Hey guys got some parts for sale from my car as i have given my car face lift and other mods. PICTURES AT BOT.
>> R32 gtst/gts Black front gaurds/quarter panels. Both sides available, right side has scratch and about 2cm of paint been removed. shown in pics. $150($130 for scrtached one)
>> R32 gtst/gts inner front gaurds. $50 both
>> R32 gts Black front Bar $80
>> R32 gts/gtst front blinkers. $50ea
>> R32 Trust 3inch cat back, resonator replaced with straight pipe. comes with interchangible end cannon/muffler to baffle sound. as in pics. $150
>> R32 Dump and hks down pipe with sensor. $80
>> R32 gts down pipe with 3inch catalyst. $50
>> space saver wheel unused (pcd 4/114.5) $50
>> R32 front 4 stud hub/control arms (pcd 4/114.5) $50 both
Also variuos r32 interior parts, dash, cluster sorround, plz ask
Open to offers
Andrew, east merlbourne, 0433 859 377
SOLD pending payment
will pick up friday or saturday,
call you before then to let you know
need to pick up r33 quarters from heathmont,
what the best price you can do the front drivers side quarter ? or as pair ?
please pm me
cheers Nick
i have 2 wanting to buy front bar here is some more pics of the condition. only scratches no dints.
">> R32 gts Black front Bar $80"
plz let me know if ur still interested.
still got the cigarette lighter socket?
by cigarette light socket im assuming u mean the middle bottom dash that holds the ash tray and covers the sides of your headunit right back ur pedals? if so then yes However it is from a R32 GTR and will not match gts/gtst interior as the bottom hieght is not long enough which leaves it not flush the gts/gtst floor carpet. i've tried.
nah champ i just meant the actualy socket where the cigarette lighter goes onto. the round cyclinder thingy that is glued to the plastic surround. mine came off completely
Nah sorry mate i dont wanna seperate this cos it will ruin value of piece.
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
