HEY GUYS
MARK FROM HPI MAG HERE.
I AM CURRENTLY TALKING TO THE OWNERS OF KINETIX RACING AND I AM ABOUT MAKE AN ORDER FOR THEIR LATEST PLENUM FOR THE V35.
I HAVE ASKED HIM FOR A SPECIAL PRICE AND HE HAS ASKED ME TO SEE IF MORE AUSSIES WOULD BE INTERESTED.... THERE WILL BE ONLY 5 AVAILABLE IF ANYONE IS HALF INTERESTED PLEASE LET ME KNOW.
I AM EXPECTING THE PRICE TO BE ABOUT $800
** Newly released Velocity Intake Manifold replaces our older SSV version with many improvements:
* Velocity plenum chamber design - Equal air flow between cylinders
* 12% more plenum chamber volume
* 10% short intake runners for more flow and higher HP potential
* Smoother A/F curve - less tuning required - more consistent power
* High RPM power !! 30.5hp gains at 6800 rpm
* Thicker gauge construction for higher boost - warranty up to 30psi **CLICK ON THE PICTURE FOR DYNO PROVEN RESULTS**
For 2003-2007 350z and 2003-2007 G35 (single throttle body engine models)
We took the very popular SSV manifold and went over every aspect of its design to make the most impactful improvements. As our customers and the 350z/g35 marketplace continue to improve the power potential of their engines, the SSV needed a redesign to accomodate the the higher power output of these vehicles.
The new Velocity Manifold is geared for higher flow and higher RPM power gains. This allows for even larger power gains in the many F/I vehicles out there.
The new Velocity Plenum design maximizes flow to the furthest cylinders by creating a "venturi" effect. By gradually narrowing the plenum chamber , the air speed must increase to satisfy the equation of continuity. Improved flow to all cylinders also means an improved smoother A/F curve that requires less tuning in F/I applications, and ZERO tuning in N/A vehicles.
This manifold is constructed entirely of Stainless Steel, then polished out for an absolute beautiful finished product that looks as great as it performs. We chose stainless because of its great thermal properties, conducting 10X!! less heat than aluminum and eliminating much of the manifold's mass, which greatly helps with heat soak. Stainless is considerably more expensive than aluminum, but the finish shines brighter and longer. The overall manifold SAVES 10lbs of weight over stock! Precision TIG welding throughout, and a CNC cut 3/8" main flange. All mandrel bent runners and charge tube, this manifold rivals the quality of other intakes twice its price.
We improved greatly upon the factory plenum designs. The factory lower plenum creates MANY dips and turns which do not promote good airflow and create turbulence inside your factory intake. We developed a straight shot design, eliminating the twists, turns, and obstructions. We then took each runner and also added velocity stack inlets to each individual runner for even better performance.
This Manifold is a DIRECT replacement and will work with any aftermarket intake. It also allows you the ability to use the factory strut bar, or any aftermarket strut bar. We also have available an engine cover specifically designed for our manifold.
We recommend an A/F tuning on Forced Induction vehicles (turbo and supercharged) after installation of the SSV in order to maximize power and overall engine reliability. Tuning is generally not needed in Naturally Aspirated ( NA ) applications.
Each manifold is supplied with all necessary hardware and instructions. There is an additional port supplied which can be used for boost gauges, etc.
https://www.sau.com.au/forums/topic/269716-ssv-extreme-plenum/
Awesome!
Very keen.
Will there be a deal on the cover that goes with the plenum as well?
i am not sure mate, the guy will be emailing me everything tommorrow morning. the $800 is Aussie dollars and includes shipping charges.... will update for you guys tommorrow.
its listed for $749 on their site which is us dollars, plus you would have to include shipping charges plus GST....so all up this should save each guy who gets one a few hundred bucks.
Hey Guys,
Cut off date is most likely next Thursday. i am still waiting on the final price. i am pushing for $800 AUD
Omce all 6 are ordered they have told it will take about 2 weeks to come in.
Will keep all of you updated once i hear the final price.
Cheers Guys
unfortunately i'm going to have to back out of this one (i hope i dont regret it later).
I need to sit down and plan out the work and parts that i plan to do in future, and this might not be inline with it (i'm looking at the ssr twin entry).
feel free to list me as a maybe, and i'll be interested to see what price you get. But to make sure i dont completely screw your planning dont count me as a definate.
I always wonder when i see manufacturers claim of these plenums about the 20/30/50 hp gain.
This plenum looks good although i'm not sure about the 30.5hp gain ? Maybe on a car with forced induction installed. Be interesting if someone dynos it after install :)
Guys do a search on the Yank forums, these things are not as good as they make out especially for NA applications. I have the kinetix V+ plenum or whatever its called and even with that the car only made 1 or 2 hp more.
The ssv has been known to make less power then the standard one with NA applications, not trying to rain on anyone but rather save u guys $$'s and dissapointment.
i was trying to tell you about it a few posts back.....
    • Hi,  Just joined the forum so I could share my "fix" of this problem. Might be of use to someone. Had the same hunting at idle issue on my V36 with VQ35HR engine after swapping the engine because the original one got overheated.  While changing the engine I made the mistake of cleaning the throttle bodies and tried all the tricks i could find to do a throttle relearn with no luck. Gave in and took it to a shop and they couldn't sort it. Then took it to my local Nissan dealership and they couldn't get it to idle properly. They said I'd need to replace the throttle bodies and the ecu probably costing more than the car is worth. So I had the idea of replacing the carbon I cleaned out with a thin layer of super glue and it's back to normal idle now. Bit rough but saved the car from the wreckers 🤣
    • After my last update, I went ahead with cleaning and restoring the entire fuel system. This included removing the tank and cleaning it with the Beyond Balistics solution, power washing it multiple times, drying it thoroughly, rinsing with IPA, drying again with heat gun and compressed air. Also, cleaning out the lines, fuel rail, and replacing the fuel pump with an OEM-style one. During the cleaning process, I replaced several hoses - including the breather hose on the fuel tank, which turned out to be the cause of the earlier fuel leak. This is what the old fuel filter looked like: Fuel tank before cleaning: Dirty Fuel Tank.mp4   Fuel tank after cleaning (some staining remains): Clean Fuel Tank.mp4 Both the OEM 270cc and new DeatschWerks 550cc injectors were cleaned professionally by a shop. Before reassembling everything, I tested the fuel flow by running the pump output into a container at the fuel filter location - flow looked good. I then fitted the new fuel filter and reassembled the rest of the system. Fuel Flow Test.mp4 Test 1 - 550cc injectors Ran the new fuel pump with its supplied diagonal strainer (different from OEM’s flat strainer) and my 550cc injectors using the same resized-injector map I had successfully used before. At first, it idled roughly and stalled when I applied throttle. Checked the spark plugs and found that they were fouled with carbon (likely from the earlier overly rich running when the injectors were clogged). After cleaning the plugs, the car started fine. However, it would only idle for 30–60 seconds before stalling, and while driving it would feel like a “fuel cut” after a few seconds - though it wouldn’t fully stall. Test 2 – Strainer swap Suspecting the diagonal strainer might not be reaching the tank bottom, I swapped it for the original flat strainer and filled the tank with ~45L of fuel. The issue persisted exactly the same. Test 3 – OEM injectors To eliminate tuning variables, I reinstalled the OEM 270cc injectors and reverted to the original map. Cleaned the spark plugs again just in-case. The stalling and “fuel cut” still remained.   At this stage, I suspect an intermittent power or connection fault at the fuel pump hanger, caused during the cleaning process. This has led me to look into getting Frenchy’s fuel hanger and replacing the unit entirely. TL;DR: Cleaned and restored the fuel system (tank, lines, rail, pump). Tested 550cc injectors with the same resized-injector map as before, but the car stalls at idle and experiences what feels like “fuel cut” after a few seconds of driving. Swapped back to OEM injectors with original map to rule out tuning, but the issue persists. Now suspecting an intermittent power or connection fault at the fuel pump hanger, possibly cause by the cleaning process.
