  • Replies 50
Just the fact you would use SAU and NS in the one sentence denotes a life time of bitch slaps, every time you leave your house there should be someone there to bitch slap you, every time you think you need a drink BANG bitch slap, every time you think you should not have linked NS and SAU BANG bitch slap.
this is going into the best quote thread :blush:
Ye i know its a sad day when it gets to that level, and the fact that the cops can get away with it.
But as usual, its the minority that have ruined it for the majority over the past 5-8 years. Same as mothers groups are screwing this country's law/policy making
- 120dB exhausts
- 40mm off the ground
- Racing each other all day night
- 20 inch wheels on cars that come factory with 15's etc etc
and do you know their response to that when i talked to some of the people in TMU.
because were 'altering the factory status that their perfectly built to and with their body aerodynamics (with wheels) to suit it best bla bla. changing its standards makes it more worse and dangerous. as stupid as it sounds even though we all know that in some cases bigger rims with bigger tyres are alot more useful with grip/handling etc etc.
its a bit sad to see how much they keep changing the laws the last few years.
ive heard so many stories with cops with them doing dodgy shit and getting away with it.. the whole system is just s#!t to me
If you haven't done anything wrong and your not challenging the system, you have accepted the problem, in fact your effectively agreeing you have done something wrong when you pay the fine.
Which is disappointing, start challenging if your getting done on legal mods, if your mods are illegal then you probably need to get rid of them :blush:
any more info on the actual police beating someone up part ??
its getting old listening to the same 3-4 people giving there same teary eyed life stories each time.... and dont say I dont have to read it, I was looking for the beating part :blush:
Edited by justin911
Rear number plate cannot be seen from a 45degree angle - defected.
Beat it on the fact that its totally legal, sup reg to the law the officer quoted, said exactly what i thought, if the car was factory like that then its OK
Driving in a manner dangerous
Driving 140 in a 80 zone
Reckless endangerment of life
-Beat all them as the cop was talking out his ass to put it plainly, his "key witness" didn't show to court twice. Furthermore the "key" witness didn't actually see anything by his own statement. Also the officer was not in full attire (no badges, labels, lapels, hats)... just blue shirt/pants. And he was apparently directing traffic while watching me do all the above. Which to add too it, was on the GOR around a blind corner. This was a old koot Lorne cop, been in the force 40 years and was probably due for retirement after he got the above so horridly wrong it wasnt funny.
Driving 110 in a 60 zone
-Had this down graded to 80 in a 60 zone. Officer had no gun, and only 300 meters with which to estimate my speed over. Mathematically the cops were wrong. Sad part is police are "recognised" estimators of speed, so very good lawyer required
There are others, I cant think of them at present. But challenge EVERYTHING. I take no shit, simple as that.
Sounds like you have had some success in contesting matters in court Ash, do you recommend a particular lawyer/firm?
Wish I could find the business card of this lawyer. He is a car nut himself and specialises in defending your defect in court, and he advertises in import car mags. Will post up details when I do.
    • Put a fuel pressure gauge on it. Replace the turbos. Probably completely separate issues.
    • What copper washer do you guys use on the bleeder bolts? The existing one I have I had no idea where to find it in a local store, I did buy some online but that are only 1mm thick whereas my old one is 2mm+ thick and when I put the new washer out and squeeze the top radiator hose I can hear a bit of air but not with the old one. Does this matter? The new one doesn't leak, but the inner diameter is a bit loose whereas the old one threads on the bolt.
    • Howdy all, after being out a few weeks ago on a spirited drive in my GTR I have 2 issues that oddly have appeared at the same time. Whilst accelerating quickly through the gears all of a sudden i’ve lost power at the top of third gear (below redline around 6000rpm) for no obvious reason.    From that point onwards the car has been running rich on idle, won’t really rev under load without a ton of black smoke and the odd backfire, and dying as a pull up to a set of lights unless I keep the revs up around 1500rpm. In addition when shutting down the car that same night (I was 10 minutes from home) I noticed one of the turbos was significantly noisy on wind down when shutting off the engine. After letting the car cool down overnight it starts up fine, although once it gets to temp the revs start to creep up and down, the exhaust is darker than it should be and it also sounds like it’s running rich (fat note) I’ve put a new set of plugs in it - no change, the old plugs all seemed OK with two of them being somewhat richer/fueled up than the other 3 with 1 being borderline. I’ve smoked tested the intake system via the front of the Turbos, found a split vacuum hose going to the factory boost gauge sender, which I have since replaced.  Also found another leak on the gasket coming off the rear turbo outlet, have also replaced this. After fixing both of these leaks - still have the running rich issue. I’ve also tried another pair of AFM’s - no change here After pulling off the front turbo intake pipes, there is obvious shaft play in the front turbo, which now hisses loudly on light revvs although I can’t see why this would make the car run funny even under idle. I’m curious to know why it’s running rich before I potentially replace/rebuild turbos. The car is completely stock <50,000kms  other than an exhaust. Oil and coolant are all clear. I haven’t bothered with coil packs as it looks like they won’t be the issue due to condition of the plugs. Any help appreciated as I cry myself to sleep!
    • No probs at all. I used to love trying to dig up obscure info for those in need where possible going back 20+ years on SAU.  I did have another look and couldn't come up with any closer match. I'm leaning towards those skirts in your first pic are custom fitments, cut down/extended or from another car entirely and modded to fit an R34 sedan. I would've thought someone in Japan had them and taken a photo at some stage over the last 2 decades but there's nothing. Someone out there must know surely.
