Galston to Gosford Cruise 8:30pm 17/10/2003 (Formerly Midnight cruise - Friday 17th)
  • Replies 161
alrighty then..................
if ure coming up to gossie i suggest terrigal they have food places open reasonably l8 plus a 24hr bakery.......... oh and there is a decent amount of carpark
plus if its a fri nite the cops wont be out as much cause the big nite up here is thursday
the pizza thing is easy cos as soon as i get tired i can piss off home. but this will be a better drive, i'll just cruise until i feel a need to make tracks. no excuses, I'm there :rofl:
History has shown that Friday night & Pizza at the beach on Terrigal has ended with cops :(
Depending on the number of people is Pizza at Gossie Station do-able ? Seems to attract much less cop attention than the carpark at Terrigal ...
I might have to be in for this, I have never come out on a skyline cruise before and would love to get some piccies. I will head hom from work then back to thornleigh(I work just off pennant hills road. City view Rd)
catch you guys then
mark
I've been on the last 2 Terrigal runs and never even seen a cop let had trouble from cops (and we were parked 100m from a cop shop).
catch you guys then
mark
Thats like 5mins from me!! How come i've never seen your car in the area? :(
Come cruising everyoneee!!! its gonna be fun! and a chance for us all to catch up :)
Originally posted by Moanie
Come on tosh!  do your thing! :) start a 'who is coming' list :(
and how long do you guys reckon the whole cruise will be?!
it's your cruise Mona.... I'm sure you can manage to do it
okies...please check the first post as i've updated it with a list of whose coming and the maybes....
Let me know if i need to make changes....or if you're intested in coming along...
We will be leaving Thornleigh Maccacs at 8:30 (i promise i won't be late!!) so try not to be late...i don't have alot of your numbers so not sure how it'll work if you are running late and still want to come along....
I will definatly be there. I haven't been out with you guys so can't miss this one.
I don't drive out of work during the day often. walk to the nearest shops and stuff. our carpark is F#$ed, takes 10 mins to get out of it cause you get parked in all the time.
Well i haven't been on one of your cruises before, blitz keeps telling me that i should come along, but i will need to call blitz to see where you are at around midnight, but will love to join the next cruise for sure.
Originally posted by Nismodified
CB radio to tell everyone how far behind i am during the cruise (wont be in use for long as its only got a 3km range)
Don't laugh that happened to me last time. Whats even funnier is within 3km of leaving Thornleigh I was already out of range going thru Galston :D
Taking a wrong turn and not having good brakes doesn't help haha :) I didn't catchup until about 20mins later.
/me removes his speed limiter :bahaha:
    • Have a look at that (shitty) pic I posted. You can see AN -4 braided line coming to a -4 to 1/8 BSPT adapter, into a 1/8 BSPT T piece. The Haltech pressure sender is screwed into the long arm of the sender and factory sender (pre your pic) into the T side. You can also see the cable tie holding the whole contraption in place. Is it better than mounting the sender direct to your engine fitting......yes because it removes that vibration as the engine revs out 50 times every lap and that factory sender is pretty big. Is it necessary for you......well I've got no idea, I just don't like something important failing twice so over-engineer it to the moon!
    • Yup. You can get creative and make a sort of "bracket" with cable ties. Put 2 around the sender with a third passing underneath them strapped down against the sender. Then that third one is able to be passed through some hole at right angles to the orientation of the sender. Or some variation on the theme. Yes.... ummm, with caveats? I mean, the sender is BSP and you would likely have AN stuff on the hose, so yes, there would be the adapter you mention. But the block end will either be 1/8 NPT if that thread is still OK in there, or you can drill and tap it out to 1/4 BSP or NPT and use appropriate adapter there. As it stands, your mention of 1/8 BSPT male seems... wrong for the 1/8 NPT female it has to go into. The hose will be better, because even with the bush, the mass of the sender will be "hanging" off a hard threaded connection and will add some stress/strain to that. It might fail in the future. The hose eliminates almost all such risk - but adds in several more threaded connections to leak from! It really should be tapered, but it looks very long in that photo with no taper visible. If you have it in hand you should be able to see if it tapered or not. There technically is no possibility of a mechanical seal with a parallel male in a parallel female, so it is hard to believe that it is parallel male, but weirder things have happened. Maybe it's meant to seat on some surface when screwed in on the original installation? Anyway, at that thread size, parallel in parallel, with tape and goop, will seal just fine.
