Yo, Ive got a '95 R33 GTR here in sydney for wrecking as it unfortunately can't be complied
It's silver and has approx 44,000 ks, series 1. I can post almost everything from the car, or pickup is available. Will post some more pics in the next few days
R33 GTR rb26dett motor, complete engine with approx 44,000 ks. Compression test came up perfect- ~165-170psi each cylinder
Includes turbos, wiring loom, ECU, manifolds, injectors - $5000 ono
17x9" Axia? (jap wheels) +18 offset wheels with Dunlop Lemans LM702 tyres, front 2 have about 50% left, rears are pretty much on the tread markers
$1000 ono
5sp Manual GTR box, good nick.. includes slave cylinder, shifter - $1000
HKS 3" catback exhaust - $200
Exterior stuff
R33 GTR front bar - paint is cracked + grazed a bit on drivers side. includes blinkers - $400
R33 GTR grille - $250
R33 GTR front guards, includes GT badges and blinkers - $500 pair
S1 headlights - $400
R33 GTR front reo bar - $150
radiator support/ nose cut - $300
R33 GTR sideskirts + rear pods - $200
R33 GTR bootlid + spoiler. Paint is a bit faded on the pass side near windscreen, includes GTR badge - $400
Rear 'Skyline' garnish - $50
Guard liner plastics, both sides - $100
Brake vent plastics - $100 pair
Tail lights - $50 each
Side mirrors - $50 each
Passenger door minis door trim - $150
Drivers door minus door trim/switches - $200
post-35556-1240393680_thumb.jpg post-35556-1240393701_thumb.jpg post-35556-1240393200_thumb.jpg
post-35556-1240393715_thumb.jpg post-35556-1240393732_thumb.jpg post-35556-1240393766_thumb.jpg
Engine bay stuff
R33 GTR afms - $200/pair
R33 GTR airbox & snorkel - $150
Engine Mounts - $100/pair
GTR BM-57 brake master cylinder - $120
Stock dump pipes + front pipe - $150
Stock BOV pair - $120
Stock BOV recirc piping - $100
Stock FMIC piping - $100
Stock Calsonic FMIC, some damage to the bottom though it still holds pressure fine - $50
R33 GTR A/c condenser - $150
R33 GTR radiator- $100
Thermo fan - $80
GTR Washer bottle - $30
fuse box lid - $20
radiator overflow bottle - $20
Charcoal canister - $30
Bonnet lining - $50
post-35556-1240393555_thumb.jpg post-35556-1240393670_thumb.jpg post-35556-1240393834_thumb.jpg
Suspension/brakes/driveline
Front & rear Brembo calipers + pads - $1750 full set ONO
Stock suspension, full set - $250
GTR front + rear swaybars - $150
GTR rear diff - $500
standard swaybars - $80 each
Front upper control arms - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
17" space saver tyre - $50
Interior stuff:
R33 GTR front + rear seats + door trim, complete set - $1600 ono, will probably seperate
GTR instrument cluster, carbon fibre look cover ~44,000ks - $250
GTR 3 gauge centre DIN cluster, nismo white face cluster & carbon fibre look cover - torque, oil temp and boost - $175
post-35556-1240393321_thumb.jpg post-35556-1240393332_thumb.jpg post-35556-1240393294_thumb.jpg
Steering wheel with S1 airbag (some wear on the wheel but airbag is great) - $150
Complete Boot interior - $100
Drivers door window switch (suit s1/s1.5 R33) - $80
Drivers window switch surround (s1), bit worn - $30
Drivers door window motor - $80
Passenger door window motor - $50
Large dash surround plastic with clock etc (s1) - $70
Gear stick surround (s1) - $50
Ashtray - $25
Glovebox - $40
climate control - $40
Seatbelts, full set - $80 (will seperate)
If you're after any random bits and pieces that arent listed, shoot me a PM- got the whole car available
Cheers!
https://www.sau.com.au/forums/topic/266621-r33-gtr-95-wrecking-in-sydney/
  • Replies 140
front guards on hold till next week! climate control sold pending payment
pm sent
Replied
pm sent
replied
pm sent
replied
how much for the front Strut Brace?
oops, forgot to list it - $80 each for the strut braces
pm replied!
pm sent
replied!
Post the brake ducts to Melb?
yep no worries, PM sent
Pm Sent
replied!
il take the head lights and grill , also the airbox and afm please pm me
done, PM sent
PM Sent!
replied!
how much for just the front gtr seats? any damage ie. rips and so on
Chasing $1000 for the front 2 seats+rails. No rips or anything, few tiny tiny marks but theyre negligible imo
pm sent
replied!
    • Yeh I think i'll message an old contact i had for ages that manages his own tyre shop now.. n tell him what i want n work with him before ordering..  Got this 17x9 +30 Driftteks on 245/45/17 PSR Drag Radials on the rear.. They fit well - for your reference in future - Rear guards  have been lipped in & minimal to non flaring of the rear Gaurds.
    • If only it were that easy! I also needed to remove seats, shocks, brake calipers, send my car through a fence, and use measuring and ended up guessing because I didn't remove seats, shocks and brake calipers. It can be hard sometimes Can be a little more complex than 'just measure' if you want to truly measure the entire wheel through all of it's suspension travel. But if you aren't going for every last mm then yeah, you can check the space you currently have and guesstimate.
    • If you own a car, and it has wheels on it, and you know the offset of those wheels, and you have a measuring device, you have everything you need to work out if other wheels will fit.
    • Will this fit? but they are staggered set - RAYS 57DR SEMI GLOSS BLACK 18x8.5 +37 | 18x9.5 +38 5-114.3 STAGGERED SET   or If no go could just get a set 4's wheels of 18x8.5 +37 5-114.3 - would i run 8.5's 235s up front n 245's at the back if I do?   Thanks.
    • Put a clamp on your return line. I have a feeling it's sucking air, and introducing bubbles to your fuel. With a lot of fuel, less problematic. I'd honestly be redoing all the lines in the tank and clamps on everything.   Also, you've given two different answers to the same question: Asked if being followed by the police you could get down to use the whole tank, you said yes you could, so long as you keep off boost. However, you then followed this up that free revving, it would also cause the issues. I'm doubting free revving is enough to make any noticeable boost on what is likely a decent sized turbo.   So now I have to ask, can you actually drive it lightly and use all the fuel, or does it break up even free revving? Also, have you put a fuel pressure gauge on it? Can you hear the pump change noise at all when you're having this issue?
