solenoid from the EVo9 as well. Remember that full cam control is a bitch for most speed density sytems and that total "bump and check" cam phasing is alot of work for not much gain. Your better off with just an on and off cam advance solenoid
https://www.sau.com.au/forums/topic/261777-rb26-vct/#findComment-4494691
    • It says 300ZX, does that make it an Aus delivered car? Funny how back in the day I just couldn't care less about Z32's and these days I am just in love with them. Back when Nissan was into pushing the envelope. 🤣
    • Hi guys, just after some guidance with an R34 sunroof that has stopped working correctly. It still opens and closes perfectly fine, but it no longer tilts/vents up or down. As a result, the rear of the glass now sags a bit as it drops down slightly in order to retract into the roof, but now it can't pop upwards into a flush position. I’ve probed the pins on the back of the switch connector with a multimeter and it seems like both switches (for open/close and tilt/vent) still work correctly. Any ideas on what it could be, or where I should even start in terms of diagnosing? I'm sure someone's had this issue before but I haven't been able to find anything online relating to this specific issue, most of the issues are with the seals leaking or the motor failing entirely. Thanks in advance!
    • Do you have some data like fuel pressure? It's really hard to say if you're still fighting a fuel system issue at this point. Could be something weird like the FPCM dipping out.
    • Yeah in that case, pulling the dent out. Event a very slight dent can create a lot of work filler-wise and there is a strong chance the panel won't be the factory shape when you are done (as the dent will result in a new high point created somewhere, then everything is brought up to that new high point... but the panel shouldn't be that high if that makes sense).  So you've filled and primed the panel and it is flat, why would you go back and remove the primer and add more filler?
    • Something else I have been faffing with while the car was off the road is making the AC work. Assuming the car isn't at a thermal limit the idea of having AC while waiting in line to go on track sounds delightful. I have actually been lugging around the weight of the entire system since 2018 when the RB25NEO went in without it working at all.  The main reason was in the first few events before I got around to re-gassing it the rubber hose that runs under the manifold had the factory heat wrap/sleeve fail resulting in this: ~2 years ago I purchased a complete used R32 AC line set but when I finally went to install it the line i needed was different where the expansion section is I found a local place that was able to replace the rubber section and re-crimp. They also added some modern heat sleeve to the hose Tight fit but fingers crossed this is the last physical piece of the puzzle needed
