I'm not sure which way I'm leaning at present, I have loaded up the car with some heavy items quite a few times so it needs to stay functional.. but the look of it squatted tempts me badly! I also love being able to drive over things without fearing the usually scrapage that I get with the Supra, but I want it to have less understeer than at present. I'll wait and see how the Whiteline sway bars go that I just ordered from Daleo :D
dude, its an ARX and the guards are lower AND you have a larger rolling diameter wheel.
cant compare RS/RX and ARX like that. your car may LOOK lower, but isnt
take craigs car and mine for example. mine IS lower, but his LOOKS lower :)
thats because it has awesome!....oh wait...so does yours..........we are both awesome!cheers.gif
what if its already happened?
anyway, i need to drop the rear a little. maybe raise the front. but dont think so. my new exhaust wont hang as low as the stock one. mostly due to its lack of mufflers
this is what the AXIS looks like now.. big wheels but they look tiny being up so high. would love to take an inch out of it but almost seems like more hassle than its worth. Your cars are dumped!! I couldnt go close to that
lol you need larger tyres.
17", go for a 55 tyre
18", go for a 45 tyre
19", go for a 35 tyre
Edited by iamhe77
these are actually 20".. but yes I def need larger tyres! I'm not too happy about the offset on these either... need some new 19" forgies yummmmmmmm.
my original aim with these wheels was to complement the car so they didnt stand out too much.. i guess it worked! lol
but with some height taken out the rims increase in size.. but it becomes less practical the lower you go!
My love of this car grows everyday so it might get to a stage where a new set of rims with suspension is in order.. and some new brakes!
or just put some 30's on your existing wheels.
They will be a smaller rolling diameter than the standard RS/RX/Axis rolling diameter, but better 12mm smaller rolling diameter than 12mm larger if you put 35's on there (might scrub)
Go to the link below to compare wheel and tyre dimensions
http://www.rimsntires.com/specs.jsp
    • HFM BM57 has a "bad" knee point, IIRC. It's not the same thing as the later R chassis MC.
    • The ATTESSA is functionally identical to R34; there were a bunch of JDM models that continued ATTESSA including Fuga/Q70, Skyline/Q50, Cima etc as an option. All with Auto only and I think mostly for snow regions. AFAIK there were no AWD VR30DDTT sold in Australia - it is on my to do list to check regs for racing a LHD car in Targa/ATR/AASA/CAMS events because if I can get the auto to work it would be interesting to run a 4wd car The Ecuteck TCM tuning is the same model as their ECU tuning, they already have it for R35 and Dose's favourite, BMW. You buy "points" to allow your computer to be tuned, buy either a bluetooth (phone app) or bluetooth+USB+Key (phone and PC) dongle, and pay for a tune that will be locked to your tuner ( ). You can also access the tuning software yourself but 1. it is mega expensive and 2. these computers have a billion parameters that intersect, so how could you ever spend enough time on it to get a decent result.
    • Or, is it a case of what it is like owning an R series Skyline? NFI what the previous owner has done or fiddled with... Ha ha ha After reading through this thread, I went on a bit of a research about the Q50/Q60. Now I'm quite intrigued by them! Is the AWD in them more like a WRX where it's always AWD, or is it more like the ATTESSA in the GTRs? By the sound of this TCU tuning, this sounds like a case of someone has made some real software for it, and you just need the right piece of hardware, and then you license that specific vehicle/TCU. Or is this a case of the software will be really expensive so only a few tuners have it, and you still have to pay a license per vehicle?
    • No, code 21 is very straightforward. It can only be the things described in that diagnostic flow. In fact it has no way of knowing that the spark plug resistance is out of spec.
