Hey,
I have some issues with my rb25det in r32. We tried to tune it but to no avail because the voltage keeps dropping. I tried two new alternators and niether one changed anything. I have check continuity from -ve and +ve from battery to alternator and i have checked voltage at alternator and battery and its the same both sides, and as the car runs the voltage keeps dropping.
I am really stuck!!! If someone can offer some ideas I would be very appreciative.
Thanks, Leon
https://www.sau.com.au/forums/topic/266144-rb25-voltage-problems/
What sort of voltage are you talking?
I have always seen a slight voltage drop with mine; its nothing the volt vs ign, volt vs inj correction can't take care of.
As its a different motor my bet is the chassis/motor being poorly earthed.
Edited by TheRogue
its definately got good earth. There is 2 from chassis to battery and 2 from chassis to block, all on clean metal.
Not sure what alternator it is, its a 90amp mistu one. Can anyone tell me whether or not r32/r33 have internal or external volt regulators?
okay so they have internal regulators...
Now just wondering, ive been told the battery light should turn on in the dash when i key on for the alternator to be working properly... the light only comes on after driving and battery goes flat///
any ideas anyone?
  • 3 years later...
Hey,
Thanks, Leon
I currently have the exact same problem. But mine is still a rb20 in r32 with voltage dropping under engine load.
Anybody got ideas?
Have you tried a new battery? This cold weather can make them fail...
I would guess the power through the dash light to the alternator may not be wired up correctly or open circuit? I seem to remember it need to be connected to charge correctly? I would be taking it to an auto elec.
The charge light MUST come on on the dash when you turn ignition on. It is the small current flowing through that circuit (and the alternator) that excites the alternator and lets it actually charge. If the light does not come on, then you either have a wiring problem, or the globe is blown (assuming no alternator fault).
It is that simple.
Edited by GTSBoy
    • http://calfinn.com.au/product/1500kg-standard-trolley-jack-cj-2t-c/1500kg-standard-trolley-jack-cj-2t-c   I have this and fits under a S3 33 GTR with no issues. Purchased in 2009 and not one issue. It was $950 back then. Not cheap but something so important isn’t worth cheaping out on.
    • Just trying to get my head around this. At 5psi of boost, you turn on your wmi pump, and then you're using a 3000cc injector, to allow flow upto the actual engine, where you have your 6x200cc injectors and a 500cc injector. If the above is correct, what advantage are you obtaining by having the 3000cc injector blocking flow, is this just incase a line breaks between that injector and the motor you can stop flow immediately? Or are the 6x200cc and 500cc less injectors and just spray nozzle?
    • Welcome! New member myself, but I had an R33 back in 2002. Best advice I could give, based on my experience: if you're running the factory turbo, be very conservative with boost. I made the mistake of just fiddling around with the boost controller and cranking the boost for fun, and the end result was my intake pipes popping off frequently from the constant deluge of oil that was being blown into the recirc by the stressed-out turbo, which itself was siphoning oil from the engine and farting it out both sides of its centre bearing (or something to that effect). If I could do it all again, I would have gotten a new turbo and had a tune dialled in professionally and then just left it alone! Funny you mention the metal shavings in the gearbox, as I had the same thing - the probe plug (magnetic drain plug, essentially) would come out caked with shavings. At least it was doing its job. Not sure if that's just sacrificial wear and part of the deal, or if my gearbox was shagged, but I wasn't abusing it. Enjoy the R33 - they're a dying breed, and if they weren't $35k+ on CarSales in Queensland, I might have picked up one of those again, instead of the 370GT I own now (though I'm loving the 370GT, that big 3.7L V6 just hits different).
    • Howdy folks. I owned an R33 back in 2002, which was thoroughly beyond my capacity (financially speaking) to maintain/insure, so we parted ways in 2004. Fast forward 21 years (to literally yesterday, in fact) and I'm now the proud owner of a 2007 V36 370GT. I'm happily surprised by how much power the VQ37VHR makes, compared to the RB25DET, considering the latter is turbocharged. I had planned to add a turbo at some point but I'm on the fence about whether I'll even need it (though I do love the sudden onset of extra torque). Any other 370GT owners around the traps, I'd love to hear about your experiences with this car (good and bad).
    • Perhaps the answer is... more jacks!* *proper jacks must be used.
