Did anyone see there was a black r33 series 1 on crime stoppers. The driver got in an arguement in a petrol station in balcatta, drove away, came back with an axe and started swinging at another guys head, the guy put him arms up to protect his face and nearly had his hand sliced off.
The skyline had five spoke rims (maybe stockers) and was an older r33.
I love to see skylines on TV, but not like this.
Greg.
https://www.sau.com.au/forums/topic/26580-a-skyline-on-crimestoppers/
Originally posted by PSIKO
sounds like normal petrol customer behaviour to me, thinking it's the stations fault for setting the price
they reckon 5c will make big difference to their $10 fill-up, and THEN buy 2L of water for $5!?
lol hahahahaha i know exactly how you feel! i work for Shell after hearing complaints about petrol prices all day i usually just take the piss
"how come the petrol is so expensive?"
"well im going away next weekend and needed a bit more spending money"
or
"i woke up in a bad mood this morning and thought every1 should go f*ck themselves 2day!"
aarrrrrrghhh its so frustrating its not like i chose to make it that price :P
    • There are black hose clamps as well if you care. Plazmaman for example sells some: https://plazmaman.com/product/black-hose-clamps-premium-quality-stainless-breeze/
    • After using a protractor for an actually accurate assessment of what is required,  and by NOT using my uncalibrated eyeball I worked out I need a 25° silicone bend from the TB ro the MAF, but, my choice was either a 30° or a 23° (23° is a weird spec), so I grabbed the 23° one from Raceworks I also grabbed 1mtr of 3" straight from Just Jap, I needed 350mm, but they only had 300mm, or 1mtr lengths....meh Also ordered a 1/2" hose bulkhead fitting from fleabay, this has a smoothish mushroom looking head (they are designed for below the water line of boats) that will fit inside the bend, the hose bit and threaded bit looks to long, but nothing that a hacksaw cannot fix if required, the hose will then just get jamed on the threaded bit up to the retaining nut Fingers crossed and the unsightly amount of hose clamps will be reduced down to 4 once all the parts arrive
    • Oil change does not trigger code 21. Code 21 is for coilpacks primary side connection. You can try to clear the code with a battery disconnect, hold down the brake pedal to drain capacitors through the brake lights with the ignition on for 10-15 seconds before you reconnect the battery. I have seen R35 coil conversion permanently cause this code with no ill effects so it might be the resistance it wants to see isn't quite right on one or more coilpacks. Could be inside the ECU, could be the harness, could be a coil. You can test it all if you want or just ignore until the car actually starts misfiring.
    • I forgot you have a Nistune ECU. Use Nistune to do all the tests I mentioned instead of faffing with 30+ year old electrical connectors. You can read MAF volts off that too, there are reference values in the service manual to tell you roughly what it should be in different conditions.
