Hi Guys.
Read this entire thread but no one had answered the question yet so so... just wondering if anyone has fitted any type of coilovers to an M35 with HICAS, mine is currently on the water but is a HICAS model and I did read a while back that there maybe an issue with clearance... any one here actually have a HICAS model with coilovers?
Cheers :)
yes all ARX models have HICAS, also LSD models on some RSs to
is yours an RS with HICAS? lucky for you it has an LSD too
anyway, the suspension bolts up the same, its the tray for the spring that steers the wheels
12kg's are fine for the front.....12kg's are a too hard for the rear imo.....but then again I'm try to get a lot more power to the ground than stock.....I'm running 9.3kg's in the rear atm and it's very snappy in the wet........12's in the rear would be a little bumpy as well.
In between 8-10kg's would be fine in the rear....if you want to play around with it more get a good adjustable rear sway bar.
Hey Jetreck, what suspension are you running if you don't have BC's?
Hi Guys.
Cheers :)
I'm running BC's and mine has Hicas :thumbsup: and an LSD... :nyaanyaa:
No issues at all. The hicas only deflects the subframe a few degrees, so I can't see any problems.
Edited by Daleo
It's a 250T RS Four V
Unsure about LSD :S
Might go 12front and 10 rear wouldn't mind racing kents later on but I dont mind stiff as I still need better fitment!
Just got pedders springs all round at then moment rides like poo! You can buy them once I get coilsezzzzz
The ARX rims are +40????
lame...
Yeh, I used to have a set on mine too. They're not ideal. post-61153-0-51601300-1302746704_thumb.jpg 20mm spacers would help a lot.
I now have these; post-61153-0-09558200-1302746830_thumb.jpg V35 18x8, +30 offset. Much betterthumbsup.gifpost-61153-0-78944500-1302747133_thumb.jpg
    • The wiring diagram for the R33 RB25 is freely available, and is essentially the same same as most other RBs (just with differences as to which pin # does which job). To get the ECU to power up, you just need to provide power to the ECCS relay, and have the other power feeds that come in from the top left of the wiring diagram (wrt the ECU) that give perma power to the fuel pump relay, the ECU itself, etc etc, all connected. When you put power on all these it will just come to life. It's pretty clear from the diagram what needs to happen. Just follow the lines from the 12V + supply stuff in the top left over towards the ECU. I've even posted snips of such diagrams (not for vanilla 25, I think for Neo and 26) to various threads here in the last few months, talking about what it takes to get the fuel pump and FPCM up and going. Search these up and they will help get you started on doing the same with the vanilla 25 diagram. Hell, for all I know, I've done the same with that one in years past and have forgotten.
    • Yep...so unless someone posts up the answer you will need to probe from the ECU connector to the dash plug with a multi meter in continuity mode to trace the wires.  Note the ECU has multiple - and + (and across different key settings - Battery, IGN and Start) and most likely the power is fed from the connector(s) that is normally near the left hand headlight.
    • Thanks Duncan, I am actually just trying to get the Rb turning and running with the RB25DET S2 original loom itself  I am just trying to get it going outside the body and not thinking about the S15 or trying to match anything to the S15 loom at all I am only trying to see if anyone has done this and what pin they found to be the ignition trigger and ECU+/- on the dash connector, that's about it. Thanks
    • Hi Guys, Does anyone know any aftermarket part numbers for a starter motor to suit the VQ25DET? I can find lots of alternative part number for the VQ35DE, which I assume would fit, but there is a lot of conflicting information out there. Thanks..
    • I don't understand how this hasn't boiled down to - Upgrade the turbo when you have everything required. ECU, injectors, fuel pump, turbo, etc. Do it all at once.  If you don't have everything required, just enjoy the car as it is and keep saving up your pennies.
