okay well i like going lower
so im gonna put RS and RX stuff on m car :)
Will probably end up too low man. Too low indeed.
By all means go for it. I will be looking for some suspension so may buy it from you when you put it up for sale :)
  • 3 weeks later...
Yes I know there is a "Stagea Suspension" thread, but it is pretty cluttered and we haven't really explored a lot of M35 suspension kit options out there, so I thought I would put together a bit of a list with some basic info and links to websites for those of us without suspension upgrades.
This is not a complete list by any means, but should serve to give M35 owners a few options.
Silk Road "RA-1"
Adjustable: F -20 to -90mm, R -15 to -65mm
Spring rates: F 16kg/mm, R 10kg/mm
Non AR-x
RRP: 165,900yen
Website: Silk Road
Freeway-Dolphin (Ohlins)
Adjustable: unknown
Spring Rates: F 9km/mm, R 8kg/mm
AR-X not specified – also available in 2WD
RRP: 344,400yen
Website: Dolphin
Bilstein "BTS"
Adjustable: No. Front /Rear -40mm
Spring rates:
AR-X #BTSA162
RS/RX/Axis #BTSA163
RRP: 168,000yen
Website: Bilstein
NM35 Bilstein Dampers (RS/RX/Axis)
Front part # - Left BE5-A100, Right BE5-A101
Rear part # BE5-A152
Cusco "Zero 1 and Zero 2"
Adjustable: F -10 to -65mm, R -10 to -65mm
Spring rates: Made to order
AR-X not specified
RRP: Zero 1- 153,300yen
Zero 2- 186,900yen
Website: Cusco
HKS "Hipermax LS+"
Adjustable: F 0 to -58mm, R 0 to -42mm
Spring rates: F 10kg/mm, R 6.8kg/mm
AR_X not specified
RRP: 192,150yen
Website: HKS Hipermax
Insurance Group "G-Line"
Adjustable: F -20 to -95mm, R -15 to -65mm
AR-X adaptable
RRP: 208,950yen
Website: G-Line
RS-R "Best*i" and "Basic*i"
Adjustable: F 0 to -55mm, R 0 to -55mm
Spring rates:
AR-X available
RRP: 115,000yen
Website: RS-R
Nismo "S-Tune"
Non adjustable
Spring rate: F 8.3kg/mm, R 9.2kg/mm
Non AR-X – Also available in 2WD
RRP: 96,780yen
Website: Nismo S-tune
Tein "GT Wagon"
Spring rate: F 10kg/mm, R 11kg/mm
Non AR-X
RRP: 104,457yen
Website: Tein
Tein "Super Wagon"
Adjustable:F 0 to -55mm, R 0 to -55mm
Spring rate: F 6kg/mm, R 7.2kg/mm
AR-X not specified
RRP: 132,300yen
Part# DSP00-91AS3
Website: Tein
Aragosta "ERS"
Adjustable: F 0 to -65mm, R 0 to -58mm
Spring rate: F 11.6kg/mm, R 9kg/mm
AR-X not specified
RRP: 346,500yen
Website: Aragosta
Takero's
Adjustable: F -20 to -48mm, R -20 to -48mm
Spring rate:
Non AR-X
RRP: 346,500
Website: Takero's
Kenstyle
Adjustable: F +20 to -22mm, R +14 to -15mm
Spring rate: F&R 5.4kg/mm
Non AR-X
RRP: 139,650yen
Website: Kenstyle
Absolute "DS"
Adjustable: Made to order
Spring rate: Made to order + camber adjustment
AR-X not specified
RRP: ~235,000yen
Website: ???
JIC Magic "Profit FLT-TAR"
Adjustable: F +10 to -30mm, R +10 to -30mm
Spring rate: F 8kg/mm, R 8.2kg/mm
Non AR-X
RRP: 152,250yen
Website: JIC
MASA "M-Tune"
Adjustable:
Spring rates: F 10kg/mm, R 10kg/mm
Non AR-X
RRP: 281,400yen
Website: MASA
KYB "Lowfer Sports"
Non-adjustable: F -21mm, R -25mm
Spring rate: multiple selectable springs
Non AR-X
RRP: 52,920yen
Website: KYB
AiStar "A-Spec"
Adjustable: F -5 to -55mm, R -5 to -55mm
Spring rate: F 8kg/mm, R 7kg/mm
Non AR-X
RRP: 106,870yen
Website: ???
Hi
I just bought a set of Tanabe Sustec Pro NF for $1600 delivered to Brisbane. Got em from JDM Concept, they have them in Stock in Australia.
Tokage Racing Imports on the Gold Coast have a set of HKS Hipermax LS+. Second hand but in excellent condition with no leaks or bends, $1800 delivered.
Hi
Yeah, forgot about the Tanabe's. How are they? Pics of your car with/without?
$1800?I think I would get a set of Nismo's new for that money, even if they are not adjustable - just a great ride.
Has anyone recently tried to buy Bilstein shocks for an m35 through Sydney shock absorbers?
I rang them today and asked, they told me they had them for earlier stageas but not for 35's. Quoted Steve the part no's in this thread, but he had no listing, and no knowledge of them.
How are people buying replacement suspension parts?
the Bilstein shocks for the M35 were a special make up for the Japanese distributor of Bilstein. there were made to his specs and I believe they are not an option for any other distributor to buy as minimum order was 100 units or more.
Cheers
Andy
Hi
Have you installed yet? Could you post some pics and a bit of a review?
Hi
Sorry it took so long guys.... :rolleyes:
SUSTEC PRO NF (Normal Feeling)
F: -37mm to -78mm
R: -37mm to -73mm
Spring rate: same as OE
RRP: 110,250yen
Tanabe NF
SUSTEC Pro GF (Grip feeling)
F & R: -25mm to -35mm
Spring rate: "Medium" - estimated to be ~8kg/mm
RRP: 116,850yen
Tanabe GF
Edited by iamhe77
Sorry it took so long guys.... :ninja:
F: -37mm to -78mm
R: -37mm to -73mm
RRP: 110,250yen
Tanabe NF
RRP: 116,850yen
Tanabe GF
I have paid for them but the manufacturer came back to me asking if the car had Hicas or not. Apparently if you have Hicas on an NM35 there3 is a problem with the coilovers rubbing or touching some of the mechanics in some way.
Any-one had any experience with this. There is no Hicas light on the dash, so I am assumng I don't have it.
Not sure about other brands.
make sure they know its an M35, the spring and shock are seperate on our models - in the rear. C34s had a 'coil over' type of setup on front and rear. DOUBLE CHECK before they send it to you
Edited by zei20l
Have not had any direct experience, but the only noted difference with all the aftermarket suspension I have in this thread is whether it is 2WD or 4WD only.
Not once have I seen any info regarding HICAS.
Do you mean that Tanabe in Japan asked if your car has HICAS or that the place you bought it from asked?
Tanabe in Japan asked if the car had Hicas, I bought from JDM Concept, he is the agent for Tanabe in Oz. My mechanic from Brisbane Turbo and Tuning said it is possible that some of the Hicas Mechs would be very close to an aftermarket coilover. He said depending on the Make and outside diameter of the coilover this could be a problem.
By the way the Tanabe GF don't do a fitment for the NM35
Hmmm... admittedly I cannot find any info on the GF kit this morning (and didn't save the page I found it on either :D )
Perhaps if you go to JDM Concept with the part number GGNM35K, they might come up with something.
When I was looking at a set of Bilsteins through an Australian distributor, they could not find anything - even when talking to their contact in Japan.
This may or may not be the case with JDM Concept Tanabe as I do not know how if the Tanabe kits are put together by Tanabe Japan or by an independent distributor who has asked for a "special order" of GF kits (as was the case with the adjustable Bilsteins).
Hmmm... dam it, I hope the GF doesn't exist because I have confirmed my order on the NF's and I believe it is to late to change. My wife will be happy because she doesn't want me to change anything on the car and the fact that NF means Normal Feeling is as close as I can get to making her happy about the coilovers.
  • 1 month later...
Have you got the tanabes in yet?? I'm very interested to see how they look and feel.
    • I thought that might be the case, thats what I'll start saving for. Thanks for the info
    • Ps i found the below forum and it seems to be the same scenario Im dealing with. Going to check my ECU coolant temp wire tomorrow    From NICOclub forum: s1 RB25det flooding at start up Thu Apr 11, 2013 7:23 am I am completely lost on this. Car ran perfectly fine when I parked it at the end of the year. I took the engine out and painted the engine bay, and put a fuel cell with an inline walbro 255 instead of the in tank unit I had last year. After reinstalling everything, the engine floods when the fuel pump primes. if i pull the fuel pump fuse it'll start, and as soon as I put the fuse back in it starts running ridiculously rich. I checked the tps voltage, and its fine. Cleaned the maf as it had some dust from sitting on a shelf all winter, fuel pressure is correct while running, but wont fire until there is less than 5psi in the lines. The fuel lines are run correctly. I have found a few threads with the same problem but no actual explanation of what fixed it, the threads just ended. Any help would be appreciated. Rb25det s1 walbro255 fuel pump nismo fpr holset hx35 turbo fmic 3" exhaust freddy intake manifold q45tb q45 maf   Re: s1 RB25det flooding at start up Fri Apr 12, 2013 5:07 am No, I didn't. I found the problem though. There was a break in one of the ecu coolant temp sensor wires. Once it was repaired it fired right up with no problems. I would have never thought a non working coolant temp sensor would have caused such an issue.
    • Hi sorry late reply I didnt get a chance to take any pics (my mechanics on the other side of the city) but the plugs were fouled from being too rich. I noticed the MAF wasn't genuine, so I replaced it with a genuine green label unit. I also swapped in a different ignitor, but the issue remains. I've narrowed it down a bit now: - If I unplug and reconnect the fuel lines and install fresh spark plugs, the car starts right up and runs perfectly. Took it around the block with no issues - As soon as I shut it off and try to restart, it won't start again - Fuel pressure while cranking is steady around 40 psi, injectors have good spray, return line is clear, and the FPR vacuum is working. It just seems like it's getting flooded after the first start I unplugged coolant sensors to see if its related to ECU flooding but that didnt make a difference. Im thinking its related to this because this issue only started happening after fixing coolant leaks and replacing the bottom part of the stock manifolds coolant pipe. My mechanic took off the inlet to get to get to do these repairs. My mechanics actually just an old mate who's retired now so ill be taking it to a different mechanic who i know has exp with RBs to see if they find anything. If you have any ideas please send em lll give it a try. Ive tried other things like swapping the injectors, fuel rail, different fuel pressure regs, different ignitor, spark plugs, comp test and MAF but the same issue persists.
    • My return flow is custom and puts the return behind the reo, instead of at the bottom. All my core is in the air flow, rather than losing some of it up behind the reo. I realise that the core really acts more as a spiky heatsink than as a constant rate heat exchanger, and that therefore size is important.... but mine fits everything I needed and wanted without having to cut anything, and that's worth something too. And there won't be a hot patch of core up behind the reo after every hit, releasing heat back into the intake air.
    • There is a really fun solution to this problem, buy a Haltech (or ECU of your choice) and put the MAF in the bin.  I'm assuming your going to want more power in future, so you'll need to get the ECU at some stage. I'd put the new MAF money towards the new ECU.
