Why am I hearing that to register a vehicle with an aftermarket FMI, or at least a vehicle that isn't fitted stock with a FMI, you are required to have an engineer's certificate?
The list of PDF files StinkyPoo linked to in the Turbo Timer thread didn't seem to have anything relating to air-intake of the engine, be it Turbos, Superchargers, pod-filters or anything...unless I missed it lol
Anyone got anything solid on this?
https://www.sau.com.au/forums/topic/263430-front-mount-intercoolers/
i was told that you could only have one intake mode.. ie pod filter or intercooler.. not both. if you have more than one you need to get it engineered.
im not saying that the above statement is correct, that is what i was told but the engineer
i got my pod filter engineered because i had to do my coilovers so i thought i might as well do that too. i also got my pedals and boost gauge engineered
That's what I've heard also...So if the only engine mods on a car I'm looking at are FMI and Turbo-back exhaust, it *should* be ok? :wub:
Also, by "engineered" you mean certified, or (re)fitted by an engineer?
Approximately how much that cost?
Thanks
Edited by Trozzle
Yeh, I don't think many cops would pick on you cos it's soo easy to remove a FMIC. Anyways, here is the section of text:
1.1 MODIFICATIONS NOT REQUIRING CERTIFICATION
• Fitting a replacement new, used or reconditioned engine.
• Fitting a manufacturer’s optional engine together with any associated components as supplied by the manufacturer for that same model vehicle.
• Fitting replacement original equipment (or equivalent) engine and exhaust components.
• Fitting replacement original equipment, equivalent or better, components that have no influence on engine performance or emissions. (e.g. higher volume oil pump than original)
In all of the above cases, if the engine is modified, it must be certified under the relevant Approval Code.
1.2 MODIFICATIONS REQUIRING CERTIFICATION UNDER LA APPROVAL CODES
• Fitting equivalent engines (within 20% of original power and engine mass).
• Fitting performance engines.
• Installing a supercharger or turbocharger.
• Modifying engines and engine components.
One reason is that generally to fit a FMIC you need to cut extra holes in your car for pipework.
If you cut holes without reinforcing hole perimeter you have reduced structural integrity of Monocoque chassis..(technically anyway).
Any modifications to car chassis obviously needs to be engineer certified...
There are other regulations that are State dependant...
i used john wilson of AKZ engineering. cost me $550 to engineer my coilovers, pod filter, non standard wheels, boost gauge, aftermarket pedals and turbo timer. it took about a week to get the report back from him andi had no issues getting my car registered. i know some people have had problems with him.. i believe one was naughtyruski
I've dealt with John on my previous car modification pre-skyline.. Not going to say anything here.
I went to Ray Spence to get my engineering done (POD, Wheels, FMIC, Exhaust) for $550. Took 8 hours to get the report in my hands (dropped off in the morning, picked up in the arvo). I think it was Mick that actually put me on to Ray Spence (cheers for that).
On the note of needing an engineer's cert for mods, where I read that, it also stated that interstate certificates are sufficient. Would a Queensland "modplate" count for this? If all mods have been certified and the car has been given this "modplate", I'm wondering if that will count enough.
x2 about not saying anything, I could say a massive amount.
I highly recommend Ray Spence. :cool:
Called Dickson Motor Registry this arvo, the modplate doesn't count for anything unless it's backed up by signed paperwork...that isn't necessarily a problem at this point, at least all the mods are done properly so getting an engineer's certificate from Ray when I've got the car won't be a trouble...only more money >.<
Other than the engineer's certificate, can anyone see any real reason I shouldn't grab this car while I can? http://www.skylinesaustralia.com/forums/R3...ht-t242518.html
Currently asking $14000 (plus $521 to send it to Canberra), and it has a new clutch as stated on the last page.
Thanks :D
    • But first....while I was there, I also swapped across the centre console box for the other style where the AV inputs don't intrude into the (very limited !) space.  Part# was 96926-4GA0A, 284H3-4GA0B, 284H3-4GA0A. (I've already swapped the top 12v socket for a USB bulkhead in this pic, it fit the hole without modification:) Comparison of the 2: Basically to do the console you need to remove the DS and PS side console trim (they slide up and back, held in by clips only) Then remove the back half of the console top trim with the cupholders, pops up, all clips again but be careful at the front as it is pretty flimsy. Then slide the shifter boot down, remove the spring clip, loose it forever somewhere in the car the pull the shift knob off. Remove the tiny plastic piece on DS near "P" and use something thin and long (most screwdrivers won't fit) to push down the interlock and put the shifter down in D for space. There is one screw at the front, then the shifter surround and ashtray lift up. There are 3 or 4 plugs underneath and it is off. Next is the rear cover of the centre console; you need to open the console lid, pop off the trim covering the lid hinge and undo the 2rd screw from the driver's side (the rest all need to come out later so you can do them all now and remove the lid) Then the rear cover unclips (6 clips), start at the top with a trim tool pulling backwards. Once it is off there are 2 screws facing rearwards to remove (need a short phillips for these) and you are done with the rear of the console. There are 4 plugs at the A/V box to unclip Then there are 2 screws at the front of the console, and 2 clips (pull up and back) and the console will come out.
    • So, a bit of a side trip, but one that might be interesting for people with JDM cars and japanese head units. I know @Pac previously posted about a carplay/android auto adapter he installed which used the AUX input, and @V35_Paul put in one of the Tesla style units that replace both screens. The option I went with was a Lsait LLT-YF-VER5.87_2 (https://www.alibaba.com/product-detail/Lsailt-8GB-Android-Multimedia-Interface-for_1601187633672.html). Price was $1,150 for a single unit although they are much cheaper if you are willing to buy 2....$857ea. Make you you get the version 2 not version 1, it is faster and has a better UI - this is the manufacturer listing: http://www.lsailt.com/product/348.html. BTW if you've never bought from Alibaba before, don't be concerned....these guys can't stay in business unless they are responsive, ship fast etc, they were excellent (probably faster shipping than most local places) So, this was my task for a lazy Sat afternoon....looks complex but was all done in a few hours (it probably helps that I had some of it apart before so it was a bit familiar). I also decided to add a HD USB drive recorded at the same time and the unit also supports an aftermarket reverse cam (if you don't want to retain factory) and also AV in and HDMI out It looks much worse than it is, in fact in was genuinely all plug and play (no custom wiring at all). This video was pretty good (skipped a few steps), unfortunately they are an Aussie seller but no longer sell this unit (I guess Carplay/AA adapters are easier to install and much cheaper) https://www.youtube.com/watch?v=T5hJfYOB8Dg
