This is a probably a stupid question but what is the factory weight of a 1995 R33 GTS-T ?
I have googled and stuff and all the answers are inconsistent.
Also, I don't pick up the car till next week so i cant check the rego sticker lol.
So i'm just wondering if any of you guys know.
Sorry if this is posted elsewhere.
Thanks
Edited by zero-R33-
https://www.sau.com.au/forums/topic/264082-r33-weight/
Based on Nissan Skyline JDM Brochure from japanese dealer:
R33 Gts25-t coupe: 1360kg (man), 1380kg (auto), 1390kg (man super LSD model)
R33 Gts25 coupe: 1320kg (man), 1350kg (auto)
R33 Gts25-t sedan: 1380kg (man), 1400kg (auto)
R33 Gts25 sedan: 1360kg (auto only)
R33 Gts RB20 engine sedan (not eligible for import under SEVS): 1270kg (man), 1290kg (auto)
Unfortunately I do not have any brochure of the R33 Gts4 (AWD version), so no idea how heavy, but probably would be close to 1400-1500kg similar to GTR weight less one turbo weight as it's only single turbo instead of tt.
https://www.sau.com.au/forums/topic/264082-r33-weight/#findComment-4516871
    • The oil pressure sensor for logging, does it happen to be the one that was slowly breaking out of the oil block? If it is,I would be ignoring your logs. You had a leak at the sensor which would mean it can't read accurately. It's a small hole at the sensor, and you had a small hole just before it, meaning you could have lost significant pressure reading.   As for brakes, if it's just fluid getting old, you won't necessarily end up with air sitting in the line. Bleed a shit tonne of fluid through so you effectively replace it and go again. Oh and, pay close attention to the pressure gauge while on track!
    • I don't know it is due to that. It could just be due to load on track being more than a dyno. But it would be nice to rule it out. We're talking a fraction of a second of pulling ~1 degree of timing. So it's not a lot, but I'd rather it be 0... Thicker oil isn't really a "bandaid" if it's oil that is going to run at 125C, is it? It will be thicker at 100 and thus at 125, where the 40 weight may not be as thick as one may like for that use. I already have a big pump that has been ported. They (They in this instance being the guy that built my heads) port them so they flow more at lower RPM but have a bypass spring that I believe is ~70psi. I have seen 70psi of oil pressure up top in the past, before I knew I had this leak. I have a 25 row oil cooler that takes up all the space in the driver side guard. It is interesting that GM themselves recommend 0-30 oil for their Vette applications. Unless you take it to the track where the official word is to put 20-50w oil in there, then take that back out after your track day is done and return to 0-30.
    • Nice, looks great. Nice work getting the factory parts also. Never know when you'll need them.
    • Thanks @jtha7 I will have a look around tomorrow but it is a prick of a spot. These are some photos i tried taking
    • I take it that the knock retard is from bearings tapping a little tune? Thicker oil is a fragile bandaid. You need a much bigger oil cooler and probably the bigger pump being discussed.
