GTR has no chance. not sure why nissan/nismo didnt go into the GT2 class
Really did you see the times posted around the Paul Richard circuit in testing?? I know its only testing but it does look like the GTR will at least be competitive ;)
1. 2010 GT1 Nismo / Gigawave Nissan R35 GT-R - 2:05.447
2. 2010 GT1 Matech Ford GT - 2.05.948
3. 2010 GT1 VDS Ford GT - 2.07.401
Don't read too much into the pre-season testing times for these cars.
I have a mate that works for the Jet Alliance GT1 team (Aston DB9R's) and I remember him telling me that the governing body uses the testing times to try and even out the field by giving extra ballast etc to the fast teams. So as a consequence they used to do all of their pre-season testing on 5 year old slicks that were half useless to make themselves look slow.
Actually I just remembered they did it by determining the size of the restrictors they all had to run.
  • 3 weeks later...
  • 1 month later...
Dates;
03/05/09 Silverstone
16/05/09 Adria
21/06/09 Oschersleben
26/07/09 Spa-Francorchamps
09/08/09 Bucharest
20/09/09 Algarve
04/10/09 Paul Ricard HTTT
25/10/09 Zolder
Alright - I'm off to Spa to watch this one :thumbsup: Although I'm going with Brisby so I'll have listen to his Corvette rubbish all weekend I'm sure.
Best bit is for the 2 days after the race we'll actually get to play on the track :D
well fck you carnts then. lol.
  • 5 months later...
yeah not surprised - they are a whole other level up from the cars around.
and speaking of levels, the r35 is running it gt2 not outright, right? It is much more road car than the top level cars
The GTR & Ford GT were running to 2010 GT1 rules, getting a head start on the competition.
Have been working with the Ford GT GT1 cars for next year, all new Aero package.
Sponsorship all set, should be a good year for the ford's running some great drivers
Nissan has some updates over last years but is pretty similar in styling.
I love the toys you get to play with. the proper GT cars are the some of the most seriously engineered cars around
Pitty I'm stuck here in adelaide and they are in Switzerland :P
was invited over to the launch at Paul Riccard But i think the new mortgage is more important at the moment.
know anyone that wants a GT3 spec Ford GT here? chuck us a PM if you do!!
    • If you take the top half of the intake off you can unbolt the flap off the shaft and leave the shaft in there blocking the hole. Then you can remove the little vacuum canister off from under the manifold and get a spare vacuum line to run to the ECU. I can take some photos of it later. Probably best to get the vacuum source to the ECU sorted first though. Mine all worked mint with the base map from the GTT an I've pretty much let the closed loop sort the fueling and took 1 degree out of the whole timing map.
    • This IS something you also have to configure in Haltech (or at least I did in the past when going from onboard-to-ECU map sensor and an external MAP sensor in haltech land).
    • I'm hoping it's something as simple as the ECU is looking for an external MAP sensor, but he is trying to use the onboard MAP sensor.
    • You won't need to do that if your happy to learn to tune it yourself. You 100% do not need to do that. It is not part of the learning process. It's not like driving on track and 'finding the limit by stepping over the limit'. You should not ever accidently blow up an engine and you should have setup the ECU's engine protection to save you from yourself while you are learning anyway. Plenty of us have tuned their own cars, myself included. We still come here for advice/guidance/new ideas etc.  What have you been doing so far to learn how to tune?
    • Put the ECU's MAP line in your mouth. Blow as hard as you can. You should be able to see about 10 kPa, maybe 15 kPa positive pressure. Suck on it. You should be able to generate a decent vacuum to about the same level also. Note that this is only ~2 psi either way. If the MAP is reading -5 psi all the time, ignition on, engine running or not, driving around or not, then it is severely f**ked. Also, you SHOULD NOT BE DRIVING IT WITHOUT A LOAD REFERENCE. You will break the engine. Badly.
