what do you guys use?
mine has let go for some reason :D after about 6 or more months, 20000kms after the rebuild.....
i have 300kw atm on gt2860r5s only 15psi....
no need for a head stud kit?
i do plan on running 20 plus psi
also the car never got hot either?......
will be pulling down soon....
https://www.sau.com.au/forums/topic/262338-head-gaskit-rb26/
JUST MAKE SURE you undo the water and oil line connections / supports (10mm heads) on the block to turbo brackets, and these brackets themselves (12mm heads unless people have changed and lost the bolts and replaced, and they'll be a 13mm head [they are an M8 thread]), and the water and oil line connections / supports on the turbos. Also the actual banjo bolts at the side of the turbos (14 and 17mm heads from memory).
DO NOT FORGET you have a 10mm head bolt IN side at front, behind the cam backing plate. You can either remove cam gears, then the plate and access, or, put a 1/4" drive 6 POINT socket on a magnet and put in the gap on the IN side. Use a 6" 1/4 extension and push it into the socket, then use a ratchet to remove the bolt.
Once bolt is out, lift extension and use magnet to get bolt out. Put magnet back in the hole and pull the extention up to make the socket disconnect. It will hit the magnet and you can pull the magnet out and it's all done.
Once head is ready to come off, get 1 person each side (IN and EX) to lift it. Get a third person to push the turbo oil and water lines out of the way, and disconnect the wiring under the IN plenum you can not access ie cold start (on runner [right next to head, purple plug, near cyl 3]).
You will also have to remove on the EX side, a 14mm head bolt that holds the PS bracket on as the lower 2 bracket bolts are in the block. The top is the head.
IN and EX sides at back corners of head also have 10mm headed bolts.
If all your stuff is factory, you will also need to remove the bolts that hold the bracket to the oil pressure sensor housing.
Undo the water pipe (U shaped) that goes from thermostat housing to hard water piping under IN plenum as that rubber pipe is block connection. The metal job is head connection.
Undo the water lines at the factory water cooling at oil filter.
Remove all other obvious stuff.
If you just want to swap it, and not fully remove and inspect, you can leave all wiring side alone, lift the head, remove gasket, ensure the dowells are put back in place and put new gasket on. NOT ADVISABLE as you really want to clean the surfaces, but if you are time desperate like we were on the way to a race meeting, you can do that.
ok played with it for half the day! no drop in comp 160psi in all 6
no water in any....
plugs are all the same in colour?
its leaking oil into the water some were... first guess would be the oil cooler?
dip stick ect is not milky only a very little bit on the rad cap in in the over flow tank, is down say 500mm of oil in around 1000 to 1500kms
quick trick:
heat engine so radiator pressurises, remove plugs and run a small mirror over each plug hole.... if it fogs you have headgasket issues in that cylinder. If you can get hold of a pressure tester for the rad it makes it easier.
Let me guess:
1) You are running a factory block ie non N1 or RRR GT
2) You run 1.3 bar or more, or have hit / exceeded 1.3 bar a few times in the passed
Your block is cracked between where the head bolt goes into it and the water gallery on the outside of the bore. 99% chance it's the cylinder 5 or 4 one EX side). The crack is usually very small, but grows. If you pull the head off you may not even see it as it starts sub-surface. Skim the block and you'll see it clear as days.
You get trace oil accumulating in your radiator I take it, especially in your overflow? You empty it, it comes back?
The crack is small, but as the oil pressure is greater than the water pressure, it forces the oil through the crack into your water system. Over time, the crack will get bigger, and more will start on other head bolt / gallery places. The harder you drive, the faster it does it.
That is exactly what mine and many others have done. That is why the N1 was made, then the GT block, and why I went to an N1.
Changed to N1 block. No problems at 2 bar.
Other friends (boost ran [bar] / time it lasted before oil in radiator):
1.6 / 2 weeks
1.6 / 6 months
1.5 bar / 8 months
1.5 bar / 1 week
1.5 bar / 2 days
1.6 bar / 2 years and still no problem
The time for the cracks to start is random.
You can either replace with an N1 block, or do a semi-temporary / semi-perminant fix on your factory block.
You do not have problem with oil cooler, I guarantee it.
Pull the motor out.
Edited by pure_methamphetamachine
Pull the motor out and pull the head off (you can EASILY pull it off with everything attached outside of the car). Fully drain block of all oil and water. Make sure head bolt holes and water galleries are 100% dry. Add a thin(ish) smear of loctite stuff (see below) in head bolt hole, and put quite a lot in the water gallery, ensuring you go down as far as you can. You can put like 4mm thick of it in there. Allow to dry, put head back on and put the motor back in.
Do this on EVERY water gallery and head bolt hole, but only in the part of the gallery that is next to the bolt hole.
This half @rsedly emulates an N1 block (all the N1 is is a factory one with more meat between the bolt and gallery).
Loctite: Can not remember the exact stuff by name or number, but it is a 2 part epoxy(?). One tube is yellow, the other is black. Tubes are small too, like little super glue tubes. Mix like araldite and apply. The stuff looks like concrete, as opposed to araldite which is clear like a resin / glue.
    • Power is fed to the ECU when the ignition switch is switched to IGN, at terminal 58. That same wire also connects to the ECCS relay to provide both the coil power and the contact side. When the ECU sees power at 58 it switches 16 to earth, which pulls the ECCS relay on, which feeds main power into the ECU and also to a bunch of other things. None of this is directly involved in the fuel pump - it just has to happen first. The ECU will pull terminal 18 to earth when it wants the fuel pump to run. This allows the fuel pump relay to pull in, which switches power on into the rest of the fuel pump control equipment. The fuel pump control regulator is controlled from terminal 104 on the ECU and is switched high or low depending on whether the ECU thinks the pump needs to run high or low. (I don't know which way around that is, and it really doesn't matter right now). The fuel pump control reg is really just a resistor that controls how the power through the pump goes to earth. Either straight to earth, or via the resistor. This part doesn't matter much to us today. The power to the fuel pump relay comes from one of the switched wires from the IGN switch and fusebox that is not shown off to the left of this page. That power runs the fuel pump relay coil and a number of other engine peripherals. Those peripherals don't really matter. All that matters is that there should be power available at the relay when the key is in the right position. At least - I think it's switched. If it's not switched, then power will be there all the time. Either way, if you don't have power there when you need it (ie, key on) then it won't work. The input-output switching side of the relay gains its power from a line similar (but not the same as) the one that feeds the ECU. SO I presume that is switched. Again, if there is not power there when you need it, then you have to look upstream. And... the upshot of all that? There is no "ground" at the fuel pump relay. Where you say: and say that pin 1 Black/Pink is ground, that is not true. The ECU trigger is AF73, is black/pink, and is the "ground". When the ECU says it is. The Blue/White wire is the "constant" 12V to power the relay's coil. And when I say "constant", I mean it may well only be on when the key is on. As I said above. So, when the ECU says not to be running the pump (which is any time after about 3s of switching on, with no crank signal or engine speed yet), then you should see 12V at both 1 and 2. Because the 12V will be all the way up to the ECU terminal 18, waiting to be switched to ground. When the ECU switches the fuel pump on, then AF73 should go to ~0V, having been switched to ground and the voltage drop now occurring over the relay coil. 3 & 5 are easy. 5 is the other "constant" 12V, that may or may not be constant but will very much want to be there when the key is on. Same as above. 3 goes to the pump. There should never be 12V visible at 3 unless the relay is pulled in. As to where the immobiliser might have been spliced into all this.... It will either have to be on wire AF70 or AF71, whichever is most accessible near the alarm. Given that all those wires run from the engine bay fusebox or the ECU, via the driver's area to the rear of the car, it could really be either. AF70 will be the same colour from the appropriate fuse all the way to the pump. If it has been cut and is dangling, you should be able to see that  in that area somewhere. Same with AF71.   You really should be able to force the pump to run. Just jump 12V onto AF72 and it should go. That will prove that the pump itself is willing to go along with you when you sort out the upstream. You really should be able to force the fuel pump relay on. Just short AF73 to earth when the key is on. If the pump runs, then the relay is fine, and all the power up to both inputs on the relay is fine. If it doesn't run (and given that you checked the relay itself actually works) then one or both of AF70 and AF71 are not bringing power to the game.
    • @PranK can you elaborate further on the Colorlock Dye? The website has a lot of options. I'm sure you've done all the research. I have old genuine leather seats that I have bought various refurbing creams and such, but never a dye. Any info on how long it lasts? Does it wash out? Is it a hassle? What product do I actually need? Am I just buying this kit and following the steps the page advises or something else? https://www.colourlockaustralia.com.au/colourlock-leather-repair-kit-dye.html
    • These going to fit over the big brakes? I'd be reeeeeeeeaaaall hesitant to believe so.
    • The leather work properly stunned me. Again, I am thankful that the leather was in such good condition. I'm not sure what the indent is at the top of the passenger seat. Like somebody was sitting in it with a golf ball between their shoulders. The wheels are more grey than silver now and missing a lot of gloss.  Here's one with nice silver wheels.
    • It's amazing how well the works on the leather seats. Looks mint. Looking forward to see how you go with the wheels. They do suit the car! Gutter rash is easy to fix, but I'm curious about getting the colour done.
