Sweet, I got your SMS with the new number too.
It was you, right? There is one other Ian (Xmetal) and an Iain (zei20l) here in NSW, and that's just the Stagea drivers (or ex-drivers).
Yep, its me alright and I missed out on the cruise tonight too. DAMN IT........ :P Finished work early for a change and all.
Will have to see if I can make the next one, usually too wrecked from driving the truck all over syd.
  • Replies 356
Well i guess now i am an official owner,
wont get my car till monday and still not sure whats wrong with it when i do get it! hopefully it will be pretty easy to work out :P
Congrats!
Welcome to the ever expanding M35 arm of the family.
Hope the damage is not too bad.
Edited by iamhe77
    • Oh, also, forgot to add these photos I believe.
    • Thought i'd update on this. I was able to get in contact with Craig Lieberman and later on Darryl Alison (owner of Kaizo Industries). Darryl was able to help me verify that my car was in fact one of theirs and is helping me find more info on mine !
