Yo, Ive got a '95 R33 GTR here in sydney for wrecking as it unfortunately can't be complied
It's silver and has approx 44,000 ks, series 1. I can post almost everything from the car, or pickup is available. Will post some more pics in the next few days
R33 GTR rb26dett motor, complete engine with approx 44,000 ks. Compression test came up perfect- ~165-170psi each cylinder
Includes turbos, wiring loom, ECU, manifolds, injectors - $5000 ono
17x9" Axia? (jap wheels) +18 offset wheels with Dunlop Lemans LM702 tyres, front 2 have about 50% left, rears are pretty much on the tread markers
$1000 ono
5sp Manual GTR box, good nick.. includes slave cylinder, shifter - $1000
HKS 3" catback exhaust - $200
Exterior stuff
R33 GTR front bar - paint is cracked + grazed a bit on drivers side. includes blinkers - $400
R33 GTR grille - $250
R33 GTR front guards, includes GT badges and blinkers - $500 pair
S1 headlights - $400
R33 GTR front reo bar - $150
radiator support/ nose cut - $300
R33 GTR sideskirts + rear pods - $200
R33 GTR bootlid + spoiler. Paint is a bit faded on the pass side near windscreen, includes GTR badge - $400
Rear 'Skyline' garnish - $50
Guard liner plastics, both sides - $100
Brake vent plastics - $100 pair
Tail lights - $50 each
Side mirrors - $50 each
Passenger door minis door trim - $150
Drivers door minus door trim/switches - $200
post-35556-1240393680_thumb.jpg post-35556-1240393701_thumb.jpg post-35556-1240393200_thumb.jpg
post-35556-1240393715_thumb.jpg post-35556-1240393732_thumb.jpg post-35556-1240393766_thumb.jpg
Engine bay stuff
R33 GTR afms - $200/pair
R33 GTR airbox & snorkel - $150
Engine Mounts - $100/pair
GTR BM-57 brake master cylinder - $120
Stock dump pipes + front pipe - $150
Stock BOV pair - $120
Stock BOV recirc piping - $100
Stock FMIC piping - $100
Stock Calsonic FMIC, some damage to the bottom though it still holds pressure fine - $50
R33 GTR A/c condenser - $150
R33 GTR radiator- $100
Thermo fan - $80
GTR Washer bottle - $30
fuse box lid - $20
radiator overflow bottle - $20
Charcoal canister - $30
Bonnet lining - $50
post-35556-1240393555_thumb.jpg post-35556-1240393670_thumb.jpg post-35556-1240393834_thumb.jpg
Suspension/brakes/driveline
Front & rear Brembo calipers + pads - $1750 full set ONO
Stock suspension, full set - $250
GTR front + rear swaybars - $150
GTR rear diff - $500
standard swaybars - $80 each
Front upper control arms - $50 each
Rear lower control arms - $50 each
Rear 5 stud hubs - $160 pair
Handbrake assembly & cables - $160 pair
17" space saver tyre - $50
Interior stuff:
R33 GTR front + rear seats + door trim, complete set - $1600 ono, will probably seperate
GTR instrument cluster, carbon fibre look cover ~44,000ks - $250
GTR 3 gauge centre DIN cluster, nismo white face cluster & carbon fibre look cover - torque, oil temp and boost - $175
post-35556-1240393321_thumb.jpg post-35556-1240393332_thumb.jpg post-35556-1240393294_thumb.jpg
Steering wheel with S1 airbag (some wear on the wheel but airbag is great) - $150
Complete Boot interior - $100
Drivers door window switch (suit s1/s1.5 R33) - $80
Drivers window switch surround (s1), bit worn - $30
Drivers door window motor - $80
Passenger door window motor - $50
Large dash surround plastic with clock etc (s1) - $70
Gear stick surround (s1) - $50
Ashtray - $25
Glovebox - $40
climate control - $40
Seatbelts, full set - $80 (will seperate)
If you're after any random bits and pieces that arent listed, shoot me a PM- got the whole car available
Cheers!
https://www.sau.com.au/forums/topic/266621-r33-gtr-95-wrecking-in-sydney/
  • Replies 140
front guards on hold till next week! climate control sold pending payment
pm sent
Replied
pm sent
replied
pm sent
replied
how much for the front Strut Brace?
oops, forgot to list it - $80 each for the strut braces
pm replied!
pm sent
replied!
Post the brake ducts to Melb?
yep no worries, PM sent
Pm Sent
replied!
il take the head lights and grill , also the airbox and afm please pm me
done, PM sent
PM Sent!
replied!
how much for just the front gtr seats? any damage ie. rips and so on
Chasing $1000 for the front 2 seats+rails. No rips or anything, few tiny tiny marks but theyre negligible imo
pm sent
replied!
    • Initially I thought having a pair of Recaro seats would be a big bonus, it turns out these do get a little uncomfortable on long journeys (my fault, not the seat). I had a look through the GSM Performance website at reclining seats and booked an appointment to visit their show room. I got the Recaro Sportster CS for the R34 from here, was very happy with the service received so of course a re-visit was in order. Unfortunately the two Corbeau seats I had chosen aren't on display but they had 4 other options available. Two seats dug into my back, one dug into my legs and the other was perfect. I also found out that Recaro seats use a larger bolt pattern so some adaption was required. Luckily GSM offer some universal adaptors that should solve this problem. I searched the interwebs for price comparisons and Corbeau themselves were the cheapest at £300 cheaper (for the pair). I asked GSM if they could price match, unfortunately they couldn't. I later received an email saying Corbeau would honour them the same discount, but the purchase was already made. I did however order the brackets from GSM, both arrived on the same day. I started with the passenger side seat, knowing this was going to be a little trial and error. There are 3 mounting holes at the front and 2 at the rear on these JURAN Racing seat rails.  With the adaptor brackets mounted, the allen cap bolts started to push into the seat, NOT GOOD!  The rear mounting holes lined up but there were issues at the front. The holes were 1/2 hole out, so the brackets got a tickle with the drill to modify the holes. The supplied bolts weren't going to be long enough and a spacer was needed to stop the adaptor bars from bending. A local fasteners company supplied be with some nylon spacers and longer bolts (M8x30, although these will be replaced with 35mm long shortly) A before and after I pre-drilled the front bracket before making a start on the driver's seat to save some time. And in no time at all that was in the car too. The all black seats have transformed the interior and these are MUCH more comfortable. The only downside with the new Corbeau seats is I sit a little higher, but I'll happily accept that over discomfort. The Youtube video can be found here: https://www.youtube.com/watch?v=wPyttKPktXA
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
