Yes it will - But I remember reading somewhere.....
That the ECU looks for a change in the auto box and increases the AF ratio because it thinks that the box is still sitting in first, thus making the car use a lot of fuel.
I may be wrong about the above statement, but I have used an auto ECU before in an emergency with no ill effects on a 32.
auto's can use manual ecu's. only difference is the timing retard before the gears change - which on a performance car isn't desirable anyway.
my car is auto and ive used a mines chipped ecu off a manual and it ran 100x better than i could imagine.
ran a auto ecu in my r33 for a couple of years after a conversion. would sometimes rev a little (about 1000rpm) on idle and power curve wasnt nice. put a manual ecu in and idle is good now and much smoother power curve. first pic is auto ecu on standard turbo, second is manual ecu on highflow turbo. both using safc2
Edited by Pal
you can use an auto ecu, but why bother? just get the correct ECU
also be sure to note, the auto ECU, will be checking if the car is in PARK from the gearbox
so dont be suprised if it doesnt start, youll have to find which signal wire it uses for this
the reason why I dont think Paul would like the mines ECU is because it didnt cost $1500 and come from Apexi.
I was using a mines ecu for around 9 months and for the price you're paying they are quite good. only down side is you're limited to the mods you can do to your car while using one - and that there is no rev limit. AFR's on mine on an rb25, custom GCG hiflow, cooler, exhaust bla bla bla were between 12.1 to 11.5 on 15psi, any more boost than that and it would get too lean.
    • I've heard the Tomei USA head gaskets are decent if you want to o-ring the heads but otherwise not recommended.
    • The 296mm rotors are the R33 turbo brakes. The 310mm rotors are the R34 turbo brakes. The calipers are nearly the same, but not. They're the same caliper but the R34 caliper has longer legs so that it sits out far enough to go over the rotor. The pads are the same for both. When you say, "I bough tsome EBC"....did you just mean pads? Or rotors? 310mm rotors fit under 17" wheels. There may be some wheels without enough clearance though. I can't fit my fingers between the barrel of my wheel and the "corners" of my R34 calipers, but there is plenty of room behind the spokes. This is on Enkei RPF1. You can fit 324mm rotors inside a 17" wheel, but I'd be willing to bet that it would be close to impossible with the Nissan/Sumitomo caliper (using an adapter, of course), because the Sumitomo caliper is fatter than the Brembo caliper that is supposed to go on the 324mm rotors.
    • Hi. Can someone tell me what brakes(and mainly WHERE) can i buy brakes on R34 GTT? I bought some EBC which SHOULD go on my car(i have GT but it has GTT brakes) but it does not fit, Brakes are "too" small(296mm) Are 310mm be good or? I have 17 inch wheel so no "big boys" but for me driving i just need one that fits and i can get here in EU/Czech.
    • Since winter isn't that harsh anymore in Poland, i will definetely drive it 365 days a year 😉. But if the snow hits i will try it for sure and let U know. Only swap i am planning to do is of course R34 GTR front 😍.
    • Hey. Very valuable information about pitwork, I will pay attention when buying any consumable parts 🙏 As for the carpets - I got a handful of information from nengun, from which it appears that indeed the carpets for the driver's side are OEM. They are not able to show me any pictures due to the long chain of different sales entities but after I place the order, as soon as the goods arrive at the nengun warehouse from which they will send the shipment to me they can send me photos and if my purchase differs from OEM I can immediately return it / cancel the purchase. I think I will give it a try 😉. Of course i'll let you know what's what as soon as i get them P.s. I know the topic is not relevant to the thread, but both nengun and amayama have these SICK 😍 trunk room lamps available. Do you know anyone who ordered them? I need to have one in my car
