The HKS cams I had did not have HKS stamped on them and now my TOMEI cams also don;t have any branding stamped on them.
Were they RB25 cams or RB20 cams? RB25 cams have HKS stamped on them, 100%. Tomei don't have anything so don't compare them.
Concaves on the cams mean standard RB25 cams. Another way to tell is that HKS cams don't have a casting mark down the side of the entire cam, stock ones do.
Here's a stock one, as you can see, it has the concave and the casting mark.
Your paint picture is exactly what stock ones look like. Call him tomorrow and tell him he sent you stock cams, see what he says.
Edited by PM-R33
  • Replies 44
HKS cams that I have seen are ground on their own billets which have HKS cast into them. No HKS RB cams that I have seen have the head bolt scallops in them like a standard cam or a Tomei cam, they are full round between the lobes.
YEs the HKS 264 cams I had were for a rb25 but I was using them in a rb20 before one of them snapped did not have any markings and did have the concave bits for the head studs... they were quite a few years old since I first bought them but so maybe they have changed their design over time?
Ive spoken to slide and he has told me that the early HKS cams were unstamped and did in fact have the concaved parts for the headbolts. Here are some pics, does anyone know how to measure the lift properly?? And what standard lift should be in comparison to these? I have just read that both standard rb25det cams should be 240 degress with 7.8 lift on them... sound normal?? I might run down to the head machining place and ask them to measure mine..
have a look at the Rb30 guide pdf file
in there they have the chart from Tomei that lists cam specs for the standard cams in RB engines
according to that:
R33 RB25DET cams should have 240 degrees duration and 7.8mm lift
...so would appear to be standard lift
Edited by Kranker
To all those that were following my story haha..... I ended up getting his contact details off ebay, and calling his home phone as I hadnt recieved any emails back at all. After explaining the situation he agreed to transfer the money back to me. The money has shown up today, so now I'll send his precious cams back to him. Problem sorted. Thanks for everyones input!
Jamie
Jamie
Did he make a mistake, or was he trying to rip you off?
He told me he bought them second hand under the impression they were the early model, non stamped HKS cams. But never got them fitted to his car so didnt know. Honest bloke or decent liar, who would know ???
    • I strongly recommend anyone playing with cars chasing anything electric, get a basic understanding of using a DMM, and about 12V DC systems. They're REALLY easy, you only need to know V=IR and how to apply it, and you can work out what your readings should be doing. For a simple check on a light bulb, you're looking for 12V at the positive to the light, a near zero resistance to ground, and then for a small resistance across the globe when unplugged. If one of those values isn't right, you won't get what you need. Now if they're all okay,and you then plug the light in, and it still won't work, you now do a voltage check across the globe positive to negative. It should effectively read full battery voltage. If it's not, especially if it's quite low, the age old V=IR starts to be able to be thought about, you now know though, for the current flowing, there isn't much voltage for the given resistance, but the rest of that V has to be dropping somewhere else. So now do a voltage check from ground of globe, to ground of car, then do voltage check from positive of battery, to positive of the light connector. Things like a high resistance in a wire/join will start to "steal" voltage on you. So now step back through which ever wire, until you find the voltage drop is non existent, you're now before what ever is steal your voltage for example.   There's plenty of YouTube videos, but really worth understanding some V=IR, and doing some even theoretical numbers to start to understand it. Then you'll know what the DMM is telling you.
    • Is Jackie home by Friday?
    • Item 10: Tech Edge wideband sensor interface and display. You’ll need to buy a new sensor. $150. Item 11: part of a Willians 5 point harness. $40 Item 12: OS88 gear display. No need for it now, my PPG sequential came with one. $30
    • I took it out, even though I knew I probably don't know what I'm doing other than looking for power signal lol. Lesson learned here I guess, even if it looks normal, worth checking as it only takes a few seconds anyhow. And maybe disconnect the battery, even though really shouldn't have to.
