I've been thinking I might have to hunt one of those rear spoilers down, definately adds to the sporty appearance of the M35.
Then again I could go crazy and buy a whole Nismo kit, I'll wait until I'm doing a complete respray :D
Yep, I hear ya!
ahh, if only I had the spare 3-4k lying around for the complete Nismo kit...
Oh well, what can ya do!?!
  • Replies 58
looks like a dolphin grill
Wow, that is another sweet kit, anyone know the rough price and availability of this Dolphin Aeroform kit?
Thanks Jet :P
P.S. googlied :D
http://www.freeway-dolphin.co.jp/aeroform/...a_new_m35st.htm
http://www.freeway-dolphin.co.jp/aeroform/...tagea_m35st.htm
P.P.S. Has Japanese pricing on it, maybe I need to google for a currency convertor :)
Edited by Bis-e Bee
After some calculations the basic kit is
Freeway Dolphin Aeroform
Stagea (White kit in pictures)
Front Bumper Spoiler 75,600 yen ($1044.26 AUD)
Side Step 63,000 yen ($870.221 AUD)
Rear Bumper Spoiler 71,400 yen ($986.627)
Front Grille 31,500 yen ($435.276 AUD)
Eye-line Garnish 15,750 yen ($217.621)
Rear Wing 57,750 yen ($797.944)
Total 315,000 yen ($4351.949)
You should think though they could sharpen the pencil on a complete fitout and give a better price.
I like the kit though, worth keeping a note of.
P.S maybe they would throw a set of this in in 19" http://www.freeway-dolphin.co.jp/wheel/kamp/kamp.htm
Edited by Bis-e Bee
Yeah.
I was looking at the Kenstyle EIK kit in mid-late 2007.
Got hold of the supplier (in California) and got a price... problem was it "had" to be shipped from Japan to the US, then on to me in Melbourne.
Cost was around $6.5k... before it was painted!!
Anyway, this is what I WAS looking at (same colour as my car too!)
Yeah.
Nice kit, but I really want to go with something with a matching roof spoiler :P I just think it really adds to the look of the car. At this point in time my first serious consideration would be given to the Nismo kit, followed by the Dolphin Aerosport.
But as stated previously, I probably wouldn't consider it tell I was looking at a full respray, I think however I would get it resprayed the same red as it is at the moment, the colour has grown on me.
bought 20x8 advanti vienna's with +35 offset
wat tyesr should i put on
245/40? or 45?
I would say 245/45.
I have 245/40's but my speedo is calibrated for 215/55/17.
ARX come standard with 18's, although I do not know the standard sizing.
Check near the inside sil of the driver's door, it will tell you the standard size, then punch it into THIS site to make sure your speedo is not too far out.
EDIT: plus the ride on 45's is much more comfortable than on 40's.
Edited by iamhe77
Hi guys, I have a few questions;
1: I know r34 GTR wheels go on nm35's with the wheelarch flares, (ARX, AXIS) but has anyone tried on an RS?
2: How much wider are the flares than standard bodywork?
3: Does anyone know the offset of the ARX 18x8" rims?
I know the GTR's are 18x9" but I'm unsure of offset. Looks like a squeeze, but might work if not too low...
Cheers, Dale
    • Totally equivalent. Stock often goes from the comp cover because that's where the actuator is also installed and the factory needs 2" of hose to make the connection - and it comes as a pre-assembled unit. They totally have a boost reference from somewhere between the turbo and the throttle(s). Oh, jeez. Just do it in M12 then. We don't actually care that much. I would expect any such AN converter fitting to rely on an o-ring or some other seal onto a flat surface under the flange of the hex**, because bolt threads are no intended to provide a pressure seal. unlike..... pipe threads. **which also requires a suitably flat and smooth surface on the turbo's boss to provide the seal.
    • I also used NP   That’s were it’s seems to be the best place to fit it? All schematic shows also that it’s should be referenced from the turbo housing. But idk, I do see high hp cars without any connection or anything to their turbos, so I really don’t know how they connect their things
    • I do have loctite 243 and 246 and a few more models. I could drill it now in place and make new threads for m12 and order an4 - m12 coupling and fit that to the turbo. Run a braided hose to the EBC which I could get a an4 to 1/8npt
    • So M12 and sealant should be fine?    NPT ” because that’s what I had and what I could get atm.
    • Wouldn’t touch par if they gave it to me. You need to ask how much power you’re looking to make and then add about 50% to it because that’s what you’ll end up making  The factory box says no more at about 350kw or so, the upgraded synchro boxes won’t handle much over 500kw for long and at that point you’re looking at an auto or dog engagement manual,  once you’ve gone dog engagement you may as well go sequential, they cost a little bit more but it’s worth it  also while you’re at it you should upgrade the transfer case with 10 friction plates
