  • Replies 41
Well my lil sister has kept her end of the bargain (finish VCE with enter 90+ and now in uni 1 year to go till graduation :) ). So as good loving father and brothers we bought her a car hence new automotive baby in the family. But there are a few conditions/requirements she has to meet before i'll let her take it out on her own :) .
can i join your family also???
https://www.sau.com.au/forums/topic/266414-new-baby/page/2/#findComment-4548222
ahh man im not the type of person who will study for 3 hours straight
then again
im one of those people who lack motivation.. kinda like " you will never get into your course!"
me: mehh.. ill just take over dads business
so i think its highly unlikley ill get my 83 percent enter
though im doing allright in methods, blitzing English and biology as well as visual communication
https://www.sau.com.au/forums/topic/266414-new-baby/page/2/#findComment-4549328
then again
haha lucky boy with ur dads business, but better to make your name than inherit it.
what course u aiming to get into?
https://www.sau.com.au/forums/topic/266414-new-baby/page/2/#findComment-4550305
you mean you and your dad bought a car and used your sister as an excuse right?
not exactly, why leave money in ur account to collect interest when u can spend it right? lets help the economy :O .
but really she has earnd it, only problem is she's lacking in driving experience. maybe have to send her to a Driver Dynamics day???
when she got her P's she was only taught how to pass :( .
https://www.sau.com.au/forums/topic/266414-new-baby/page/2/#findComment-4550764
well either way. i have earnt my name
i helped dad set up the business.. so business wise. im alot more mature then my mates and all the customers know me as sam jnr lol..
i want to get into automotive engineering at RMIT
dropped chemistry allready
dropping physics at the end of the year because theres no point doing a subject im gona fail
acing english, biology, visual comunication and doing okay in methods
all i want is an S for methods in yr 12 and an average of B to A+ in my sacks which im getting except for maths where i scrape thru lol..
i denno hopefuly i can get in
edit
oh GD2ILA wana adopt me? :/
Edited by GTR-boy
https://www.sau.com.au/forums/topic/266414-new-baby/page/2/#findComment-4553696
    • Its also worth mentioning that 30 years after it left the factory and god knows how many missed oil changes since, there is every possibility that one or more lifters are ticking because they are sticky/gummed up. To resolve that you need to pull the cams then pull each lifter, disassemble, clean, reassemble, soak in oil and re-install, and they should come up good as new.
    • What air filter are you running? Is it a panel filter in the stock air box, or a pod filter? Is the air filter the type that is oiled?   If you unplug the IACV, what rpm does the engine idle at?
    • Reading through the engine service manual their advice is do a cylinder balance test. Unplug one injector at a time and see if the idle drops a consistent RPM. You can also do this using a Consult cable which is easier. They also call for unplugging the power transistor, then with the engine off and the fuel rail unhooked from the manifold verifying that you have good fuel flow (even injection, no dripping/leaks, etc) when you twist the CAS by hand. Also verify the spark by pulling the spark plugs and allowing the plugs to ground and turning the CAS by hand. I would also start doing the sensor checks and idle valve checks in service manual. Make sure the MAF tests reasonably, the intake air regulator is sane, etc. You may have to get new spark plugs.
    • This sounds very old of me, however since buying the Tiguan shit box, my view on shit boxes have changed.
    • I've looked up the parts number (41011AL501). It's around $700 OEM. Usually our Infiniti G35 here in Canada have interchangeable parts with my Stagea but the parts number are not the same. I have looked around and it seems the JDM 2005 V35 Skyline (which is the same as our G35) has the same caliper but I cannot confirm. And I can't find a repair kit. The inner brake pads drags on the rotor, seems to be rusty piston. Thanks for the info by the way
