are the 2WD and 4WD ones the same? it looks very similar.
That was exactly my thought Iain. If not, the bushing will almost certainly be the same.
I'd be inclined to replace it with the factory one, given it attaches to the body not where you want a hard bushing to transmit noise & vibration.
I normally only use harder (polyurethane) bushings at the wheel end of suspension arms. Softer factory style rubber bushes at the body end to damp out vibration. A brand new factory style rubber bush will be significantly stiffer than one that's done 100 000kms. Poly bushes will still fail over time; bushes are a consumable item in cars; they do wear out, just not to the same degree as brake discs
This stops you from turning the car into a billycart (noisy & harsh) for very little change in rigidity and directness.
Edited by Daleo
thats a fair enough call.
im hardcore and not a pussy old man like you, so i can take a firmer suspension setting :P
i had poly bushes all over one of my S15s, and solid diff mounts in the rear. it was noisy and bumpy. but the good thing is you couldnt notice it over the exhaust that got in your head anyway haha
but it wasnt harsh. it just felt new again.
It is the same indeed.
But there is an option/correction to fix up pull to the left with a slight cast change with the non standard ones over the factory replacement.....thats if you have that problem.
Now that would be a worthwhile reason to change.:thumbsup:
Hey Guys,
I really need some input here.
I'm thinking of taking the cheap route on my 300RX M35 2WD. It's wallowing cornering is starting to piss me off after 3 years of ownership as it does not tie in with the amount of urge that the engine is providing. It hangs in fine on a single corner, but when I try and link two apexes together, the weight transfer is like a motor yacht.
There is a local suspension shop doing Tien 50mm lowering springs fitted for $450.
I was hoping that you guys could offer your opinion on how you think the vehicle will corner on standard shocks with lower, stiffer springs? I can get the BC gold coilovers but after I fit them and certification they'll set me back $2000. Money I'd rather spend on my Trackday weapon if you know what I mean :cheers:
So what are your expert thoughts? :cool:
So I fitted up the new poly bush's today....finally the frigging vibration has gone that I have been hunting for the last 2 years. Drive is great...feels like a new car again as it should as I have now replaced everything....my old ones were pretty well gone.
The replacements are a lot better in design as they allow for the arms to not load up continually
dude thats the 3rd time you have asked me, and yes it pulls to the left lol
seems like I have a memory like yours.....I'll let Adrian know I'm taking them.......I might go over this arvo and press them for you.
I finished the wheel alignment with the new poly strutt bar to chassis mount bushing in yesterday.....the ones that I got add about another 1 degree caster from the standard setup.
Car now handles a lot better through corners with less bump steer and a more precise point + my friggen vibration had gone when powering out of left hand corners.....I am actually thinking of backing off the sway bar one click now.
Please note....I had to replace mine because they were stuffed.....I don't know and I can only presume that it will make a difference over the standard ones if they are not shagged.
I have setup an exchange with the workshop using Iain's spare set of arm's.
Prices as below:
*Supply and press in the bush's into arms. $300(ex gst)....shipping not included. Please note that this will be an exchange set of arms so a returnable deposit will be needed to guarantee I get your arms, back.
*Supply and press bush's into arms + install into car $450(ex gst) through the Suspension workshop. Please note that this is for the Sydney people....Melbourne people can be sorted for an install as well.
You should not need a wheel alignment after doing this but the workshop I am using had the alignment setting if needed.
Guy's although I will be coordinating this atm I am not making anything out of it so please don't try to barter with me....price tend to go up for you as I don't barter or deal!.......PM me or call me for further detail.
cheers
Craig
Thanks Craig, am I first cab off the rank? I have to get rid of this vibration under acceleration... :whistling:
No left hand pulling here, thats the missus job...
I need to get Iain's in his car first.....as soon as that is done I'll get yours done.
No...I was the first cab off the rank....then Iain....then you!
    • I'm looking for some real world experiences/feed back from anyone who has personally ran a EFR7670 with a 1.05 exhaust housing or a .83 I'm leaning towards the .83 because its a street car used mostly for spirited driving in the canyons roads. I"m not looking for big numbers on paper. I want a responsive powerband that will be very linear to 8000 rpm. I dont mind if power remains somewhat flat but dont want power to drop off on top. The turbo I've purchased is a 1.05, although the mounting flange T3 vs T4 and internal vs external waste gates are different on both housings, I not concern about swapping parts or making fabrication mods to get what I want. Based on some of the research I've done with chat gpt, the 1.05 housing seems to be the way to go with slightly more lag and future proofing for more mods but recommends .83 for best response/street car setup. AI doesn't have the same emotions as real people driving a GTR so I think you guys will be able to give me better feed back 😀
    • Surely somebody has one in VIC. Have you asked at any shops?  Is this the yearly inspection or did you get a canary?
    • This is where I share pain with you, @Duncan. The move to change so many cooling system pieces to plastic is a killer! Plastic end tanks and a few plastic hose flanges on my car's fail after so little time.  Curious about the need for a bigger rad, is that just for long sessions in the summer or because the car generally needs more cooling?
    • So, that is it! It is a pretty expensive process with the ATF costing 50-100 per 5 litres, and a mechanic will probably charge plenty because they don't want to do it. Still, considering how dirty my fluid was at 120,000klm I think it would be worth doing more like every 80,000 to keep the trans happy, they are very expensive to replace. The job is not that hard if you have the specialist tools so you can save a bit of money and do it yourself!
    • OK, onto filling. So I don't really have any pics, but will describe the process as best I can. The USDM workshop manual also covers it from TM-285 onwards. First, make sure the drain plug (17mm) is snug. Not too tight yet because it is coming off again. Note it does have a copper washer that you could replace or anneal (heat up with a blow torch) to seal nicely. Remove the fill plug, which has an inhex (I think it was 6mm but didn't check). Then, screw in the fill fitting, making sure it has a suitable o-ring (mine came without but I think it is meant to be supplied). It is important that you only screw it in hand tight. I didn't get a good pic of it, but the fill plug leads to a tube about 70mm long inside the transmission. This sets the factory level for fluid in the trans (above the join line for the pan!) and will take about 3l to fill. You then need to connect your fluid pump to the fitting via a hose, and pump in whatever amount of fluid you removed (maybe 3 litres, in my case 7 litres). If you put in more than 3l, it will spill out when you remove the fitting, so do quickly and with a drain pan underneath. Once you have pumped in the required amount of clean ATF, you start the engine and run it for 3 minutes to let the fluid circulate. Don't run it longer and if possible check the fluid temp is under 40oC (Ecutek shows Auto Trans Fluid temp now, or you could use an infrared temp gun on the bottom of the pan). The manual stresses the bit about fluid temperature because it expands when hot an might result in an underfil. So from here, the factory manual says to do the "spill and fill" again, and I did. That is, put an oil pan under the drain plug and undo it with a 17mm spanner, then watch your expensive fluid fall back out again, you should get about 3 litres.  Then, put the drain plug back in, pump 3 litres back in through the fill plug with the fitting and pump, disconnect the fill fitting and replace the fill plug, start the car and run for another 3 minutes (making sure the temp is still under 40oC). The manual then asks for a 3rd "spill and fill" just like above. I also did that and so had put 13l in by now.  This time they want you to keep the engine running and run the transmission through R and D (I hope the wheels are still off the ground!) for a while, and allow the trans temp to get to 40oC, then engine off. Finally, back under the car and undo the fill plug to let the overfill drain out; it will stop running when fluid is at the top of the levelling tube. According to the factory, that is job done! Post that, I reconnected the fill fitting and pumped in an extra 0.5l. AMS says 1.5l overfill is safe, but I started with less to see how it goes, I will add another 1.0 litres later if I'm still not happy with the hot shifts.
