OK guys, things are progessing quite steadily and am wondering what to do with my cams (am not forking out for huge cams and a solid lifter conversion). Stumbled across this cam info again and am trying to figure out whether to stick with the 25DE cams or whether a combination of 20DE/20DET/25DE cams would be better..
RB20DET
Ex - 240 duration, 7.8 lift, opens 60 BBDC, closes TDC, LCA 120
In - 240 duration, 7.8 lift, opens 5 BTDC, closes 55 ABDC, LCA 115
overlap = 5, LSA = 117.5
RB20DE
Ex - 240 duration, 7.8 lift, opens 57 BBDC, closes 3ATDC, LCA 117
In - 232 duration, 7.3 lift, opens 5 BTDC, closes 47 ABDC, LCA 111
overlap = 8, LSA = 114
(R32) RB25DE
Ex - 232 duration, 7.3 lift, opens 54 BBDC, closes 2 BTDC, LCA 118
In - 240 duration, 7.8 lift, opens 9 BTDC, closes 51 ABDC, LCA 111
overlap = 7, LSA = 114.5
Relevant specs of the engine are:
RB25/30 (R32 RB25DE head)
Stock RB25DE (R32) cams
GT35R 0.82 exh housing
6boost manifold
50mm gate
Rev limit will be 7500rpm and looking at somewhere around 500rwhp. Can someone with a good working knowledge of cams in RB engines please help! :(
https://www.sau.com.au/forums/topic/266695-cam-advice-for-2530/
I'm in the same boat!
I have been considering stock RB25DE cams, but.. have no real clues to see if it will help me gain where I want it to gain.
My current plan is to build the engine and get it tuned.. Then go from there.
But that is not very helpful, and is a pain in the butt if it doesn't do what I'm wanting it to do!
Have just spent an extra 4k that I wasn't orginally planning to so I'd rather not spend $_$ on new cams unless I can really, really justify it..
Just for some comparison, these cams in this head made 490rwhp @ 22psi with a pair of 2540's.. I've had a mechanical engineer tell me to use the 20DET cams over the 25DE.. not sure on the justification though.
Craked, PM sent.
i got no secrets!
stock rebuilt rb30 with rb25 non vvt head from r32
gtr injectors
power fc
xr6 35/40
reground gtr cams
Nice!
That turbo has a 1.06 rear yeah? what power are you making and at what boost (and when do you see it?)? :laugh:
Obviously it drives pretty nice going on how happy you were with the cams..
ye it has the 1.06 rear and ideally i would've liked the smaller rear but this turbo popped up at the right price.
it currently makes 251@12psi, only reason i'm not running more boost is i dont have a boost controller and i can't warrant spending more money on a car i never drive. makes that boost by about 4000rpm but because its so torquey off boost it doesn't phase me.
cheers!
Got a couple of variables there you'd need to work on.
What turbine A/R?
What spec are the rods and rod bolts?
The cam specs suggest pushing the effective rev range upwards - ie. moving the torque curve to the right. Turbine housing choice will move your torque curve around as well.
Some who've used the GT3040 suggest it's great/useable/driveable, although the compressor flow is likely to outstrip the turbine flow capabilities. For the higher rpm and power capacity the cam specs suggest, perhaps chase a GT3582, and make sure the bottom end is built to withstand 8000rpm? I tend to think for some applications the XR6-T version is quite a decent match for a RB30DET. Possibly a bit of a soft delivery down lower, but the relative lack of turbine backpressure allows it to hold decent torque as revs rise. Be interesting to see a dyno sheet for mr rbman.
Otherwise recommend putting the specs through a Cam Doctor review and see what the predicted results are :P
Edited by Dale FZ1
    • I wasn’t able to replicate the sound anymore. It was a one time sound so maybe it was just coincidence but it was like small pebbles being dropped in a coke can.   should I try cleaning the MAF? It could be it’s functioning but dirty? I don’t know.
    • Update 4: Hi all. The car drives again! Haven't driven for long, only to store it in the garage again, but the test drive was successful. The coolant and oil leaks seem to be fixed for now. Temps on the engine were also very good, while moving I never even saw 80C water during the approx. 30 minute drive. Ate up all the coolant in the reservoir though so will have to fill that even more when I go to the car next time. One thing that pisses me off is that the RPM gauge is still f**ked, I even resoldered the board twice and used copper paste on the silly screws that are used as connections. Next time I take it out I'll take apart the board and fit new components, I'll see if I can get a replacement IC for it.  I have an appointment set for 22nd of September for the engine tune to 370hp. Alignment also still needs to be done. My hope is that I can get all the legal stuff over with by the end of this season. Anyone of you have advice regarding intercoolers? Currently there is an APEXI core fitted, one of those weird hybrid ones, 600x270x76. I don't think it's bad but it's not new and now I still have the chance to change it now to legally include it in the paperwork. Only issue is that the only options that would arrive in time are a HKS Type R intercooler or generic Ebay spec intercoolers comparable to a JustJap one. Ideally I'd order a Plazmaman but it takes over a month to receive which would mean making the car legal has to wait until next season. Would love to hear some input on this. Same story for my injectors, the previous owner was a nunce and put ID 1050x on the engine. They work but are obviously not ideal at "normal" power levels. But I don't see a reason to change them unless the tuner says it's necessary. I read online before buying a different exhaust that the top secret style rear diffusers won't fit due to the size of the rear resonators. My buddy and I made it work by slightly "adjusting the shape" of the mounting bracket and making some spacers out of 3d print for the mounting bolts. Fits like a charm. Just putting this here in case someone has this problem. Even the hefty HKS Silent Hi Power rear can fits without hitting anything.
    • Well they got my money but they are not getting my gearbox !
    • It's needed for rolling idle up, and I think it is a decider on VCT also.
    • I mean, not really. Link ECU's can absolutely still have errors from the ECU thinking it's getting a sensor it's not expecting. I would imagine the speed at the ECU level in Nistune does absolutely nothing anyway? I assume the ECU does not do any fancy TC stuff with regards to front+rear wheel speed or anything of that like anyway. Someone who uses Nistune may be more fluent in it.
