  • Replies 186
Posted Images
Soichi said he hasnt put it up on his page yet but he sent me a link to a tuner mate of his in wellington
http://www.speedtech...ent+System.html
and said all that you read there he can do
as in use the hks ecu as a piggy back install yet a stand alone ecu
and they have off the shelf harneses for the vq25det , he says look further down at make and model and ull see vq25det
Edited by Sidius
so why cant the nm35 run a stand alone ecu
wouldnt it be like any stand alone ecu
new ecu goes in and tuning , maping is done
all i know he said around 4g for full stand alone installed
beacuse like the gtr it has a whole lot of other shit to run off the factory ecu.
let him know its just a plug in loom with fcon and m35 and see what he says..
Haha, 2k for an install with a plug and play harness, I need to get on that gravy train... Even if it is tuned that's very expensive.
For 4k I would be putting a Motec M800 in I think.
At least you have an authorised HKS tuner around the corner, I would have to drive 1000k's
as scott said.
got the kakimoto R exhaust. i have not seen an exhaust where you can see straight through the 80mm of goodness(pipe) lol
for an exhaust shipped for $1000 i think its the best ive seen. cant guarantee it being quiet though :P
flames will definitely be happening. *looks at craig*
as scott said.
lol lets have a loudness competition when mines done :P
lol your using a flappy thing though arent you? or changed your mind? i have a feeling mines going to be louder than before, its seriously a straight through pipe. im amazed its beautiful lol.
^^lol show off
well heres some better and more accurate pics of the kakimoto system.
this is what came with it,
this is the mid pipe hotdog styled mufffler - straight through
and the tail pipe muffler - straight through.
can't wait to get this exhaust on.
^^lol show off
scotty got any pics of ur front pipes, race cat and downpipe , my kaki n1 full mega is on its way
I don't even have the turbo yet buddy... Give me two weeks, unless you mean the old system? I fit it into Sage's car last night.
f**k i still want this 3.5 inch u ass.
Sidius, you wanna buy my dump off me? lol
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
