Cool, I'll be on my way around to collect it in 5 minutes :)
That is a good price, I had a quick squiz on Ebay to see what they were going for. I would have gone down the NisTune road but it appears the M35 computer doesn't like the current versions of the NisTune boards available.
Let us all know how you go with the E-Management Ultimate, sounds like a cost effective solution instead of replacing the whole ecu system.
Let us know how it all goes, I did a bit of work on the ECU pinouts and have put together this drawing. There was some common inputs that I couldnt find / stopped trying to find on the harness like boost & O2 so if you know what pins these are then let me know.
ECU_Pinouts_Model__1_.pdf
well, pending avaliability next weekend - and thanks to your diagram - ill install it and get it running (with everything unadjusted) to make sure it works. then it will be a wait for the mods to happen before a drive to melbourne for a tune!
thanks for the offer of help, ill post in here so its available to anyone else that might be doing the same thing
No problems, Ive been waiting for a fully tunable ECU alternative, like FLASH'g the existing or aftermarket ECU but no one has done this yet. Im using SAFC2 at the moment and its working fine but not very tunable.
ok so im set to install this on the weekend.
the only thing that worries me is the settings on the actual unit, the jumpers, and also the firing order for ignition
in my S15 i had to wire 1,2,3,4 to 1,3,4,2 due to a 4 cylinder firing order, i destroyed 2 coilpacks with incorrect wiring, and i dont want to risk that on this car.
they mention V6 engines, and with nissan being nissan they will probably have kept it fairly standard config. im going to google emanage ultimate installs on a VQ35DE engine from the states, i believe they act the same, even if the ECU is wired differently.
fingers crossed!!!
ok here is an install doco for G35 (US) that looks pretty good. ignore the wiring to the ECU, however his technique and setup is good, and it covers some nissan 'problems' etc.....
DandyMaxEUWriteup.pdf
may as well keep all the Emanage Ultimate stuff in the same place. make it easier for other guys to find and us to assist with
so once ive done my install, are you gonna drive to sydney to get me to do yours too?? :)
cheap rates :):P
cheap rates :):P
Haha. You would have to be bloody cheap.
Remember I can get it installed & tuned for a damn good price.
Edited by iamhe77
cheap rates :P:P
Ahem... I do hope you are referring to the E-Manage Ultimate :)
I'll be interested to see how it goes and what you think of it after it's had an optimal tune :D
I assume you are going for high output rather than fuel efficiency ;)
But I'm sure you can adjust that on the fly or atleast with a laptop running windows?
I've got a apple laptop so that wouldn't be too good for the whole USB software adjustment etc.
ahh yeah damn i forgot you were already IN melbourne for that tuner lol
yeah you can tune it on the fly with a laptop, but id be doing it on a dyno so its done properly.
ill be tuning for less fuel down lown, and more power up top because i drive easy around the city where i need economy, but when i put my foot down i dont give a shit lol
+1 (or is that +2?)
so yesterdays install didnt occur. the pin layout diagram i have may be incorrect. i was metering out +12v and 0v and neither of them were correct. so either i cant use a multimeter anymore, im reading it backwards, or the diagram is incorrect.
not sure what im going to do at this stage.............. might try again when i dont have a headache lol
Hmm... Too many variables there.
Perhaps ask URAS (Trent from Status Tuning - here in Melb)
Also, check out his eManage Ultimate thread.
Edited by iamhe77
nah no updates mate, with mothers day yesterday i didnt get a chance. ill see whats on this weekend before i give it another go. im prepping the wiring so the hopefully ill just need to plug it in after i crimp the wires
    • Ok so after much research and talking with knowledgeable people I've got my turbo conversion done and it's all running great other than 1 small issue.  Car has remained auto with the na auto and tcm, I've used a stagea ecu with. NIstune board and everything is great other than my gear selection on the dash. It illuminates park, reverse, neutral, 3rd and 2nd. But nothing drive or what gear your in when you pop it into tiptronic.  I'm sure there is may e 1 wire in the ecu plug I need to move to rectify this. Dose anyone here have any ideas?   Cheers guys
    • Sorry I haven't been following all the detail, so you may have tried this. Does it idle with the tiniest bit of throttle you can add? You've mentioned the IACV, does it have an AAC valve and have you adjusted it at all (ie, screw the idle adjust screw all the way in, then back it out a couple of turns until idle is stable)?
    • My bad, I unplugged the one underlined in red instead of yellow before. With the car started, after unplugging the IACV (the one underlined in yellow), it idled at around 400/500 for 3 seconds before stalling. Attempting to start the car without the IACV will not start the car.   It does stutter and sputter for around 5 seconds before dying. However, immediately after starting it, you can already hear some slight sputters from the exhaust.   It won't start with the AFM unplugged. If it is when the car has already started, it stalls in a few seconds.   Yesterday, I did take some logs using Nistune of 3 scenarios. Car idling till it stalls Car idling and unplugging the IACV Car idling and removing the AFM I also have some previous logs of when the Car is idling till it stalls and when driving and it cuts. I am not really knowledgeable enough to understand what to look for. After every test, car idles rougher and rougher, until I have to stop. It will be fine the day after.
    • There is no difference between a 17x8 and an 18x8. The total diameter of the tyre needs to remain +/- the same (so you don't mess up the gearing, speedo reading, and clearance when turning front wheels..... so you just need to use a lower profile tyre on th 18 than you do on the 17. /rocket surgery.
    • I thought the same to start with. But then I thought it was one of those LCAs where the end of the ARB goes through a bushing in the LCA itself, instead of having an end link.
