brisby, my car is so far from 22s its not funny. id love to know where 4 seconds is hiding... i can account for 2 secs max with the current set up. i will be back to give it a red hot go. Today was meant to be about shaking the car down and giving Mick some seat time so effectively i had one session with 2 clear flying laps.. i also had a whole session of datsuns and rexs spinning in front of me..
im much more keen to get back to PI to smash out a time there... corners ftw!
Well done Dean with the 1.22. nearly had a RWD on top of the list for a change.
  • Replies 269
Posted Images
Dean Taylor did a 1:22.0!!!!!!
Thats an awesome effort.
BBGTR was looking very strong out of the last corner, and boy does she let out some flames.....
Thats awesome! Good work Dean, i was starting to think that i was insane for thinking more of the later model rwd boys should be up in the 22 bracket! The Datsun boys are flying too these days :)
Some Footage
Session 2 - 1.21.9 lap -
Session 3 - Red Flagged :w00t:
Session 4 -
Session 5 - Short - Memory card was full - didn't empty it from the last session
Session 6 - Didn't bother with camera - did fastest lap of the day 1.21.5 :P
Hey guys thanks for the kind words
Car was good- suspension upgrade helped.. I cant believe a didnt play with it or change it after owning the car for 5 years!!
definately more time in it currently- i think another second.. getting close to teens!!
Dean
I had a great time yesterday.
Was SOOO thankfull that the rain held off all day .
sorry to see Chris' car had engine dramas, hope its nothing to major.
Highlight was the run where I was chasing mick in ryans car. SO nearly had him at turn one ( he locked up big time lol)
Just struggled on 3 or 4 tight corners to get lateral grip. Was very entertaining though.
Had a major moment and dandy kink. pushing a lil hard only me and Wayne- Rchoo will know how much of a moment it was lol.
BRIS best for the day was 1.28.5. Not sure how to get to 22s , 24s is reachable with tyres and a few other lil adjustments,
Here is a pic my lil bro took just before lunch.
Cheers Guys see you all at Deca
With the same turbo setup and brake setup your car can definitely do a 1:22, i dont know what you have with regards to suspension but my old Bilsteins were not anything great so.... you need to bin the 18s and go lighter 17s with decent rubber :(
I am mega pumped and catn wait to get back behind the wheel later this year. LOL i bet my car will be slower with all the new mods :(
Brian track days require 2 balls... and i hadn't been off yet so thought it was about time. I had a great day, dipped into the 1:26s for the first time, was trying to go quicker than the Sil80 coz that always makes for a bit of fun but little mistakes cost me. And i have less power so i guess it was expected there.
As for the 1:22's there is a big difference at sandown between a car like the brisby mobile that has 260rwkw and the suspect 220rwkws sil80. I'd say thats a good number of seconds right there.
Twas a great day with no rain coming in the end, started to be able to pick off a few of the faster wrx's in my group too which is always fun.
Bad luck to Chris stacey too, hope it turns out ok.
what ever happened to the days when group 1 was full of rediculously quick gtr's and getting into a track day meant you had to enter as soon as the forms came out!?
what are the hsccv days like? i'm addicted now
I think you might want to upgrade your brake pads and fluid before going to the next one,
those brakes were overheating in 2 flying laps
Combination of the GFC, Targa and softness on the account of the rest..... :D
Yeh, Sandown is all about grunt. But my 23.1 was with 230-235rwkws as i was only running 15psi. At PI i used 18-19psi to do the 52 flat. So i did a 25.2 at Sandown with my old ICE tune and the 10cm housing which was a laggier 222rwkws. I ran Dutton / Sandown with 260 and went slower at 1:24.2 or something :D Not posting to fly flags, simply pointing out that i think Ryan needs to throw his car on the dyno and get the tune looked at, i suspect its simply not making the power it should.
As others have said, power rules at Vic tracks, Sandown being the most obvious example, lol probably the reason i like it... :P
    • Well GTSBoy, prepare yourself further. I did a track day with 1/2 a day prep on Friday, inpromptu. The good news is that I got home, and didn't drive the car into a wall. Everything seemed mostly okay. The car was even a little faster than it was last time. I also got to get some good datalog data too. I also noticed a tiny bit of knock which was (luckily?) recorded. All I know is the knock sensors got recalibrated.... and are notorious for false knock. So I don't know if they are too sensitive, not sensitive enough... or some other third option. But I reduced timing anyway. It wasn't every pull through the session either. Think along the lines of -1 degree of timing for say, three instances while at the top of 4th in a 20 minute all-hot-lap session. Unfortunately at the end of session 2... I noticed a little oil. I borrowed some jack stands and a jack and took a look under there, but as is often the case, messing around with it kinda half cleaned it up, it was not conclusive where it was coming from. I decided to give it another go and see how it was. The amount of oil was maybe one/two small drops. I did another 20 minute session and car went well, and I was just starting to get into it and not be terrified of driving on track. I pulled over and checked in the pits and saw this: This is where I called it, packed up and went home as I live ~20 min from the track with a VERY VERY CLOSE EYE on Oil Pressure on the way home. The volume wasn't much but you never know. I checked it today when I had my own space/tools/time to find out what was going on, wanted to clean it up, run the car and see if any of the fittings from around the oil filter were causing it. I have like.. 5 fittings there, so I suspected one was (hopefully?) the culprit. It became immediately apparent as soon as I looked around more closely. 795d266d-a034-4b8c-89c9-d83860f5d00a.mp4       This is the R34 GTT oil sender connected via an adapter to an oil cooler block I have installed which runs AN lines to my cooler (and back). There's also an oil temp sensor on top.  Just after that video, I attempted to unthread the sensor to see if it's loose/worn and it disintegrated in my hand. So yes. I am glad I noticed that oil because it would appear that complete and utter catastrophic engine failure was about 1 second of engine runtime away. I did try to drill the fitting out, and only succeeded in drilling the middle hole much larger and now there's a... smooth hole in there with what looks like a damn sleeve still incredibly tight in there. Not really sure how to proceed from here. My options: 1) Find someone who can remove the stuck fitting, and use a steel adapter so it won't fatigue? (Female BSPT for the R34 sender to 1/8NPT male - HARD to find). IF it isn't possible to remove - Buy a new block ($320) and have someone tap a new 1/8NPT in the top of it ($????) and hope the steel adapter works better. 2) Buy a new block and give up on the OEM pressure sender for the dash entirely, and use the supplied 1/8 NPT for the oil temp sender. Having the oil pressure read 0 in the dash with the warning lamp will give me a lot of anxiety driving around. I do have the actual GM sensor/sender working, but it needs OBD2 as a gauge. If I'm datalogging I don't actually have a readout of what the gauge is currently displaying. 3) Other? Find a new location for the OEM sender? Though I don't know of anywhere that will work. I also don't know if a steel adapter is actually functionally smart here. It's clearly leveraged itself through vibration of the motor and snapped in half. This doesn't seem like a setup a smart person would replicate given the weight of the OEM sender. Still pretty happy being lucky for once and seeing this at the absolute last moment before bye bye motor in a big way, even if an adapter is apparently 6 weeks+ delivery and I have no way to free the current stuck/potentially destroyed threads in the current oil block.
