I thought i won the last one.. hang on a sec whilst i check the thread..
AHAHAH have you seen the last page of the thread... damn it Troy didn't get the pics up i think til later.. anyways i had the winner of the model comp completely bent over my car arse facing the camera! twas great... well i thought so anyway...maybe i came second place then! especially according to driftr33 :-)
If i can score a digital camera this year i will hopefully get some more nice pics for the SAU "private" collection :-)
  • Replies 120
fer real yeah it takes guts to do that :)
Model comp? am I missing something? :confused: heheh...
Photos will be up when I get them processed. it was proper film cam not Digital ones... it will take time.
but I'll post them up soon ;)
again Well done Girls and Guys :D
cheers
Joey
Yep photos comming:
* Hot Fours Mag
*Fast Fours Mag (those ones were a little more tasteful than Hot Fours)
* Red Earth Design ....... and they want to use me for more work so i hear free graphics coming for my car!!
*Technik Car Audio .... are going to send me their photos ..... i must say a special thanx to those lads keeping me occupied through out the day with hijinx
* 1010 Modelling agency ..... god that guy is persistant ..... so will check to see if photos end up on website ..... if they do will post the link.
And the rest are just peoples personal photos ..... ive got a guy wandering around with nearly a whole film of me i swear .... by the end i was like "just phucking leave me alllloooone" anyway its all good fun ..... but im sick of smiling!
    • I wanted to try and preserve the front bumper as long as possible, they're not cheap and are made to order in Japan. Taking inspiration from my previous K11 Micra build where I made an undertray for the Impul bumper, I did the same for this BN Sports bumper but a little slimmed down.  This time round I only made a 'skid plate' (if that's the correct wording/term) for just the bumper surface area, the Micra version covered the gap like an undertray. Starting off with a sheet of mild steel approx. 0.9mm thick 4ft x 2ft in size. I traced around the bumper, cut it out and cleaned the edges. Luckily I was able to get two halves from one piece of metal In the video I installed it as is, but I've since then I've removed it to spray and add a rubber edging trim. The rubber trim is suitable for 1-2mm and it's a really nice tight fit. The bolts had to be loosened due to the plates being too tight against the bumper, the trim wouldn't push on I used some stainless M6 flat headed bolts for a flusher finish (rather than hex heads poking down), I believe this style fastener is used for furniture too incase you struggle to source some. The corner's are a little wider, but this may be an advantage incase I get close to bumping it  The front grill got some attention, finally getting round to repairing it. Upon removal one fixing pulled itself out of the plastic frame, one side is M8 that fixes inside of the frame, where as the other side is M5. Not knowing I could get replacements, I cut down an M8 bolt, threaded it inside the frame along with a decent amount of JB Weld.  The mesh was replaced to match the bumper. One hole on the bonnet/hood had to be drilled out to 8mm to accommodate the new stud, once the glue had set it could be refitted. I think the reason the grill was double meshed was to hide the horn/bonnet latch (which makes sense) but I much prefer it matching the bumper Bumper refitted and it's looking much better IMO The Youtube video can be seen here: https://www.youtube.com/watch?v=bVZP35io9MA
