Guest RedLineGTR
U can find the wire...if u know where to start...usally the buzzer is either beind the dash where all the speedo etc are housed on rear on the circut board. If not just pull the bottom cover off and have a listen to where its coming from thier are some boxs or items that look like that could be making the noise. The good thing is about the chime is that it beeps also when u leave your lights on and turn off the car, good reminder if u get distracted and u forget. Goodluck
https://www.sau.com.au/forums/topic/26216-door-open-chime/#findComment-555886
another option is to unscrew the little contacter on your door pillar (its like a spring loaded plunger with a rubber boot around it). This has a spring inside it which is the culprit. just open it up by taking off the rubber boot, poping of a few clips (make sure the wires don't fall down the hole when u have the contacter removed) and remove the spring.
chime gone!!!!!
The only down side to this is that the interior light doesn't come on for the drivers door automatically, but its easy enough to flick on manually. you don't have to do this for the passenger door, because for some reason only the drivers door activates a chime.
this way it doesn't effect the chime when you leave your lights on, which to me is important than having your door open.
https://www.sau.com.au/forums/topic/26216-door-open-chime/#findComment-573686
just follow the chime noise and disconect it at the chimer. u dont even have to take the dash apart, just stick ur head at the bottom of the driverside dash and u will find the chimmer straight away if u follow the noise.
https://www.sau.com.au/forums/topic/26216-door-open-chime/#findComment-573908
there is a plug just above the key barrel under the plastic cover. Just unplug it. it is as simple as that. the chimer also tells you when you have left the lights on so dont bother looking for the chimer. i unplugged mine because it is bloody annoying if you want to blast your stereo with the doors open.
https://www.sau.com.au/forums/topic/26216-door-open-chime/#findComment-576408
    • Haha, i kow right? Could have bought so many cars for the same amount of money (or less) but driving Unicorn gives you at least +1mln to style 😅. Like wise man said "life's to short to drink cheap wine and drive boring cars" 😉
    • Newbie here, proud owner of an Autech 260RS. I'm on the hunt for wiring diagrams specific to the 260RS, particularly S1. I've ran my eyes through R33, R34 Diagrams, there are some similarities, however continue to find incorrect wire colours and pins on connectors in the 33,34 diagrams.   I was hoping someone could point me in the right direction? I'd be happy to pay for the originals in Japanese. I can translate them, at least they would be accurate.   Any help please would be greatly appreciated, never heard an RB26DETT before let alone driven one, and I've got a spaghetti monster of goodness to sort out.   Cheers Benny
    • Hey all  im wondering if you can help me please I have put a rb20 box in my r34 gtt as my auto packed up and a friend had a spare box I know it’s not ideal but it will get me up and running for now. we have done the conversation and everything is working great but my Speedo we got a s13 speed sensor but my Speedo reads double now and I bought a speed converter but still not having any luck.  so I thought I’ll reach out and pick your brains  any help would be appreciated please as I wanna drive my car again
    • Drain it. I got official Matic D but you can get whatever is listed as Matic D compatible.
    • Thanks guys,  Yeah I should at least have them dynoed, at least then I know what I've got as a starting point.  The springs on these are hard as rocks. I vaguely remember Russman saying he was going to sell the shocks to me with the rocks fitted, as he was keeping the softer springs for his new setup.  I didn't click at the time but of course that was to let me know the shock/spring wouldn't be matched.  I also remember pricing up new springs around 2014-15, but, house, money etc. it never happened. So that was another reason to have them rebuilt. I have rebuilt the forks on many motorcycles so I think I could handle the seals on these easily enough, but getting the valving right would be a rabbit hole I cbf exploring.  Duncan, interesting to hear RP was tuning these back then. I might give them a call.  In the mean time I have been busy fitting sway bars. The Whiteline rear sway bar I purchased 15 years ago finally got fitted, along with the Whiteline front bar that showed up last week. Just waiting on new links for the front sway bar to finish that off.  And my spare set of advan AVS VS5's should be back from the powder coaters in a Pearl White finish sometime this week, with a set of Hankook RS4's lined up for fitting.  And then I just have all the suspension bushes to do. A comprehensive kit is on the way... Lots to do before the Ararat hill climb. Cheers guys 🍻
