I cant find a gasket for an n1 oil pump anywhere on ebay or anything theres a few threads that have all the nissan part number's they have the n1 pump's but no gasket anyone know where i can get one?.
No such thing. The gasket for the standard pump can be used with the N1 pump.
Yeh i was thinking might have to try and reuse the standard gasket if its still in good condition when it gets taken off. the place i got the pump from said they dont come with gasket's but they have them when trying to buy one from them there telling me they have run out. just have to give the original one a go i guess.
Thanks.
Edited by unix
gasket in a tube works fine.
Never use sealants where a gasket should be, except as a last resort. This is especially important with something like this oil pump. Think about what happens when you tighten the bolts....the sealant gets squeezed out of the joint face and some of it is squeezed out into the oil passages. How much is dependent on how heavy handed you are, but it can affect oil flow in bad cases. There's a reason Nissan used a gasket.
Thanks.
i got a few spare here if you get stuck. DO NOT use only gasket goo.... engine failure is only a gallery blockage away...
    • The final part arrived today to un-clampify and simplify the intake Who would have though a 1/2" hose stainless bulkhead fitting designed for below waterline bilge pumps would be what I needed Test fit on a 3" offcut I had laying around to see if it would work, and it worked a treat All going well the intake will be on its "final version" tomorrow
