ahh damn!!! ok ill find more shit you guys dont have in your povo packs :blink:
Jealousy is a curse, I'm thinking you won't find a *great* deal of difference between the RS / X :wub:
Our cars are just more sporty! Where as yours is a crossdresser, oops I mean crossover ;)
Edited by Bis-e Bee
  • Replies 52
Only phone camera (i.e. el crappo quality), gives you an idea what wez talkin' 'bout tho! :)
F***'n Mo******ker! B*******! F***'n son of a two bit, well used a*** w**** ! F***! F***!! F***!! F***!!
*ahem*
...and where, per say would my lovely Stagea stamped door F***'N TRIM BITS BE??? :wub:
ummm, yeah guys. They look good. :blink:
I must admit that it sucks when you find out everyone else's Stagea has something that yours doesn't!
It's like ripped off majorly!
If I come across any during my gogglie's searchs etc I'll let you know iamhe77
is that a rare thing??
mines got that
mine didnt even have the stickers off it when i got my car
*chin sinks into chest*
* face sinks into hands*
Guess it has nothing to do with the "Aero selection" as they say.
I would say that it may have been something Nissan introduced in 2002+, but my mates M35 doesn't have them either!
Mine is a 2001 model, given the marks and wear etc. I'd say they were there from factory.
:blink:
Maybe they were an option, though FAST didn't say anything??
Anyone fitted an ARX LSD to an RS or RX? Straight forward?
My RS has an lsd... :blink:
Might be more common than previously thought. Seems to be varying spec levels across the different models, i.e. leather, 6 stack BOSE, nav, etc.
No reason why this couldn't apply to diff, esp. if there is no ratio difference.
Edited by Daleo
Might be more common than previously thought. Seems to be varying spec levels across the different models,b i.e leather, 6 stack BOSE, nav, etc.
What's the easiest way to check incase mine does have it?!
Besides planting it in the wet lol
Beat me to that question.
I have planted it in the wet (determined to get it sideways).
U-turn (or U-bolt for all the NSW peeps) at about 15kph, then planted it 3/4 of the way through.
Rear end slipped out a little (turned the wheel to between 10 & 11 o'clock to correct) and fronts immediately gripped and I was at 100kph in no time.
How would an LSD or lack of LSD change this scenario?
Edited by iamhe77
Jack one rear wheel off the ground, with handbrake off, rotate wheel. If wheel turns, no lsd. Friction from lsd will prevent you from rotating wheel. Good luck, hopefully more free lsd's will be found!
also dont have an overdrive button.
If you want a boost gauge, you need to fit your own but it is very easy.
The 5th gear is the overdrive, if you put it in triptronic mode it will start in 4. Then you need to change to 5 if you want a taller gear.
Cheers
Andy
2003 RS FOUR here, with the guages in the centre (except my boost guage is broken - barely works - 99% of the time it sits on full vacuum even under heavy throttle when i can hear the turbo spooling).
no "stagea" on door sills, no leather, no heated seats, no rear air-con vents... you guys suck lol :D
but hey...i do have guages...even if only 2 of them are working (but the volts one isn't very interesting and i dont drive fast enough for the front torque one to move much either).
no overdrive button - but then s2 stageas dont have one either. no real need when you have tiptronic.
    • This looks great! Awesome to have the 5 speed with an LSD in this. The Recaro's look like SR2's or SR3's. It's a shame they've been retrimmed as they would have looked sweet in their original colours. I think I'd want my agent to be a little more up front and informative too. I've never imported but I reckon it would make me a little nervous, so the more info the better.
    • Thanks for doing that Duncan! Makes you a good person in my books. We don't get kangaroos or wombats here. But we have bats and it's similar. AFAIK it's often the mums with a baby attached that get hit because they drop lower when starting from a tree. If you hit an animal, check on it. https://www.ifaw.org/au/resources/wildlife-rescue-app An app to get the closest wildlife rescue contact.
    • My dream is also to have a proper hoist, but I don't think it will ever happen. My quickjack is probably as close as I'll ever get, it really is very good though.
    • Yeah we keep on in the dailies, it is pretty poor how many animals get hit and the driver leaves without checking....have saved a couple of little ones over the years. Bit of a gruesome job though, pouches generally need to be cut open because they are so tight and often the joey doesn't realise mum is gone so they are still locked onto the teat. I checked the modules in front of the DS wheel where an oil cooler should go.... There is the radar unit - that can go for race use) One of the 2 HX water pumps, the silver cylinder. That needs to be kept but might be able to be relocated But the bad news, the big computer mounted vertically in front of the wheel (blocking any potential air exit) is the electric steering computer. That is required until/unless i do a hydraulic steering conversion, and in CAD based modern car design it is not like I can just pop a big unit like that somewhere else (plus the loom would be too short anywhere else too). So, the passenger side is OK to clear out (just use a smaller washer reservoir, potentially elsewhere), but the DS no beuno
    • Well, all the best with the new camry It was interesting to hear about the UK process, it is generally a lot more streamlined here with a shipping agent looking after all the import side (noting the exact final price can still be a surprise.....) and I've used a few different brokers on the japan (or US) side, and never had any trouble with any of them....luck of the draw I guess. You mentioned you didn't get the auction sheet (understandable since you bought it from a dealer, not auction), but I always try and get hold of that because they are pretty thorough. I've imported 2x R grade vehicles over the years and both were fine, repairs in Japan are pretty thorough compared to here in Oz.
