Where is the best place price wise to hook up a front mount? Greddy or Hybrid or does it even matter?
Would there be any difficulty in installing it in an 96 S2 R33 GTS-t? I need to take the horn out of that space and re-position already
I dont want to get dicked over on an install price either- Hence, dont anyone reply with 'take it to Car Toys' haha
Cheers!
https://www.sau.com.au/forums/topic/268482-front-mount-intercoolers/
take it to car toys hahaha.....joking
umm generally brand name coolers tend to work a bit better IMHO and as regards to fitting most of the coolers are quiet easy to DIY...there are a few threads about them in the DIY section i would think.....in my 33 i had to reposition the Horn but only had to flip it over from where it was mounted before...best places to look for coolers would be on the traders on SAU like Just Jap then the next best bet would be autobarn.....they tend to sometimes have those coolers for a nice price....specially the one at gillies plain or holden hill.....
Most import garages would be able to get a decent price on fitting if you would like it to be done by mechanics
Good luck mate
Good luck mate
Thanks for the info mate. Its good to know you can just flip the horn over. I remember seeing a while back Greddy's advertised at autobahn for like $800 for the part. Will suss it out. Did you notice genuine improvement in horsepower and performance after installation?
i picked mine up for $600 thats when the $ was good value lol.....I did notice that the car was running a lot better....horsepower wise i didnt feel a great deal if any....but its to cool air not to force air lol......in the summer you can definately feel it working and ohh it loves the winter chills.....so i reackon that is definately a good investement
Greddy is what i have as well and according to them its not a big pressure drop either and IMHO they work a lot better then those Hybrid types...$800 seems to be general price for coolers now days....
If i was you, and either didnt have the confidence/time to be fitting it yourself, head to JustJap.com, grab a cooler from there, they do fit well enough, and spend maybe 2-300 on fitting. theres the price of 1 greddy cooler.
Sweet. I was trying to get one for summer but didnt end up with the cash. Reckon I will hook one up in the coming months. Cheers
ill be getting a HDI Intercooler from Exhaust Technology....i think its like $850 and they can install it for you aswell and i dont think it is much more to do that
Is that the GT or RS core?
HDI GT kits go for 500-550ish where as the RS (100mm) goes for 700ish.
850 imo is a little pricey.
I had an RS HDI in my R and paid 1/2 that price for the cooler without the pipes......used my own pipes
HDI Intercoolers (RS)
after seeing a lot of shitty cooler kits and how badly they can fit, id recomend the greddy type m for vaule, fitment and quality.
isc can get you one at a decent enough price.
Thats exactly what i was trying to get to...my Greddy kit bolts straight up and no hassles...so if fitment and quality you want mate then go with a brand name cooler
is there a cooler that will fit a r33 gtst without no hasstles? like no cuts or nothing?
my current cooler is greddy, but reo bar is cut.
ummmm, R34 Sidemount. All others will require cutting and drilling of some sort. The one i bought through a mate at work was supposed to be hassle free as it used the stock plumbing, was wrong. Sure it used the stock plumbing, but i had to but up my foglight housing to get the piping to fit from the cooler to the stock plumbing.
    • Ok I get you. But isn’t the butterfly intake a headache with the +T?  see this is my plan so far but please advise me into the right direction.  Nistune Ecu, 1000cc Bosch injectors, TD05 or TD06 Kinugawa turbo using stock rb25det exhuast manifold, walbro fuel pump unsure of model I think it’s 450/460, spitfire coils and sparks to suit and a R35 MAF sensor and boost sensor.    I was thinking maybe do a cheap eBay plenum $400-500 or try find a stock det neo intake. I think I’d port match it so it’s getting the full capacity but open to advice please.  Thanks
    • The issue now is the 'fuel cut' while driving, and when it happend, it does not stall. This, I did not test the fuel pressure while driving as I cannot with a fuel pressure gauge. I do have Nistune logs, yes. I have also replaced the MAF Sensor.   Also related to the FPG Fuel Hanger – I just realized that I need a Deutsch Crimp Tool to crimp some cables for the FPG Fuel Hanger. Need to purchase additional cables as the kit only included 2, which are for the float. FPG has not responded to my emails so far since purchasing. I thought about taking it to someone and having it done professionally, but I am reluctant since everyone I took it to messed up in some way.
    • There's a good German place in Brisbane if youre up for the drive 😛
    • The German place in Cabramatta was rock solid, fresh pretzel cooked to order back then. Then it went all quiet, after all the poker machines were removed, then I believe it closed for good. I did drive past the other week and noticed outdoor lighting a big screen, but no idea what is there now.
    • Yeah I suspect even if you hold airmass per cycle/cylinder constant if you get too far away from stock you're still going to have problems running the factory tune within the bounds of the factory load scale. Cams, different displacement/rod ratio, etc. I'm just lucky that the GTIII-SS with wastegate boost + CA compliance cats is pretty much equivalent to stock turbos. When I have actual space I can finally get it tuned and modify the fuel system for flex fuel to 100% handle any detonation concerns when cranking the boost to whatever those dinky turbos can put out.
