is that your old car? cause my mate deano owns it now
he has shaved the boot lock and put on a drift lip. looks schmicko
Yep ok I'm sold.
SSR SP1's definitely the best looking wheel on an R33.
I've been looking at replacing my Sterns for 4 years now.
Have done heaps of image editting, pasting various wheels on to my car.
My car is black, and I like the look of the bronze spokes on the black RX-7. Classy and mean.
I think the dish stands out more with a darker spoke.
Super black would probably be my choice for a new set.
If I get a used set, I'd spray em bronze or gunmetal.
Hard to find a used set of rims with the right offsets you want.
Yep ok I'm sold.
I have a set of 17x9.5 +10 and 18x9.5 +16 Chrome SP1s for sale.
I also have another full set of 18 inch Chrome SP1s coming over on my 34 atm as well. They will be sold as I'm going really aggressive with my fitment. The ones on it fill the guards already :D
Ill throw mine into the mix, I think they look good on my car, there bigger then i wanted (19's, i wanted 18's but after constantly getting told the wheels i wanted were only available in 19's for the offset on my car I gave up and got 19's) But the suit my black skyline pretty well... Well I think so anyway
Koya INOX R1's (Polished Lip, Machined face spokes with black R1 + other details)
19 x 8.5 front (235's)
19 x 9.5 rears (265's)
Sorry about image size
They have nice dish at the rear, a little at the front and fill the guards pretty nice
Edited by 89CAL
  • 3 months later...
dont really wanna be getting coil-overs just for the sake of it. im 6 foot 4 and its bad enough to get in and out of at the moment lol. it is lowered with low king springs and GAB shocks, handles much better now. where i took that photo,it makes it look like its riding high.
    • Sounds like you've got an interesting adventure ahead here with local support if you have trouble! My guess is that, unboosted, you will be OK with a small upgrade like -9. What will happen is that once the stock ECU sees more airflow than it expects it will add a heap of fuel and pull a heap of timing to be safe because it can't understand how it could get that much air without there being an issue. You will see clouds of black smoke and it won't pull hard through the midrange and top end. So, overall it will be a bit frustrating but should be OK. If you are still nervous set the base timing back 2o through the CAS, but it will be even more sluggish everywhere. As said above through...this is not my guarantee your engine won't be blown into a million pieces, leaving you looking for very hard to find parts A better idea is get a computer with logging ASAP, wire in a wide band O2 sensor and a use remote tuner. I've done multiple cars this way and while it is not as good as a specific tune on a dyno they can get it 90% right. I'd suggest if you can afford an R33 GTR these days you can afford an ECU and tune. And if you can't afford that you sure won't be able to afford the rebuild if it goes bad in the meantime,.
    • Yeah it would be nice if someone took the time to put that sort of information together, but there are a lot of variations in looms. I think you are making this way hard for yourself if you just want to get it running....sourcing an SR20 with the right wiring will be a billion times easier than matching the RB loom to an S15 chassis. If you do end up going this way, you just need to trace every wire in the loom with a multimeter, 95% of them will go to a location you can confirm at the ECU.....and then post it up for the next person who needs it
    • Just top it up with water, and keep a general idea of how much you added. It is normal for water to be pushed into and pulled out of the reservoir through the cap, and it should not be more than half full or it will be likely to overflow when hot. Any decent mechanic can do a pressure test of the cooling system to confirm if you have a leak. Keep in mind if it is only leaking a little and when hot it may well evaporate before you see it hit the ground
    • I'd ask the shop what they used and use that. Mixing coolants is sometimes OK, sometimes not, and you have know the details of each coolant to know whether it's a good idea or not.
    • Is it alright to top up with just another green coolant?
