Hey guys..
Whats a decent turbo to suite rb20 that can provide around 230-240 at the wheels with minimal lag?
I currently have a GT3071r but find its a bit laggy for daily driving.. doesnt come on till 3500rpm.. im looking for something that comes on around 3000 if not earlier and still pulls through the whole gear range..
anyone got an suggestions or ideas? and if you have one has something they wana get rid of.. let me no. I'm also interested in swapping mine for something a bit smaller.. suites rb20/25 manifold direct bolt on.
also.. is there even much difference between HKS and garrett? or just a massive price difference!! lol..
cheers
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/
Paul i have a standard R33 turbo and willing to do a swap plus $$ your way for that GT3071R mate....you could try the R33 turbo and see if that makes a difference....mine on 12 psi made 211 on a RB25 though....i have heard of my mates r32 making 190-200 with a few supporting mods and a R33 or R34 turbo....and apparently its very responsive
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/#findComment-4518803
Im currenttly building my own turbocharger, should be the sort of thing you'd be after.
ie a garrett GT2871R instead of your gt3071r
Ive got a garrett gt2871r chra core, pulled it down and she's cactus.
purchased a new centre ball bearing cartridge, purchasing a garrett exhaust turbine shaft with 60-1 front compressor wheel and full rebuild kit
using my hiflowed and ported rb25 compressor and exhaust housings
all up $500 cost plus a rebalance fee at ATS or MTQ, less sale of current highflow chra
;) ba boom ! now theres how to save a grand on a turbo :(
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/#findComment-4518806
mate i got a 25/30 making 17psi at 4300 and that is one of the more responsive turbos u can get for a 20 that makes awesome power
u gotta go for a 25 if ya want power
if not go high mount external and u'll get full boost at 4000 give or take
+1 2530!
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/#findComment-4518905
There is a whole SAU forum dedicated to this sort of question with hundreds of different answer and opinions. Did you even do a search for "RB20 turbo" or something similar?
http://www.skylinesaustralia.com/forums/Fo...erforma-f8.html
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/#findComment-4518907
are you joking? u wanna make MORE power and REDUCE lag...
hahahahhahahahahahahhahahaha......
your rb20 is RESPONSIVE compared to alot of others..
save your $$$ and buy a 25 and strap the 3071r on it!
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/#findComment-4519378
like i said i want to sacrafice the power i can make with the gt30 and start making less power but more lower down.. is there any mods u can do that will minimize the lag with the gt30?
Edited by jonohr32
https://www.sau.com.au/forums/topic/264247-turbos-for-rb20/#findComment-4519382
    • What an awesome idea to fit the facelift Lamborghini Diablo headlights. They are a perfect fit!
    • An update regarding the registration with the DVLA I sent off the paperwork the day after I collected the car from the port, two weeks later it was all returned with a letter explaining they have rejected the application. This was because the cheque was £20 short for the road tax (I used a price list I found online). Nevermind it is what it is, it was sent back to them the following day with a new cheque. Fast forward another 2 weeks or so, I called them for an update to be told it had been rejected. Yesterday (16th September) I received the documents back along with another letter, this time it was because I didn't put an X in one box on the V750 (personalised number plate certificate), which declared that I had the rights to the personalised number plate. Why this wasn't mentioned in the first rejection letter, I don't know, but it could have saved this headache. The documents were sent back today, so fingers crossed third times a charm and it'll FINALLY be registered on the road just in time for the bad weather (woohoo!) To cheer myself up I lowered the front 25mm, was sick of seeing it sit like a monster truck. No idea how much clearance I'll have getting on and off the driveway, I'll worry about that when I can actually drive it
    • You're going to miss not worrying about rust in the strut towers like the Skyline shitboxes out there
    • A few little updates that weren't filmed due to not taking long to do or not interesting enough for their own video. My new K&N Air Filter arrived, I went with an RU-4180 which matched the dimensions of the universal cone filter the car originally had.  The battery had gone flat, while that was charging I tidied up the spaghetti wiring at the bulk head and down the sides of the engine Next job was to swap the stereo The Kenwood harness had the female ISO plugs cut off and the male ISO plugs cut off the adaptor loom and joined with bullet connectors. I ordered in a repair loom through work and re-did it all. New Kenwood unit installed (Android Auto, DAB, Bluetooth, Reverse Camera) The bonnet/hood gas struts have been poor since collecting the car. I couldn't find any suitable replacements locally so took a chance on a pair from AliExpress.  The originals don't use a retaining clip to secure the cup onto the ball fixture, would explain why I struggled for 10-15mins trying to pry off the cups. The ball fixtures unscrew using a 12mm spanner, new ones are the same size. Sadly no photo of them fitted, you're not missing much lol The dished Momo steering wheel got replaced with my Momo Tuner, turns out I ordered counter sunk bolts for the horn trim ring (like they normally are for the steering wheel) instead of allen cap (flat seat)  A terrible photo of a Quaife style gear shift knob I've had stashed in my tool box for many years after purchasing the incorrect thread size (I can see a pattern emerging with ordering incorrect parts...) Also threw in a cup holder and a (empty) Boss Coffee can, because why not
    • GT-R clearly the better choice! The 300 is certainly not insaly fast but has a decent amount of poke. Does a nice little drift around the corners with a decent amount of throttle. It's VERY predictable in a slide too.  Feels so progressive! People probably presume there's a 25 year old driving it based on my behaviour this week! 🤣
