Circuit track day at Oran Park! (26/10/2003)
Hi All,
I have been in contact with Jeff, the manager from Oran Park raceway, in regards to several events coming up. They want to run a full on drift competition towards the end of the year and are holding a few pratice days prior to that on their south circuit.
SAU, the WRX club and the NSW Road Racing Club are their "guinea cops" on these pratice days. It would be good to get some good numbers!
From one of Jeffs emails;
L2s licence holders may practice in road registered cars, provided they comply with Schedule A & B in the CAMS manual. Basically the cars need to be OK for a Supersprint
- so you need to hold a CAMS L2S license for these events.
EDIT; this particular event will be circuit ONLY - no drifting! Drift events will be later in the year.
Cost; $80 per car.
Thanks Guys,
Christian.
Originally posted by PranK
Re: Drift practice day at Oran Park! (26/10/2003)
? :confused:
So it's NOT a Drift practise day?
Good news about the L2S requirement, normally it's a C3 or higher. :uh-huh:
Originally posted by B-Man
But the  best drift corner has a  dirty great big wall on the RHS. he he:)
Nah - down the back would be fun !
I was wondering how WRXs drift ??
:) oops, I thought it was north circuit.
Cancel that, south circuit is crap for drift, not just the last turn but the left hander over the back of the track also has a wall very close...not for me
I might go, where do I get details and apply? Timing?
I went out to a super sprint on Sat just gone, run by North Shore Sporting Car Club. Did a 48.36 only a zed with standard turbo's but she goes. Sorry if I am gloating.jpeczed1.jpg
    • Not sure the US can import anything other than the C34 Stagea's, but if you can and you need to to tow, DO NOT under any circumstances get an M35 Stagea. If it is just as a family car and your country/state allows it, absolutely and definitely get an M35 (3.5L if possible as it is effectively a 350Z) over a C34.
    • Punch your VIN (nm35-xxxxxx) into Amayama.com You can see everything there quite easily.
    • Thanks for that, I'll check it all out. I can always do the brakes last anyway if its a problem.  The 16's are super cool, if they do fit I'll cruise around with them for a bit.
    • Well, that's kinda the point. The calipers might interfere with the inside of the barrels 16" rims are only about 14" inside the barrels, which is ~350mm, and 334mm rotors only leave about 8mm outboard for the caliper before you get to 350, And.... that;s not gunna be enough. If the rims have a larger ID than that, you might sneak it in. I'd be putting a measuring stick inside the wheel and eyeballing the extra required for the caliper outboard of the rotor before committing to bolting it all on.
    • OK, so again it has been a bit of a break but it was around researching what had been done since I didn't have access to Neil's records and not everything is obvious without pulling stuff apart. Happily the guy who assembled the engine had kept reasonable records, so we now know the final spec is: Bottom end: Standard block and crank Ross 86.5mm forgies, 9:1 compression Spool forged rods Standard main bolts Oil pump Spool billet gears in standard housing Aeroflow extended and baffled sump Head Freshly rebuilt standard head with new 80lb valve springs Mild porting/port match Head oil feed restrictor VCT disabled Tighe 805C reground cams (255 duration, 8.93 lift)  Adjustable cam gears on inlet/exhaust Standard head bolts, gasket not confirmed but assumed MLS External 555cc Nismo injectors Z32 AFM Bosch 023 Intank fuel pump Garret 2871 (factory housings and manifold) Hypertune FFP plenum with standard throttle   Time to book in a trip to Unigroup
