Ok so Just Jap has either "Splitfire Direct Ignition Coil Packs" for $695 or "JJR Direct Ignition Coil Packs" for $399 for sale.
Splitfire: http://justjap.com/store/product.php?produ...at=0&page=1
JJR: http://justjap.com/store/product.php?produ...at=0&page=1
Does anyone know the difference?
Has anyone experianced both or have any recomendations? Hard facts guys not just because you've got them.
I am making the assumption that cause they both say they can go on a R34 with the RB25 Neo they will be fine. Is this right?
I have a Series 2 RS FOUR S.
Thanks in Advance Guys n Girls. :D
https://www.sau.com.au/forums/topic/270005-coil-packs/
Holden coil packs?? That's a first.
well the splitfires will work in the stagea (as there is a image of the Stagea on the box)
I wanna know from guys who are using JJR's if they are any good
Edited by BigDirtyJase
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4594549
yeah it's when you run big power, you use them as external coilpacks - i think from memory you only need to use 3 too as they are twin pulse or something
anyway, back on topic, get splitfires. end of story. don't bother with JJR rubish
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4594584
you cant go wrong with splitfires, they are a proven brand. dont bother with the JJR ones, you get what you pay for. or you can run commodore/falcon coils, they are 3 coils in one block and each coil handles two cylinders "3/2 coils", do a search on wasted spark you'll find heaps of info. the only benefit is they are cheaper to replace if they burn out/blow up.
it isn't always better running the wasted spark commodore/falcon coils over splitfires. i remember a write up on this testing all different coil pack setups, and the power that the stock 3/2 coils output, while they had higher MJ power per coil than the direct ignition coils, that power is shared between two spark plugs so it worked out less MJ per plug than running a good direct ignition or even 6 single coil setup.
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4595021
Hi,
I dont mean to hijack this thread but i also am wondering what coil packs are available for the M35....... No one seems to want to help and i feel mine will be due for replacement soon( some surge and miss at high rpm) I was hoping to change them when i do the plugs as they are in a bastard of a place on the VQ..
Cheers
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4595270
Thanks in Advance Guys n Girls. :(
I can't answer your question as to which aftermarket pack is best (Performance-wise also have 'Yellow Jacket' coils available - they could be another option), but the question begs asking - why do you want to replace what you've got?
Do you have a confirmed fault, or have you been drawn into the false belief that the factory coils are no good?
Curious minds want to know...
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4595334
Hi,
Cheers
Dunno mate. I have looked (briefly), but not found anything for M35.
Perhaps a VQ35 set would work? There would have to be some out there for V35 or Z33!
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4595807
Ben i am getting a tiny bit of surge...wether is me being over sensitive to the car or an actual miss is another thing. :P
But also they're 9 year old packs. So its also simply a preventative measure. I'm planning future mods so having packs that i know are deffinatly up to standard will be a weight of my mind. (I'm also going to change the plugs at the same time)
So by the looks of it I'll go for the Splitfire ones. Just did a bunch of overtime this week at work so that will pay for them nicely. :P
I was kinda thinking that the whole "You get what you paid for" thing would apply in this case but still wanted to put the question out there.
Thanks all. I'll let everyone know if i see a difference when i get them.
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4596455
A bit of topic. Am I the only one who is perhaps over sensitive to the sounds and vibrations from my car, or are there others in my boat. What I mean is when ur driving and u hear a noise or feel a vibration that u may not have felt or heard before, and worry that its a bad noise or vibration. :P
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4596475
yeah i do at first, but then a quick turn of the volume knob on the cd player makes those noises go away :P if the noises get louder then so does the cd player lol
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4596648
  • 3 months later...
Hmm, neither JJR or Yellow Jacket make coils to suit NEO engines yet. So that means that the only coilpack options available to series 2 owners are OEM Nissan coilpacks (not REALLLY an option, in my case at least, at $1000+) or Splitfires.
...or chop up your $200 coilpack harness and wire in different coils...
can someone suggest any other solutions for S2 owners?
Edited by DaveB
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4822782
Anything that fits the r34 rb25neo will fit C34 rb25neo apart from sump and im pretty sure the block is different down the bottom cause of the all wheel drive.
As for coil packs. Im running splitfires and as far as im concerned they are the way to go. i wouldnt waist my time with any cheaper options, they are proven to work the best and you get what you pay for.
SPLIT FIRES all the way !!!
https://www.sau.com.au/forums/topic/270005-coil-packs/#findComment-4822867
    • All 3 I guess. The car came with the JASI Aero 4 door Type R Full Kit unpainted so this was one thing at the top of my list to complete then I noticed there were body panels parts for this kit so i picked them up along with some black mesh to fill in the front bumper and front side air vents. car is at a paint and body shop atm completing this work. Next I will be addressing the internal bells and whistles, great summer project I can do with the kids.  full interior removal - ,boys car sound deadening - pads and spray ,boys stereo, sound, lighting - Big 3, GTT or bigger alternator ,kids head lining - dye black add star lighting mod ,daughter. That's it for the next 5-6 months. I have some motor maintenance  work i have to plan out. oil filter relocation, gaskets, mounts. beyond that, mind is starting to turn over if i can use a DET intake plenum, block off turbo ports & pipe in a air intake.
    • roller coaster of a ride. Alarm system was removed & main harness was repaired where possible. still no fix just random successful starts. moved on to the replacing the ignition switch and relay. well all this troubleshooting & repair has been going on, the car is at a paint and body shop being pushed around. Ive been going down there on odd days after work to get it sorted.
    • 5th November if you want to come out for a spin wakfield
    • PROBLEM WAS BROKEN COOLANT SENSOR!!! Replaced with a new one and its running mint.
    • I think he was only proposing to use the wire, not the sender. Simply because it runs from the right place to the right place. Personally, I wouldn't hack up the factory wiring like that. I'd just lay in the Defi loom.
