I do have a GT2540, but my friend still has the stock turbo and his motor does the same sound, just not as loud.
Stock gearbox too, only mod is a shortshifter and nismo clutch & flywheel on the drivetrain.
Oh and BTW, I want your rims ahah
Edited by MaxGTST
Hmmm... Interesting...
I was gona say worn out rear diff LOL! But no... Thats more of a "whoo" sound
Might have to ask afew tech heads on here.
LOL! Thats not my car in my signature. I have Volk TE 37's and no rear spoiler.
Yes Nismo LMGT4's are nice and I want them too! Hehe!!
some gearbox set ups can sound like a supercharger......
the Supra JZA80 6-speed Getrag can actually have a spooling whistle...
but the sound you hear in the video, is definately the turbo.......
my guess is the type of low quality video camera used..... ....
video cams can make things sound different than to the real thing
Yeah, it can be hard with those kind of sounds, a mate with an EL XR8 had a gearbox or diff whine sort of like that, my old VN had a REALLY loud supercharger type noise due to the clutch for the aircon being stuck on permanently, and like I said before, turbo gasket with a piece missing started it in the R32 (though when that happened, it was also extremely laggy and the noise seemed to go away on fullboost).
It's not straight cut gears or something modified in the gearbox like that is it?
^^Yeah bozodos thats what I was thinking of as well... Square / Straight Cut Gears in the gearbox...
I remember hearing a VN Commie when I was living in Ballarat and the car looked stock but we heard this "Whine" and a friend said to me it sounded like Square / Straight Cut Gears.
Guys, do some trouble shooting..................
Can't be diff hey, the noise is there while the car is stationary.
Can't be gearbox hey, the noise is there while he's got the clutch in. Certainly sounds like box but he's got that clutch in.
Can't be turbo as it spools up matching engine rpm, just like a supercharger and NOT like a turbo.
So I'm thinking power steer pump
waterpump
Gates timing belt
crook tensioner/idler
Whatever, I wouldn't be thrashing it like that until I'd done some simple checks.
are we talking about the wirring sound on idle? cause everything else sounds normal. if it is the wirring sound my bet is its an aftermarket timing belt.
My car makes the same sound though not as loud even though I used a genuine timing belt for the 100k service. I can really hear it when i blip the accel.
but i agree with grigors diagnosis
I'm talking about the "supercharger" sound the car makes while accelerating. You can hear it clearly at 0:50.
It's not turbo spool, cause you can hear the turbo spooling and it's not this sound I'm talking about.
HAHA yeah i know the one (00)Skyline(00), happens a lot on V6's! Mine was an 8 and different sound to that in particular, you could hear it at idle and the sound increased linearly with the revs. It was also a deeper whine, more like a Gilmer belt drive.
in that video, it sounds like it goes away when the clutch is in and then comes back when it goes out. But then it appears to do that in neutral as well :S
Thinking about it, a mates Passage sounds a tad like this too, it also has a HKS Turbo.
The only cars i've heard with straight cut gears incidentally (all WRX's) kind of make a TIE Fighter like sound, which that is not. I could be wrong though!
Edited by bozodos
ok .. updates .. car does it when clutch is not in, in gears or neutral .. but when I press the clutch, it stops ! Gears, are kinda harder then my old R32 to put in. So.. aftermarket transmission ? Or simply the nismo clutch & flywheel thats does this sound.
It does the same exact sound as this car
Sounds like I have a dogbox on my car .. woot ! I now need to change my changing gear method.
Edited by MaxGTST
Updates .. looks like I can't change gear without using the clutch like a dogbox would. Tried this, full throttle, lno throttle, change gear, full throttle, didn't work at all...
All I know now it that the sound goes off when I press the clutch.Would a changed gear set with syncros do that sound ? Does a straight cut gear exist with syncros ?
Edited by MaxGTST
i think you'd somehow notice a dogbox.... probably around the time you paid $4k more than you were expecting and the previous owner said "that's because it has a dogbox"
    • I just bent the ends of my premo plates. It even went through Regency like that after the engine conversion and the inspector (a great bloke!) just squinted his eyes and said "I didn't see that". Plates, and how they look, are just something that have zero importance to me.
    • Yeah, I would have said the same. It makes me suggest that there are other things wrong, such that the ECU is totally unhappy with the broken sensor. The only other thought here is that maybe it is shorted, which might cause a different issue to the typical "disconnected" sensor.
    • The fact that US/JDM plates actually fit the skyline bumpers properly is a big, big thing for me as they are the correct dimensions. Annoyingly you can't opt for a normal plate (or plate combination) in that size. You have to make up your own one, and at that point you'd still know it wasn't randomly assigned.
    • Well, really, that's any ECU, because it's not so much the ECU that the tuner connects to, but a laptop that's connected to the ECU. You have to have the tuning software installed locally. The "remote" part is essentially just remote desktop (RDP) or VNC type access. Nevertheless, if you're looking to upgrade, then you're immediately in the Haltech/Link territory, both of which can be done by any number of competent tuners here in Oz. But without a dyno, you'll definitely also need a wideband O2 sensor fitted, and you'll probably be relying on "auto" tuning a bit, where you drive it around under various loads and then apply the corrections that the ECU learns (basically applying the fuel trims that the ECU has to do to correct the mixtures). Tuning the timing is a little harder. It can be difficult to trust the old OEM knock sensors on RBs, so it is definitely best to have someone who knows what they're listening for, with knock ears (a piezo microphone connected to the engine, and and little amp and headphones so the listener can hear the angry men with hammers who live in the engine). That is more difficult to do remotely, and I suspect the only sane way is to be quite conservative on timing. But that's OK. You're probably waaaaay better off with conservative timing where you are. What is the fuel situation? 98RON available? Or low grade jungle juice?
    • I see your point, I didn't think too deep into it, was purely focused on the price. There's no bad blood between myself and GSM, they acknowledged the price was cheaper else where and at the time couldn't match it.
