  • Replies 58
I know that they are not ARX's, but my stock RS wheels are 17x7 with 215/55/17 tyres
I have Nismo LMX5's
18x7.5+25
with 235x40x18 tyres
My mates RS has 18x8 Work rims (don't know the offset) with 245/45/18 tyres.
He also has 5mm spacers.
Being an ARX, I am sure that you could easily fit some 19x9's in there.
I very nearly bought a set of Work CCR 20x9's for my RS... Those damn wheel arches can almost swallow anything!
Oh, and NO WAY would I call an ARX an off-roader. Prob more a "soft-roader".
Edited by iamhe77
hm.. im looking at some meshy type rims on 19"
I have 19" Lenso with 245/45/19....tight fit though once lowered.
P.S. Red line is going this weekend as per the second pic.
Edited by Jetwreck
Never thought I would say it, but I actually like them better with the red line.
Don't get me wrong, I like a car that has been murdered out, but I think that the red breaks it up a bit.
mmm suits the gold ARX nicely.
..... I also believe that I spot a Nismo rear spoiler... Looks great!
I've been thinking I might have to hunt one of those rear spoilers down, definately adds to the sporty appearance of the M35.
Then again I could go crazy and buy a whole Nismo kit, I'll wait until I'm doing a complete respray :D
    • That's probably OK. That's a face to face compression joint between two surfaces with the clamping load provided by those bolts. So.... it's unlikely that the bolts will end up feeling that load in shear, unless the clamping surfaces are not large enough, bolts not got enough tension on them, etc etc to prevent the two faces from moving wrt each other. Which... I would hope the designers have considered, seeing as it's probably one of the most important things the upright has to do apart from resist collapsing in its own right. But yes, it would definitely be worth asking them what their safety factor on that part of the design was. I tend to think that the casting, being a casting, is not necessarily the strongest bit of material in the world. It's about an inch square, and when you think about the loads that are being put into it, you have to wonder what safety factor the Nissan boys (and every other OEM engineer who has designed all the millions of other uprights that look essentially the same) used to account for defective casting, aging, severe impacts on the wheel, etc etc.
    • Those bolts would be orders of magnitude stronger that cast aluminium though.  And its mainly clamping force, not shear they are dealing with?
    • Except all that twisting force that is breaking a cast piece, appears to be going through 4 bolts in the picture Johnny posted of the BryPar one...
    • The smart approach is to use the gearbox loom from the manual car. Makes it a lot easier - just plugs into the switches on the box and plugs into the main loom up near the fusebox. Then you only need to deal with bypassing the inhibit switch. The other approach requires you to use the wiring diagram to identify those wires by colour and location, perhaps even indulging in a little multimeter action to trace them end to end to make sure, and then.... you will have the answers you need. The R34 wiring diagram is available on-line (no, I do not have a link to it myself - I would have to do a search if I wasn't able to go to the copy I have at home).
    • Hi, i’m converted my r34 4dr auto to manual but need help with gearbox wiring. There are bunch of wires no idea which one for speedo drive, neutral, reverse can anyone help me. IMG_6860.mov
